    MMM-awesome-alexa
    241 Posts 43 Posters 446.4k Views 47 Watching
    • cowboysdudeC
      cowboysdude Module Developer
      I guess he’s given up on getting this working correctly…
      Trust me this thing is a bloody nightmare…
      • cowboysdudeC
        Well I have figured this out…it’s VERY simple.
        IF You need the sh files to generate your info please go to my fork of this module…I’ve included them.
        https://github.com/cowboysdude/MMM-awesome-alexa
        • G
          g_nandagpl
          Thanks for this module. It works.
          If we have visualization, it would be better.
          dolanmiuD G 2 Replies Last reply Reply Quote 0
          • dolanmiuD
            dolanmiu @g_nandagpl
            @g_nandagpl Thank you for the feedback, glad you got this working
            As for visualization, it turned out really laggy on Raspberry Pi, so I postponed it
            I might re-visit this feature, maybe figure out a way to speed it up if there is enough interest
            • cowboysdudeC
              cowboysdude Module Developer @dolanmiu
              @dolanmiu OH there’s interest. I"m using a real computer to run mine so not an issue :)
              • J
                jnstnr @cowboysdude
                @cowboysdude thanks for the scripts! I’m trying to run auth_code.sh but I get the following errors, and no code to put in auth_code2.sh:
                Can’t locate URI/Escape.pm in @INC (you may need to install the URI::Escape module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl .).
                BEGIN failed–compilation aborted.
                /usr/bin/xdg-open: 1: eval: www-browser: not found
                /usr/bin/xdg-open: 1: eval: links2: not found
                /usr/bin/xdg-open: 1: eval: elinks: not found
                /usr/bin/xdg-open: 1: eval: links: not found
                /usr/bin/xdg-open: 1: eval: lynx: not found
                /usr/bin/xdg-open: 1: eval: w3m: not found
                xdg-open: no method available for opening ‘https://www.amazon.com/ap/oa?client_id=[removed my client id]&scope=&scope_data=&response_type=code&redirect_uri=’
                Any ideas what could be wrong?
                • cowboysdudeC
                  cowboysdude Module Developer @jnstnr
                  @jnstnr Yes I may have an idea…
                  open up both sh files and using your keyboard replace all the double quotes … for some reason they do not copy well. I did that and it ran great! :)
                  • J
                    jnstnr @cowboysdude
                    @cowboysdude just got home and tried it, replaced all " with ’
                    And now I get another error:
                    pi@raspberrypi:~ $ bash auth_code.sh
                    auth_code.sh: line 10: syntax error near unexpected token (' auth_code.sh: line 10: perl -MURI::Escape -ne ‘chomp;print uri_escape($_),’\n’‘’
                    Pretty sure there’s a simple fix for line 10, but haven’t figured it out yet!
                    J S M H 4 Replies Last reply Reply Quote 0
                    • J
                      jnstnr @jnstnr
                      Scratch that, finally managed to get a refresh token! Added it to the config and getting a black screen now though :/
                      • cowboysdudeC
                        @jnstnr Well past that I cannot help you…just double check your config and make it look like the example if that doesn’t solve it msg @dolanmiu He created this module :)
                        • J
                          jnstnr @cowboysdude
                          @cowboysdude Thanks. I managed to get this up and running, now trying to tackle my USB mic :) this isn’t the easiest module to get working!
                          But thanks for all your help, you’re doing great work for the magic mirror community
                          cowboysdudeC dolanmiuD 2 Replies Last reply Reply Quote 0
                          • cowboysdudeC
                            @jnstnr Thanks. Did you see the Troubleshoot section here:
                            https://github.com/dolanmiu/MMM-awesome-alexa
                            Perhaps that will help! :)
                            • dolanmiuD
                              dolanmiu @jnstnr
                              @jnstnr Yeah, sorry for the complexity! I tried hard to make this as easy as possible
                              But due to the nature of this project, there are a lot of variables. Everyones machine and setup is different etc
                              • J
                                jnstnr @dolanmiu
                                @dolanmiu no worries, I totally understand that it’s quite complicated
                                  smyvy @jnstnr
                                  @jnstnr said in MMM-awesome-alexa:
                                  Hi, what was you fix? Thanks
                                  J M 2 Replies Last reply Reply Quote 0
                                  • J
                                    jnstnr @smyvy
                                    @smyvy I went to this url:
                                    https://sakirtemel.github.io/MMM-alexa/
                                    Put in the Client Id, Device ID & set serial number as 1234. I also added the above url as an allowed return url in the Amazon developer console before I clicked the “Request code” button.
                                      smyvy @jnstnr
                                      This post is deleted!
                                      • J
                                        jnstnr @smyvy
                                        @smyvy the config that’s included in the mmm-awesome-alexa repo wasn’t working for me, so I adjusted it to make it look like other modules in my config. here’s my setup, I was actually missing a comma after the closing }, which fixed the black screen:
                                        module: ‘MMM-awesome-alexa’,
                                        position: “bottom_bar”,
                                        wakeWord: “Alexa”,
                                        clientId: “amzn1…”,
                                        clientSecret: “…”,
                                        deviceId: “magicmirror”,
                                        refreshToken: “…”,
                                        lite: false
                                        • G
                                          g_nandagpl @g_nandagpl
                                          @g_nandagpl please share images of the visualisation, if any.
                                          G dolanmiuD 2 Replies Last reply Reply Quote 0
                                          • G
                                            @g_nandagpl is it possible to send notifications or load modules through voice?
                                            • 12
                                            • 13
                                            • 2 / 13
