    MMM-Voice-Control using USB Webcam Mic
    10 Posts 2 Posters 6.1k Views 2 Watching
    • C
      caner
      Hello,
      I tried to use that module with USB webcam’s mic but didnt work. Should i do something to use webcams mic?
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @caner
        @caner said in MMM-Voice-Control using USB Webcam Mic:
        Is your usb webcam compatible with your Pi?
        http://elinux.org/RPi_USB_Webcams
        • C
          caner
          @Mykle1 Its Microsoft Lifecam VX-3000
          • Mykle1M
            It’s been quite a long time since I set up my webcam (Kodak S101) but I was able to use both the cam and the microphone after some fiddling.
            In your terminal, type: alsamixer and that will bring you to this window, where you can manipulate some of your settings by pressing F1 through F6.
            Then from your Pi desktop go to Preferences/Audio Device Settings to reach this window, where you can see more audio info. I don’t recall exactly how I got it to function properly but through process of elimination it finally worked, and is still working to this day
            • C
              caner
              @Mykle1 Ok, i bought an USB microphone. Did it default, but still module isn’t working with mic. I can record a sound and listen it.
              • Mykle1M
                @caner
                I don’t use that particular module. Have you tried my suggestions above?
                C 1 Reply Last reply
                • C
                  caner @Mykle1
                  @Mykle1
                  yeap, i did it. I can record successful. Even i changed USB mic to default.
                  • Mykle1M
                    @caner
                    Then, hopefully, someone else that uses that module will step in here and help you out
                    • C
                      caner @Mykle1
                      @Mykle1 thanks :/
                      • Mykle1M
                        @caner
                        Your audio preferences should NOT look like this, if they do.
