    [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras
    602 Posts 67 Posters 2.3m Views 68 Watching
      sdetweil @Number_5
      @Number_5 pm2 stop 0, pm2 stop 1
      just from the commandline…(ctrl-alt-t) . does a video window open on any of these?
      • evroomE Online
        evroom @Number_5
        @Number_5
        Better to stop MM temporarily or disable the module with disabled: true, and a restart of MM.
        Also make sure omx_stream1 process is not running.
        pm2 status
        pm2 stop omx_stream1
        pm2 delete omx_stream1
        pm2 status
        Then do the single quoted command, with logging enabled.
        omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
        MagicMirror version: 2.37.0
        • N Offline
          Number_5
          Hello ,
          1. I started it from the command line
          but no windows opens. or I’m doing something wrong.
          pi@raspberrypi:~/MagicMirror/config $ --genlog
          -bash: --genlog: Kommando nicht gefunden.
          pi@raspberrypi:~/MagicMirror/config $ pm2 status
          │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
          │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 13m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
          │ 1 │ omx_stream1 │ default │ N/A │ fork │ 14967 │ 0s │ 1152 │ online │ 0% │ 2.6mb │ pi │ disabled │
          pi@raspberrypi:~/MagicMirror/config $ pm2 stop omx_stream1
          [PM2] Applying action stopProcessId on app [omx_stream1](ids: 1)
          [PM2] omx_stream1 ✓
          │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 14m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
          │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 1156 │ stopped │ 0% │ 0b │ pi │ disabled │
          pi@raspberrypi:~/MagicMirror/config $ pm2 delete omx_stream1
          [PM2] Applying action deleteProcessId on app [omx_stream1](ids: 1)
          [PM2] omx_stream1 ✓
          [PM2][WARN] Current process list running is not in sync with saved list. omx_stream1 differs. Type ‘pm2 save’ to synchronize.
          pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’
          have a nice day ;)
          evroomE 1 Reply Last reply Reply Quote 0
          • evroomE Online
            evroom @Number_5
            @Number_5
            Could you please post commands and output using the </> tag ?
            So, select the command or output and click on the </> symbol.
            Does the log say anything useful ?
            more omxplayer.log
            Pleas do not post the complete log, unless small.
            30 lines tops.
            head -30 omxplayer.log
            • N Offline
              Number_5
              ok sorry,
              in future output and commands in </>
              thats the logfile
              pi@raspberrypi:~/MagicMirror/config $ more omxplayer.log
              20:14:18 T:1939277143   DEBUG: DllBcm: Using omx system library
              20:14:18 T:1939278613   DEBUG: DllOMX: Using omx system library
              20:14:18 T:1939279243   DEBUG: DllAvFormat: Using libavformat system library
              20:14:18 T:1939280418 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
              20:14:18 T:1939280521 WARNING: DBus connection failed, trying alternate
              20:14:18 T:1939281594   DEBUG: DBus connection succeeded
              20:14:18 T:1939282354   DEBUG: Keyboard: DBus connection succeeded
              20:14:18 T:1939282502   DEBUG: OMXThread::Create - Thread with id -1387290944 started
              20:14:18 T:1939282604   DEBUG: DllAvUtilBase: Using libavutil system library
              20:14:18 T:1939282636   DEBUG: DllAvCodec: Using libavcodec system library
              20:14:18 T:1939282654   DEBUG: DllAvFormat: Using libavformat system library
              20:14:18 T:1939282994   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
              20:14:18 T:1939283372   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
              20:14:18 T:1939283465   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
              20:14:18 T:1939283726   DEBUG: OMXThread::StopThread - Thread stopped
              evroomE 3 Replies Last reply Reply Quote 0
              • evroomE Online
                evroom @Number_5
                @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                ok sorry,
                Nothing to be sorry for; you are learning as you go :-)
                • evroomE Online
                  evroom @Number_5
                  Okay, without getting rid of this error, omxplayer and therefore MMM-RTSPStream using omxplayer will not work for you.
                  I have an Axis cam and there it did not work because to the resolution I used, had to use one of the resolutions that is supported by the cam.
                  Where you able to open
                  http://your-mirror-ip:8080/MMM-RTSPStream/config.html
                  and see the cam there ?
                  Could try ffmpeg, but there I have to pass.
                  What camera are we talking about ?
                  • evroomE Online
                    evroom @Number_5
                    @Number_5
                    Can you try with another port number (554 iso 80) ?
                    omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                    • N Offline
                      Number_5
                      Hello
                      it is a,
                      DAHUA mini-dome Kamera hd-cvi 2 megapixels für indoor/outdoor g ip7. 30 m nightview fixe objektiv 2,8 mm. - AC/DC-Adapter : AC/DC-Adapter 12V 600mA (port 80)
                      also i have a Luna Hd
                      L-KA-2601 1 160,00 160,00
                      IR Bullet-Kamera (HD-CVI), Full HD,
                      if i open
                      http://XXX.xxx,x.xxx:8080/MMM-RTSPStream/config.html
                      I am denied access
                      S evroomE 2 Replies Last reply Reply Quote 0
                        sdetweil @Number_5
                        I am denied access
                        probably have to use the url syntax for userid and password
                        http://admin:roland!?1971@example.com
                        that is going to the magic mirror port
                        so, in the config.js do you have
                        address: “0.0.0.0”,
                        and
                        ipWHiltelist:[],
                        • evroomE Online
                          evroom @Number_5
                          @Number_5
                          Try with port 554, see previous post.
