    MMM-Globe
    15 Posts 4 Posters 7.7k Views 4 Watching
    • E Offline
      Eunanibus Module Developer
      MMM-Globe
      Description
      The Magic Mirror Globe (MMM-Globe) Module is a utility module that displays a live rotating globe comprised of hex-shapes. The module can be configured to show default destinations, or you can customise it to highlight locations special to you. You can also adjust the size of the globe itself.
      Screenshots
      alt text
      alt text
      Download
      [card:Eunanibus/MMM-Globe]
      Version
      • Initial Commit. Globe stable. ReadMe Added.
        Artech
        This post is deleted!
          Artech
          @Eunanibus first of all, i want to thank you for this great module. But i have a problem with . when i try to put it in my config.js nothing happend on my mirror may be i have a wrong config so if you or another can help me it we be really good
          • qu1queQ Offline
            qu1que Project Sponsor
            Same goes for me. I have several modules installed and also the MMM-Pages module so that different modules are displayed on each page, but I have not been able to get the MMM-Globe to display.
            I have also tried to add it only in the config.js.sample and I can’t make this module to be displayed, only the default modules.
            Any idea?
            Thanks, Quique
            • qu1queQ Offline
              I’ve just seen this information about this module on a raspberry pi:
              …I do not recommend using this module if your Mirror uses a Raspberry Pi…
              https://forum.magicmirror.builders/topic/2553/mmm-globe?page=1
              Maybe that’s my problem, I suppose.
                sdetweil @qu1que
                @qu1que hm, I installed the module, cut/pasted the sample config.js entry from the readme, added
                my location and started mirror… works perfect, altho it stomps on everything around it…
                it rotates the globe, and I find it odd that the Antarctica region rotates opposite of the globe rotation
                (globe rotates from left toward the right, while Antarctica rotates to the left)
                qu1queQ 1 Reply Last reply Reply Quote 0
                • qu1queQ Offline
                  qu1que Project Sponsor @sdetweil
                  That test was made on a raspberry pi?
                    sdetweil @qu1que
                    @qu1que yes… pi4.
                    I have a pi3 and pi 0 I can try on too…
                    • qu1queQ Offline
                      I have try it on a 3B+ but no image of the Globe showed
                        sdetweil @qu1que
                        @qu1que u need to enable the opengl driver…
                        run raspi-config from the commandline,
                        Advanced Options (7),
                        GL Driver (A7),
                        OpenGL desktop driver with full KMS (G3)
                        the module doesn’t list this as a requirement
                        qu1queQ A 2 Replies Last reply Reply Quote 1
                        • qu1queQ Offline
                          Ok, I’ll try it and tell here my results. Thanks!
                          S 1 Reply Last reply Reply Quote -1
                            sdetweil @qu1que
                            @qu1que it failed for me til I enabled the driver…
                            I saw the failure in the developers window, console view
                            • qu1queQ Offline
                              Cool! Now is working!!
                                Artech @sdetweil
                                @sdetweil i try it goes well but it stop others modules
                                  sdetweil @Artech
                                  @Artech it takes a lot of processor power… and covers other modules
