    [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras
    602 Posts 67 Posters 2.2m Views 68 Watching
    • evroomE Offline
      evroom @bill22
      @bill22
      And after a little while, does it say stopped?
      And what does
      ps -eaf | grep omxplayer | grep -v grep
      say?
      If pm2 status has a pid, can you do
      pstree -ap < pid >
      Iso < pid > put the pid number from pm2 status.
      MagicMirror version: 2.37.0
        bill22
        @evroom
        omx_stream1 remain online, but the uptime shows 0s only (mm is up for 36 min):
        │ App name    │ id │ version │ mode │ pid   │ status │ restart │ uptime │ cpu │ mem      │ user │ watching │
        │ mm          │ 1  │ N/A     │ fork │ 2976  │ online │ 1       │ 36m    │ 0%  │ 2.3 MB   │ pi   │ disabled │
        │ omx_stream1 │ 0  │ N/A     │ fork │ 10391 │ online │ 1073    │ 0s     │ 0%  │ 2.2 MB   │ pi   │ disabled │
        pi@raspberrypi:~ $ ps -eaf | grep omxplayer | grep -v grep
        pi        1770   820  0 18:17 ?        00:00:04 leafpad /home/pi/omxplayer.log
        pi       13794   781  1 20:05 ?        00:00:00 bash /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
        pi       13823 13794  0 20:05 ?        00:00:00 /usr/bin/omxplayer.bin --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
        pi@raspberrypi:~ $
        tried to use
        pstree -ap < pid >
        but the PID is constantly changing; therefore no output
        evroomE 1 Reply Last reply Reply Quote 0
        • evroomE Offline
          evroom @bill22
          @bill22
          To be honest, I am lost, out of ideas.
          I tried to get the module running myself again, but I cannot even get Bucks Bunny to eat his carrot.
          I would need to setup MM completely new for it to work I guess.
          At the moment you are left with the option of running it stand-alone using avm_stream, like I do
          How where you thinking of using the module should it work?
          Changing channels would still be a challenge, right?
            bill22
            @evroom
            seems to be quite tricky with that stream…
            But thank you for all your efforts so far and again great that we did it at least to run stand alone…!
            You are right, channel changing options seems to be a limitation using avm_stream. I wonder if there is a way of “operating” the avm_stream, at least to switch one particular channel/stream on and off without using the terminal…?
            evroomE 2 Replies Last reply Reply Quote 0
            • evroomE Offline
              evroom @bill22
              @bill22
              I will look if there is a module that can trigger linux commands at will.
              Would be interested in that myself.
                bill22
                @evroom
                if we could find one, it could be probably used to start/stop the stream. On the other hand it could be an option to define several “stand alone streams” and call those individually. Position of the streams could be even offset to each other…Just a thought…
                • evroomE Offline
                  evroom @bill22
                  @bill22
                  Btw, do you “fancy” stuff like Voice Control or Alexa ?
                  I don’t, but those would be modules that could trigger something.
                    bill22
                    @evroom
                    me neither
                    • evroomE Offline
                      evroom @bill22
                      @bill22
                      I used this Sunday to setup a second Pi, whilst watching F1.
                      Used a new SD, installed Debian Buster and Magic Mirror v2.8.0.
                      After I made sure I did not have any errors after rebooting, restarting MM, etc, I setup MMM-RTSPStream.
                      It now works for Bucks Bunny, my IP cam and my SAT receiver.
                      I can even rotate 2 SAT channels.
                      I also tested the little fix with --audio_queue 4and that works to (although I cannot check audio, as I have no speaker).
                      It does not say that this method will work for you (my RTSP was dead as a dodo), but it could be something to consider.
                      I will play a bit with single quotes, double quotes, etc, as that is a potential problem in your URL.
                      And it still leaves the issue with selecting a channel at will, through a trigger.
                        bill22
                        @evroom
                        Hi and sorry for the late response.
                        Sounds pretty good and promising!
                        How do you “rotate” your SAT channels? Does it change based on time (after x seconds)?
                        For me it could be good enough to have a few channels to change, of course better to select from a small list.
