    MMM-MyCommute
    286 Posts 80 Posters 703.4k Views 77 Watching
      Aries1984 Module Developer
      @robiv8 yeah it does work for me perfectly. Can send you my latest config if you want?
        robiv8
        Au das wäre sehr nett :kissing_face:
        • L Offline
          lolobyte @Aries1984
          @aries1984
          Bitte mir dann auch wenn moglich.
          • K Offline
            keyun21
            Newbie here I guess i have to pay for Google API service right? without that this module not going to work correct?
            • BKeyportB Offline
              BKeyport Module Developer @keyun21
              @keyun21 You have to set up a pay account, including a credit card, but they give you a specific number of free accesses, and if you keep the module to a timeframe that you’d normally look at it, you’d have a hard time exceeding those uses.
              • K Offline
                keyun21 @BKeyport
                @bkeyport said in MMM-MyCommute:
                Thanks a lot I will look into to see how many I can get free and how to set up module to run specific times?
                  Hi everybody,
                  sorry for the late reply. Haven’t been here much in the last couple of weeks. Here’s my config:
                          module: 'MMM-MyCommute',
                          position: 'bottom_right',
                          header: 'Traffic',
                          classes: 'default everyone',
                              apikey: 'your API Key',
                              origin: 'Marienplatz 1, 80331 München',
                              startTime: '05:00',
                              endTime: '10:00',
                              hideDays: [0, 6],
                              destinations: [
                                      destination: 'Belgradstraße 13, 80796 München',
                                      label: 'Good Food',
                                      mode: 'driving',
                                      color: '#82E5AA'
                    seanluse41
                    Can this module support Japanese addresses?
                    The default config and values work for me, but putting in Japanese addresses returns loading… forever.
                    • T Offline
                      thoeng
                      This is great and very practical module! Everything is working on me but i would like to remain below USD200 (40K calls)/mo API call request. This means staying below 1.3K calls/day
                      However, after installed I can see 570+ request call in 2 hours on Google API dashboard. This is despite setting pollFrequency: 1200000 (20mins interval) on MM config.
                      Any help please?
                      I 1 Reply Last reply Reply Quote 1
                      • C Offline
                        charp07
                        MM is only loading the “loading…” text for this module. All my other modules are showing right. I am getting request on the Google API Console under the Directions API. So I believe that I must have the module installed correctly. Does anyone know why this would be happening?
                        • C Offline
                          charp07
                          			apikey: 'my api key from google',
                          			origin: '65 Front St W, Toronto, ON M5J 1E6',
                          			startTime: '00:00',
                          			endTime: '23:59',
                          			hideDays: [0,6],
                          			destinations: [
                          				destination: '14 Duncan St Toronto, ON M5H 3G8',
                          				label: 'Air Canada Centre',
                          				mode: 'walking',
                          				color: '#82E5AA'
                            sdetweil
                            in the MagicMirror folder do
                            npm check:config
                            fix 1st error, repeat
                            I think it is the comma after the only destination
                            				color: '#82E5AA'
                            loading …
                            is the default message many modules put up while getting their data
                            but it failed to get the data
                            so, this means there was an internal error in the module code
                            open the developers window
                            (either npm start dev, or use ctrl-shift-i when mirror is running)
                            select the console tab, and scroll up to locate any errors, usually red text
                            C 3 Replies Last reply Reply Quote 1
                            • C Offline
                              charp07 @sdetweil
                              This post is deleted!
                              • C Offline
                                charp07 @sdetweil
                                @sdetweil okay, I’m new but the check:config command is not valid. So tried npm config and it brought up 10 errors.
                                Usage:
                                Npm config set
                                Npm config get …
                                Etc
                                Etc…
                                What does this mean?
                                • C Offline
                                  charp07 @sdetweil
                                  @sdetweil also added comma to that location with no success. Then moved to behind bracket and nothing there either.
                                    sdetweil @charp07
                                    @charp07 sorry, I get that command backwards
                                    npm config:check
                                    • I Offline
                                      interman @thoeng
                                      @thoeng I ran into the same problem. there a few things you can do.
                                      1. Set the time that the module comes on and goes off. For example, I set my mine from 5:00 am to 8:00 am.
                                        startTime and endTime
                                      2. Hide the module on weekends. Mine does not come up on the weekends. hideDays
                                      3. Change how many times it goes to google with a request. pollFrequency
                                      4. add a cheap motion sensor to turn the display on and off (getting one now).
                                      Hope that helps.
                                      Dn
                                      • C Offline
                                        charp07
                                        I swapped to a newer branch of “MMM-MyCommute”. After install, it booted up on the first try. Happy that it is now working. Thanks to all the authors of this module.
                                          JRB1988
                                          Will this module still be updating in the background during the hidden times? With the Google API, I wouldn’t want it updating when I am not needing it. Thanks!
                                          • T Offline
                                            trawson
                                            Is anyone else having issues with the MyCommute module hiding itself but then not re-appearing.
                                            I have EndTime setup for 8pm and also HideDays on certain days, however, once it hides, it stays hidden. Until I force it to show using the Remote module.
                                            Otherwise, this Module works great, showing all the traffic times as it should.
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
