    MMM-Fortune
    Scheduled Pinned Locked Moved Fun & Games
    14 Posts 4 Posters 10.1k Views 4 Watching
    • Mykle1M
      Description:
      Fortunes exactly as you would find them inside a Fortune Cookie. Words of wisdom first. Then a phrase in English, followed by the phrase in Chinese lettering and the pronunciation. Lastly, lucky lottery numbers. No one has ever won the Powerball Lottery using the numbers from a fortune cookie. Will you be the first? Good luck!
      Examples:
      css file included for coloring and sizing.
      Download:
      [card:mykle1/MMM-Fortune]
      Version 1.0.0
      Reply Quote 3
      • cowboysdudeC
        cowboysdude Module Developer
        Nice job!
        Mykle1M 1 Reply Last reply
        Reply Quote 1
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @cowboysdude
          @cowboysdude
          Thank you, sir.
          Reply Quote 1
          • F
            Fonfon
            Great job! is it possible to translate in a other language ?
            • cowboysdudeC
              I do not believe the api supports other languages.
              • Mykle1M
                @cowboysdude said in MMM-Fortune:
                You are absolutely right. I checked the api and it is only in English.
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @Fonfon
                  @Fonfon said in MMM-Fortune:
                  Thanks. This API is only in English. However, if you can find one in your language I’ll be happy to give it a go.
                  • T
                    TheKyleJohnson90
                    I only see the square blocks where it is supposed to have the Chinese translation.
                    I used the Raspbian Jessie lite; Is there possibly a dependency that this needs that is not included?
                    Reply Quote 1
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @TheKyleJohnson90
                      @TheKyleJohnson90
                      First, thanks for trying out my module.
                      Second, thanks for pointing that out. I neglected to include npm install into the ~/MagicMirror/modules/MMM-Fortune in the installation instructions of the readme.
                      Other than that, the characters are part of the data itself, as you can see.
                      [{"fortune":{"message":"One false move may lose the game.","id":"8"},"lesson":{"english":"English-language books","chinese":"英文书","pronunciation":"Yīngwén shū","id":""},"lotto":{"id":"","numbers":[33,55,18,30,17,10]}}]
                      Hopefully, the dependencies will fix your problem. If it is a problem with jesse lite then I really don’t know how to correct the issue.
                      Let me know how you make out.
                      T 1 Reply Last reply
                      • Mykle1M
                        I just downloaded and re-installed MMM-Fortune just to see what would happen. Before I even installed the dependencies it worked fine, albeit, on my windows dev machine. Installed the dependencies and again, it worked fine. I hope Jessie Lite, or the version of Pi you are using, isn’t the reason for the characters not being displayed.
                        Screenshot from installation WITHOUT dependencies installed
                        • T
                          TheKyleJohnson90 @Mykle1
                          @Mykle1
                          Thanks for the response. I ended up having to install the following
                          sudo apt-get install fonts-font-awesome
                          Then ran through the raspi-config again to set to None as default. Guess the Jessie Lite does not include the font your module needed.
                          Mykle1M 2 Replies Last reply
                          • cowboysdudeC
                            @TheKyleJohnson90 said in MMM-Fortune:
                            fonts-font-awesome
                            That’s interesting… I was also unable to reproduce the issue you had. There must be something different within Raspbian Jessie lite that does this… not really sure but it’s a good catch!!
                            Did you do this in the root "MagicMirror’ or in the MMM-Fortune directory?
                            • Mykle1M
                              So, it’s working now?
                              • Mykle1M
                                I used default fonts from MagicMirror. They should have been included in your MagicMirror installation. shrug
