    MMM-Bergfex doesent load respectively should be a valid spdx license expression
    30 Posts 6 Posters 20.0k Views 6 Watching
    • G Offline
      gianienderlin
      Hi
      I have problems with installation from MMM-Bergfex.
      During the installation the warning comes MMM-Bregfex should be a valid spdx license expression.
      What does it mean?
      Thanks for your help
        astrakid
        same issue here for me… tried lots of different snow areas, at least only one, but still only “loading…”.
        • G Offline
          gianienderlin
          hello astrakid
          meanwhile the module works without errors. I had to make some adjustments to the files. if you are interested, I can send you my files.
          greetings giani
            astrakid @gianienderlin
            @gianienderlin
            That would be cool. Or put ut in here for ithers as well.
            • G Offline
              gianienderlin
              to be honest, I don’t know what I’ve changed, too long ago. but it works for me
              • G Offline
                gianienderlin @gianienderlin
                oh sorry, i cant upload my files…
                Error
                You do not have enough privileges for this action
                  marphi1602
                  Has anybody solved the issue? I am facing also the “loading” issue. I was thinking of that a certain ski area doesn´t exist anymore, but I took only one (Hintertux) which is definitely open and listed on the web page… In case somebody solved the issue, please upload your files.
                    astrakid
                    not yet, i am waiting for the files of gianienderlin, then i can find out what is the fix.
                    • G Offline
                      gianienderlin
                      here are my custom files. please let me know if they work.
                      http://www.filehosting.org/file/details/705911/MMM-bergfex.zip
                      M H 2 Replies Last reply Reply Quote 0
                        astrakid
                        @gianienderlin said in MMM-Bergfex doesent load respectively should be a valid spdx license expression:
                        as far as i could see there is one main change in node_helper.js:
                        instead of
                        var sys = require(‘sys’);
                        he uses
                        var util = require(‘util’);
                        regards,
                        andre
                          marphi1602 @gianienderlin
                          @gianienderlin worked for me! The only thing what I´ve changed was the const in node_helper.js.
                          Due to the fact that I am more interested in seeing the results of the Austrian ski resorts I put // Constants
                          const URL = “http://www.bergfex.at/oesterreich/schneewerte/”;
                          Thank you!
                          • G Offline
                            gianienderlin
                            yes this is possible: -) but thought there was more…
                              marphi1602
                              anybody knows how I have to set ‘Kitzbühel - Kirchberg’ to the config? I think I am struggling with the “ü” same also for special characters like “-”… In case I am putting Kitzbühel into the config it says loading…
                                astrakid
                                @marphi1602 said in MMM-Bergfex doesent load respectively should be a valid spdx license expression:
                                it works for me without an issue. my config part:
                                                        module: 'MMM-bergfex',
                                                        position: 'top_right',
                                                        classes: 'small dimmed',
                                                            updateInterval: 30*60*1000,
                                                            animationSpeed: 0,
                                                            header: 'Schneebericht',
        skiareas: [
        'Fieberbrunn - Saalbach Hinterglemm Leogang',
        'Kitzbühel - Kirchberg',
        shortenArea: 20,
        cssclassrow: 'normal',
        cssclassheader: 'bright'
                                edit: which ‘locale’ are you using? i have “C” configured except “LANGUAGE=” and “LC_ALL=”.
                                edit2: maybe you can try this (this is what is visible in the logfile): ‘Kitzbhel - Kirchberg’
                                  marphi1602 @astrakid
                                  @astrakid thanks! I checked the config once again and I’ve seen some odd ascii characters hence it hasn’t worked properly. Now it’s working!
                                    marphi1602
                                    Is there any chance to highlight this ski resort with the highest amount of fresh snow?
                                    • H Offline
                                      hermlam @gianienderlin
                                      @gianienderlin @astrakid Even after copying these files, the problem stays: the only thing I see is the header and ‘_loading…’
                                        marphi1602 @hermlam
                                        @hermlam pls publish the bergfex part of your config. Are you looking for the snow results of Austria or Switzerland? I had to change the const to the Austrian snow result url, pls see the posts above. For the first step I would suggest to take only one ski resort in your Cfg.
                                          astrakid @marphi1602
                                          @marphi1602 highlightingwould need changes to the sourcecode.
                                          • binderthB Offline
                                            binderth
                                            I do have the same problem:
                                            To avoid some enconding Problems, I picked some oneword-places for start:
                                            			    animationSpeed: 0,
                                            				skiareas: [
                                            						// 'Zell am Ziller - Zilleral Arena',
                                            						// 'Gerlos - Zillertal Arena',
                                            						'Ischgl',
                                            						'Jungholz',
                                            				shortenArea: 20,
                                            like described in this thread (https://forum.magicmirror.builders/post/30795), I changed to var util = require(‘util’); in node_helper.js
                                            In my logs I get this:
                                            TypeError: Cannot read property 'parent' of undefined
                                                at Function.exports.update (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/cheerio/lib/parse.js:69:25)
                                                at module.exports (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/cheerio/lib/parse.js:19:11)
                                                at Function.exports.load (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/cheerio/lib/static.js:27:14)
                                                at Request._callback (/home/pi/MagicMirror/modules/MMM-bergfex/node_helper.js:43:19)
                                                at self.callback (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/request/request.js:186:22)
                                                at emitOne (events.js:96:13)
                                                at Request.emit (events.js:191:7)
                                                at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-bergfex/node_modules/request/request.js:878:8)
                                                at ClientRequest.emit (events.js:191:7)
