    Clocks and Two Time Zones
    8 Posts 4 Posters 6.6k Views 4 Watching
    • yawnsY Offline
      yawns Moderator
      Just add the clock for a second time, but specify the timezone in the config.
      Please take a look here: https://github.com/MichMich/MagicMirror/blob/master/modules/default/clock/README.md
        daikaiju
        Sure did.
        Perhaps, I missed something? I tried several time zone variations.
        module: 'clock',
        	timezone: 'Asia/Tokyo|JST JDT|-90 -a0|010101010|-QJH0 QL0 1lB0 13X0 1zB0 NX0 1zB0 NX0|38e6',
        	position: 'top_right'
        • yawnsY Offline
          yawns Moderator @daikaiju
          module: 'clock',
          position: 'top_right',
          timezone: 'Asia/Tokyo'
            roramirez Core Contributors @yawns
            @yawns There an issue this feature. I explained about this on https://github.com/MichMich/MagicMirror/issues/797
            The moment isn’t loaded when is run in electron mode. Only it’s working on server mode.
            I’ve investigating in this area, I don’t have nothing concluded yet. If some can give a idea can be nice. cc @strawberry-3-141 @paviro @Jopyth
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @roramirez
              @roramirez i tested it back then (also commented on github) and it worked for me in electron, I tried it again now and it still works
              R 1 Reply Last reply Reply Quote 2
                roramirez Core Contributors @strawberry 3.141
                @strawberry-3.141 Yes, Its work :). I’ve checking my config and is set nodeIntegration to true and this fail with that. I presuming this can be some tests fail at sometimes, I’m not sure.
                I share my config for failure.
                var config = {
                	port: 8080,
                	ipWhitelist: [ ],
                	language: "en",
                	kioskmode: true,
                	timeFormat: 24,
                	units: "metric",
                	electronOptions: {
                		webPreferences: {
                			nodeIntegration: true,
                			module: "clock",
                			position: "center",
                				timezone: "America/Campo_Grande"
                if (typeof module !== "undefined"){module.exports = config;}
                  roramirez Core Contributors @roramirez
                  @roramirez Well for test this feature fail
                  https://travis-ci.org/roramirez/MagicMirror/builds/220155902
                  Commit: https://github.com/roramirez/MagicMirror/commit/05d7c9556e773bf2b941035953200ff327efb476
                  Apparently if we load moment-timezone with nodeIntegration will be fail