                          And see
                          https://github.com/shbatm/MMM-RTSPStream
                          “Using the module” on the config.html part I was referring to.
                          The IP there, is the MM IP, or localhost, not your cam IP.
                          • evroomE Online
                            evroom @evroom
                            See
                            https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/379
                            • N Offline
                              Number_5
                              Hello
                              I’m just overwhelmed with the syntax.
                              and
                              I’ll try tomorrow and give feedback, thanks for your support
                              • N Offline
                                Number_5 @evroom
                                @evroom
                                thats the result with the port 554
                                pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                                have a nice day ;)
                                pi@raspberrypi:~/MagicMirror/config $ head -30 omxplayer.log
                                21:33:25 T:18446744071806154291   DEBUG: DllBcm: Using omx system library
                                21:33:25 T:18446744071806155602   DEBUG: DllOMX: Using omx system library
                                21:33:25 T:18446744071806156277   DEBUG: DllAvFormat: Using libavformat system library
                                21:33:25 T:18446744071806157458 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
                                21:33:25 T:18446744071806157567 WARNING: DBus connection failed, trying alternate
                                21:33:25 T:18446744071806158687   DEBUG: DBus connection succeeded
                                21:33:25 T:18446744071806159455   DEBUG: Keyboard: DBus connection succeeded
                                21:33:25 T:18446744071806159602   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                21:33:25 T:18446744071806159705   DEBUG: DllAvUtilBase: Using libavutil system library
                                21:33:25 T:18446744071806159738   DEBUG: DllAvCodec: Using libavcodec system library
                                21:33:25 T:18446744071806159756   DEBUG: DllAvFormat: Using libavformat system library
                                21:33:25 T:18446744071806160118   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                                21:33:25 T:18446744071806160518   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                                21:33:25 T:18446744071806179771   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                21:33:25 T:18446744071806180025   DEBUG: OMXThread::StopThread - Thread stopped
                                • N Offline
                                  Number_5
                                  Hello Sam,
                                  with 0.0.0.0.8080/MMM-rtspStream I was able to open the module configurator.
                                  evroom said:
                                  And see
                                  It means the mirror id is not the raspberry pi?
                                  where can I find the mm id?
                                  evroomE S 3 Replies Last reply Reply Quote 0
                                  • evroomE Online
                                    evroom @Number_5
                                    @Number_5
                                    When you run MM locally on your Pi, then your MM IP is your Pi IP.
                                    IP being the IP address, not an id.
                                    When you are able to open the RTSPStream configurator using 0.0.0.0.8080/MMM-rtspStream, then that’s fine.
                                    Continue with step 2 from this post:
                                      sdetweil @Number_5
                                      I don’t see that (mirror id) in the doc for this module
                                      i do see this for testing the camera connection
                                      Testing a camera feed
                                      To test to make sure you have a working url for a camera feed: create a text file with the URL as the first and only line in the file. Save the file as .strm and open the file with a video player like VLC.
                                      unfortuantely I can’t use this module on my dev system as there is no omxplayer…
                                      • evroomE Online
                                        evroom @Number_5
                                        @Number_5
                                        One more thing to try. Just leave out the port altogether.
                                        I use it without specifying the port.
                                        omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0'
                                        • N Offline
                                          Number_5 @sdetweil
                                          @sdetweil said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                          create a text file
                                          Hallo Sam,
                                          1. i have created a textfile wit this line:
                                          rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=1&subtype=0
                                          2 )opend in vlc player direct on raspberry
                                          3) query answered user:admin passwort:roland!?1971
                                          4) saw the stream thats working fine
                                          rtsp://User:Passwort@IP:PORT/cam/realmonitor?channel=1&subtype=0
                                          here i inserted the user, passwort , Ip and port, channel from the camera.
                                          • N Offline
                                            Number_5 @evroom
                                            Hello evroom,
                                            thats the result. Error after debug the file.
                                            pi@raspberrypi:~/MagicMirror $ pm2 stop 1
                                            [PM2] Applying action stopProcessId on app [1](ids: 1)
                                            [PM2] omx_stream1 ✓
                                            │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 0 │ 0 │ 0 │ stopped │ 0% │ 0b │ pi │ disabled │
                                            │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 30 │ stopped │ 0% │ 0b │ pi │ disabled │
                                            pi@raspberrypi:~/MagicMirror $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0'
                                            have a nice day ;)
                                            pi@raspberrypi:~/MagicMirror $ more omxplayer.log
                                            20:10:50 T:18446744072147623537   DEBUG: DllBcm: Using omx system library
                                            20:10:50 T:18446744072147624751   DEBUG: DllOMX: Using omx system library
                                            20:10:50 T:18446744072147625400   DEBUG: DllAvFormat: Using libavformat system library
                                            20:10:50 T:18446744072147626711   DEBUG: DBus connection succeeded
                                            20:10:50 T:18446744072147627442   DEBUG: Keyboard: DBus connection succeeded
                                            20:10:50 T:18446744072147627591   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                            20:10:50 T:18446744072147627696   DEBUG: DllAvUtilBase: Using libavutil system library
                                            20:10:50 T:18446744072147627719   DEBUG: DllAvCodec: Using libavcodec system library
                                            20:10:50 T:18446744072147627738   DEBUG: DllAvFormat: Using libavformat system library
                                            20:10:50 T:18446744072147628026   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0
                                            20:10:50 T:18446744072147628457   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0
                                            20:10:50 T:18446744072147647754   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                            20:10:50 T:18446744072147648005   DEBUG: OMXThread::StopThread - Thread stopped
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 30
                                            • 31
                                            • 21 / 31
