    Clocks and Two Time Zones
    8 Posts 4 Posters 7.2k Views 4 Watching
      daikaiju
      Any advice/ideas on how to get the MM to display two clocks of different time zones?
      • yawnsY Offline
        yawns Moderator
        Just add the clock for a second time, but specify the timezone in the config.
        Please take a look here: https://github.com/MichMich/MagicMirror/blob/master/modules/default/clock/README.md
          daikaiju
          Sure did.
          Perhaps, I missed something? I tried several time zone variations.
          module: 'clock',
          	timezone: 'Asia/Tokyo|JST JDT|-90 -a0|010101010|-QJH0 QL0 1lB0 13X0 1zB0 NX0 1zB0 NX0|38e6',
          	position: 'top_right'
          yawnsY 1 Reply Last reply Reply Quote 0
          • yawnsY Offline
            yawns Moderator @daikaiju
            module: 'clock',
            position: 'top_right',
            timezone: 'Asia/Tokyo'
              roramirez Core Contributors @yawns
              @yawns There an issue this feature. I explained about this on https://github.com/MichMich/MagicMirror/issues/797
              The moment isn’t loaded when is run in electron mode. Only it’s working on server mode.
              I’ve investigating in this area, I don’t have nothing concluded yet. If some can give a idea can be nice. cc @strawberry-3-141 @paviro @Jopyth
              Easy module development with MagicMirror Module Template
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @roramirez
                @roramirez i tested it back then (also commented on github) and it worked for me in electron, I tried it again now and it still works
                R 1 Reply Last reply Reply Quote 2
                  roramirez Core Contributors @strawberry 3.141
                  @strawberry-3.141 Yes, Its work :). I’ve checking my config and is set nodeIntegration to true and this fail with that. I presuming this can be some tests fail at sometimes, I’m not sure.
                  I share my config for failure.
                  var config = {
                  	port: 8080,
                  	ipWhitelist: [ ],
                  	language: "en",
                  	kioskmode: true,
                  	timeFormat: 24,
                  	units: "metric",
                  	electronOptions: {
                  		webPreferences: {
                  			nodeIntegration: true,
                  			module: "clock",
                  			position: "center",
                  				timezone: "America/Campo_Grande"
                  if (typeof module !== "undefined"){module.exports = config;}
                    roramirez Core Contributors @roramirez
                    @roramirez Well for test this feature fail
                    https://travis-ci.org/roramirez/MagicMirror/builds/220155902
                    Commit: https://github.com/roramirez/MagicMirror/commit/05d7c9556e773bf2b941035953200ff327efb476
                    Apparently if we load moment-timezone with nodeIntegration will be fail