                        • evroomE Offline
                          evroom @bill22
                          @bill22
                          In the config part add
                          rotateStreams: true,
                          rotateStreamTimeout: 60,
                          and add 2 or more streams (stream1 and stream2).
                          • BKeyportB Offline
                            BKeyport Module Developer
                            Silly question - is there a way within the RTSP protocal to detect when the camera detects motion, so you can trigger something? What I was thinking is to flash the screen background if the camera sees motion…
                            Thanks!
                            • twosquirrelsT Offline
                              twosquirrels
                              Is there a way to hide the play/pause button? I’m not using a mouse on my mirror so it’s useless. Also, i’s creating its own separate gigantic white box that doesn’t line up with my actual video stream (which I have to force its position using moduleOffset).
                              • BKeyportB Offline
                                The white box is easy to get rid of:
                                In ~/MagicMirror/css/custom.css
                                /* This removes the white border around the RTSP feed(s). */
                                .MMM-RTSPStream .innerWrapper {
                                  border: 0;
                                As far as the play button, I’ve never seen it, so I don’t know how to get rid of it, I don’t use keyboard or mouse on my mirror.
                                FYI, other css that might be useful:
                                /* This shrinks the left and right regions so that RTSPStream don't overlap. */
                                .region.right .module-content,
                                .region.left .module-content {
                                  min-width: 450px;
                                  max-width: 450px;
                                – B
                                twosquirrelsT 1 Reply Last reply Reply Quote 0
                                  twosquirrels @BKeyport
                                  @BKeyport That worked to remove the white box, thanks!
                                  I’m still struggling with getting the module to just show where I want it. I don’t know why it doesn’t just listen to “position” like every other module where I can tell them all to be top_right and they’d all line up in the appropriate order. I’m fighting with moduleOffset entering random numbers to see if I can find a decent spot, but it still overlaps, causes indentation, and is just a mess. Then often times the module will just disappear after being on screen for a couple minutes.
                                  • BKeyportB Offline
                                    Odd - I’m having no problem moving it around - although, if you’re using OMXPlayer, it’s overlaying on top of the screen, it won’t play nice with other modules in the same position…
                                    • O Offline
                                      osnapus
                                      Hello, I’m Peter,
                                      when I add RTSTStream to my MagicMirror, I have a little problem with RTSPStream module.
                                      When display is in normal mode on 27’ screen, everything is ok, picture from Cam is good, normal dimensions etc
                                      https://photos.app.goo.gl/czoZvwryGmqfJRDg6
                                      But when in /boot/config.txt in rpi3 the display_rotation=1, picture form cam is cut like on screen.
                                      https://photos.app.goo.gl/VRycUb7zMw9LQVxh6
                                      Someone could help me with this problem?
                                      Many thanks to You All
                                      Peter
                                      buzzkcB 1 Reply Last reply Reply Quote 0
                                      • buzzkcB Offline
                                        buzzkc @osnapus
                                        @osnapus
                                        Try using the GL driver to rotate…
                                        https://github.com/michmich/magicmirror/wiki/configuring-the-raspberry-pi#enable-the-open-gl-driver-to-decrease-electrons-cpu-usage
                                        I’ll post my config.txt and autostart settings tonight, don’t have access to them right now.
                                        Darren
                                        My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
                                          acimail01
                                          Is it possible to define a stream for playing a local file (e.g. .mp4 or .avi)?
                                            acimail01
                                            works with
                                            			module: "MMM-RTSPStream",
                                            			position: "middle_center",
                                            				autoStart			: true,
                                            				rotateStreams		: false,
                                            				rotateStreamTimeout	: 30,
                                            				moduleWidth			: 354,
                                            				moduleHeight		: 240,
                                            				localPlayer			: 'omxplayer',
                                            				shutdownDelay		: 0,
                                            					stream1: {
                                            						url: 'file:///home/pi/MagicMirror/modules/MMM-RTSPStream/Videos/Feuer.mp4',
                                            but no sound !
                                            in bash console works with: omxplayer -o alsa Feuer.mp4
                                            How to set hdmi sound as default ?
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 30
                                            • 31
                                            • 18 / 31
