    MMM-awesome-alexa
    241 Posts 43 Posters 431.8k Views 47 Watching
    • dolanmiuD Offline
      dolanmiu @g_nandagpl
      @g_nandagpl Visualization is now done! It looks like a talking/breathing circle, kind of like cortana.
      G 1 Reply Last reply Reply Quote 1
      • G Offline
        g_nandagpl @dolanmiu
        @dolanmiu Thanks for the visualisation.
          smyvy
          Has anyone run into this problem:
          Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v1.4-linux-arm/snowboy.node’
          at Module._resolveFilename (module.js:455:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          Happens when I try to run my mirror with MMM-awesome-alexa.
          Thanks,
          James
          dolanmiuD 1 Reply Last reply Reply Quote 0
          • dolanmiuD Offline
            dolanmiu @smyvy
            @smyvy Yes, its a very common issue, run this:
            npm run electron-rebuild
              smyvy
              Thanks for the speedy reply. Although I have tried this several times and I get
              “sh: 1 electron-rebuild: not found…”
              I’ve started over a couple of times but get the same. Sorry if this is a real NOOB problem.
              • dolanmiuD Offline
                dolanmiu @smyvy
                @smyvy which directory are you running that command on?
                It needs to be in the MMM-awesome-Alexa directory
                That command is most definitely there
                  smyvy
                  Hi, yes inside that directory.
                  I’m going to completely restart and see if it is something I’ve messed up.
                    manojjena78 @smyvy
                    @smyvy
                    I am also getting the above error. @Jnstnt- can you please share the findings… A sample copy would help
                    MKJ
                      manojjena78 @jnstnr
                      @jnstnr ,
                      Hi, Please let me the fix , I am getting this error and nothing is helping out so far…
                      MKJ
                      • H Offline
                        hnperkins @jnstnr
                        @jnstnr said in MMM-awesome-alexa:
                        @cowboysdude just got home and tried it, replaced all " with ’
                        And now I get another error:
                        pi@raspberrypi:~ $ bash auth_code.sh
                        auth_code.sh: line 10: syntax error near unexpected token (' auth_code.sh: line 10: perl -MURI::Escape -ne ‘chomp;print uri_escape($_),’\n’‘’
                        Pretty sure there’s a simple fix for line 10, but haven’t figured it out yet!
                        what was your fix for this? i am currently having this exact issue
                        • E Offline
                          E3V3A
                          @hnperkins That post “seem” wrong as it show’s a “back-tick” (`) or even forward-tick, instead of a single quote (').
                          You need to replace all double-quotes with single quotes, not back-ticks!
                          Unfortunately the single quotes are not rendered clearly, in this forum.
                          # Here is a single-quote:  '
                          # Here is a back-tick:     `
                          # Here is a double-quote:  "
                          But that said, I’m not sure that is the problem.
                          “Everything I do (here) is for free – altruism is the way!”
                          MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
                            ruhulayaan
                            It doesnt work with ifttt. Whenever i try to send the command, it gives a response “i dont see any ifttt trigger” . But from alexa app on my android it works normally with the same account, i used to generate my token.
                            • dolanmiuD Offline
                              dolanmiu
                              Documentation website up:
                              https://awesome-alexa.js.org
                              Has detailed install instructions and on how to get past snowboy issues
                                bast.
                                Hey there, I’m totally new to this topic.
                                I hope you understand my English and my problem.
                                So my Mirror is already working but when i’m adding the module Awesome Alexa my weather module is loading in the middle of the screen instead of Top_right. It doesn’t matter if i change all positions, every time Weather is in the middle.
                                When i delete the alexa module, weather is back in the original position.
                                Can somebody help me with this problem?
                                thank you a lot…
                                • C Offline
                                  Canterrain
                                  Trying to finish setup of the module.
                                  I’m in the helper config, and when I get to the point of supplying a return URL I enter:
                                  https://localhost:3000/authresponse
                                  But terminal tells me that’s an invalid URL.
                                  I’ve put https://localhost:3000/authresponse as my return URL and https://localhost:3000/ as my authorized URL on the Amazon developer site. What I am I doing wrong here?
                                  • Cr4z33C Offline
                                    Cr4z33
                                    I am struggling since 4 hours getting this module to work. 😩
                                    When I say ‘Alexa’ the module seems to wake up, but then after ie a question nothing happens.
                                    There’s no evidence of errors when running MM by npm start.
                                    All the setup went fine so I am out of ideas now…
                                      sdetweil @Cr4z33
                                      @Cr4z33 how does the module play audio? I had an alexa module that used mpg321, which wasn’t installed… so it never made any sound
                                      looks like the awesome alex debug says to test play with
                                      omxplayer -o alsa myAudioFile.mp3
                                      https://github.com/dolanmiu/MMM-awesome-alexa/blob/master/docs/audio-setup.md
                                      now that the author has one lined the source, it is hard to help as much…
                                      • Cr4z33C Offline
                                        Cr4z33 @sdetweil
                                        @sdetweil said in MMM-awesome-alexa:
                                        I actually didn’t check that part yet because every other module using sound (ie. MMM-AssistantMk2, MMM-Spotify, etc.) is already working perfectly.
                                        Also I see there’s no option in the module to set the audio output so… :man_shrugging_medium_skin_tone:
                                          sdetweil @Cr4z33
                                          @Cr4z33 said in MMM-awesome-alexa:
                                          yes, doesn’t mean anything… every module can use their own methods to make sound…
                                          let us know if/when u get there
                                          Cr4z33C 2 Replies Last reply Reply Quote 0
                                          • Cr4z33C Offline
                                            Cr4z33 @sdetweil
                                            @sdetweil sure.
                                            I might have some spare time later today and I definitely need a working Alexa module ASAP.
                                            • 12
                                            • 13
                                            • 3 / 13
