    [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras
    602 Posts 67 Posters 2.1m Views 68 Watching
      djuscha
      Hello
      I have two same hikvision cameras with the same settings so my config looks like.
          module: "MMM-RTSPStream",
          position: "bottom_bar",
              autoStart: true,
              rotateStreams: false,
              rotateStreamTimeout: 10,
              moduleWidth: 1152,
              moduleHeight: 400,
              localPlayer: 'omxplayer',
              remotePlayer: 'none',
              showSnapWhenPaused: false,
              remoteSnaps: true,
      		moduleOffset:{ top: 32, left: 32 },
              stream1: {
                  url: 'rtsp://******:********@192.***.178.160/Streaming/Channels/102',
                  frameRate: 'undefined',
                  snapshotUrl: 'rtsp://******:*******@192.***.178.160/Streaming/Channels/2/picture',
                  snapshotType: 'url',
                  snapshotRefresh: 10,
                  width: 480,
                  height: 300,
              stream2: {
                  url: 'rtsp://****:*******@192.***.178.170/Streaming/Channels/102',
                  snapshotUrl: 'rtsp://****:*******@192.***.178.170/Streaming/Channels/2/picture',
                  width: 480,
                  height: 300,
      The Problem is that one camara is showing a Picture and the second once does not Show any Picture on the screen.
      What am I doing wrong?
        shbatm Module Developer @djuscha
        @djuscha If you switch the order, does the opposite one show up? You may need to change the CPU/GPU memory split in your Pi – sudo raspi-config find the “Memory Split” option and increase from 64 to 128.
          djuscha
          When I switch the order I see the picture from the other camera.
          with change from the “Memory Split” I see no Change :(
            @djuscha Try 256, and make sure you restart the Pi after each adjustment.
            Also, please check the MM logs and post if you see any errors. You should be seeing two calls to start omxplayer. You can also do pm2 status to make sure both streams are running.
              djuscha
              @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
              pm2 Status
              pi@raspberrypi:~ $ pm2 status
              │ Name        │ id │ mode │ status │ ↺       │ cpu │ memory │
              │ mm          │ 0  │ N/A  │ fork   │ online  │ 0   │ 0%     │ 2.6 MB   │
              │ omx_stream1 │ 1  │ N/A  │ fork   │ stopped │ 0   │ 0%     │ 0 B      │
              │ omx_stream2 │ 2  │ N/A  │ fork   │ online  │ 0   │ 0%     │ 2.7 MB   │
              /home/pi/.npm/_logs/2018-12-25T13_58_40_969Z-debug.log
              1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
              2 info using npm@6.4.1
              3 info using node@v10.14.2
              5 info lifecycle magicmirror@2.5.0~prestart: magicmirror@2.5.0
              6 info lifecycle magicmirror@2.5.0~start: magicmirror@2.5.0
              7 verbose lifecycle magicmirror@2.5.0~start: unsafe-perm in lifecycle true
              8 verbose lifecycle magicmirror@2.5.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
              9 verbose lifecycle magicmirror@2.5.0~start: CWD: /home/pi/MagicMirror
              10 silly lifecycle magicmirror@2.5.0~start: Args: [ '-c', 'sh run-start.sh' ]
              11 silly lifecycle magicmirror@2.5.0~start: Returned: code: 1  signal: null
              12 info lifecycle magicmirror@2.5.0~start: Failed to exec start script
              13 verbose stack Error: magicmirror@2.5.0 start: `sh run-start.sh`
              13 verbose stack Exit status 1
              13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
              13 verbose stack     at EventEmitter.emit (events.js:182:13)
              13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
              13 verbose stack     at ChildProcess.emit (events.js:182:13)
              13 verbose stack     at maybeClose (internal/child_process.js:962:16)
              13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
              14 verbose pkgid magicmirror@2.5.0
              15 verbose cwd /home/pi/MagicMirror
              16 verbose Linux 4.14.79-v7+
              17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
              18 verbose node v10.14.2
              19 verbose npm  v6.4.1
              20 error code ELIFECYCLE
              21 error errno 1
              22 error magicmirror@2.5.0 start: `sh run-start.sh`
              22 error Exit status 1
              23 error Failed at the magicmirror@2.5.0 start script.
              23 error This is probably not a problem with npm. There is likely additional logging output above.
              24 verbose exit [ 1, true ]
                AxLed Module Developer @evroom
                @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                Next thing I am trying to use MMM-RTSPStream for, is streaming sat-tv from a Dreambox & VU+ receivers.
                I am able to stream a channel using:
                omxplayer --vol -3000 --win “0 0 480 320” --live http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                @evroom
                Maybe my new module is something for you:
                MMM-Dreambox
                Regards
                AxLED
                Cr4z33C evroomE 2 Replies Last reply Reply Quote 0
                • Cr4z33C Offline
                  Cr4z33 @AxLed
                  @axled woah gonna try it now! :thumbs_up_medium-light_skin_tone:
                  • evroomE Offline
                    evroom @AxLed
                    @axled
                    Interesting. Will give it a try.
                    MagicMirror version: 2.33.0
                    Test environment:
                    MagicMirror version: v2.33.0
                      djuscha @shbatm
                      @shbatm
                      @shbatm> Also, please check the MM logs and post if you see any errors. You should be seeing two calls to start omxplayer. You can also do pm2 status to make sure both streams are running.
                      what am I doing wrong?
                        barnosch
                        i have the same problem like @djuscha
                        The second stream does not show up.
                        Can it be a layering issue? Maybe its underneath the other one and just needs to moved down via a
                        or something?
                        As soon as i turn autorotate=on i can see both streams , but the delay between the switch is useless. I see 10 sec the stream1 than for 10 sec black and then for 10sec the other stream2.
                        (if i watch the pm2 status while in rotate mode, it stops the whole stream, thats why it takes forever to load, i guess. shutdowndelay option seems not to change something)
                        I would like to see them in parallel if possible.
                        Any idea or suggestion?
                        • 14
                        • 15
                        • 16
                        • 17
                        • 18
                        • 60
                        • 61
                        • 16 / 61
