    The mirror that wasn't a mirror
    25 Posts 10 Posters 24.5k Views 10 Watching
      RB14060
      Hey guys! I just made some finishing touches on my “mirror” and wanted to show it off. I’m displaying my setup on a TV that’s mounted to the wall in my office. We use it to display calendar events, email notifications, drive times, and current weather. Unfortunately, due to the amount of business-specific, as well as local area information, I’ve had to remove fairly large chunks of the mirror display. However, the basic idea can still be seen. Check it out!
      Also, here is my config file as well as my auto-start file. I made a slight change to the default startup script, which is the inclusion of when-changed to automatically restart my display when I update configuration. I hope you enjoy!
      A B 2 Replies Last reply Reply Quote 0
        amanzimdwini @RB14060
        @RB14060
        LIKE! Will copy/cannibalize
        Thanks for sharing
        • RedNaxR Offline
          RedNax Module Developer
          Hi!
          EDIT: It probably has to do with vendor.js… The mm prefers the stock wind icons (older set, lacking some icons) over the ones bundled with the module… looking into a fix for that…
          Is that the most recent MMM-Wunderground module? There are a few icons missing from the display…
          There should be a wind-force icon at the top and an umbrella over the percipiation chance/amount:
          paviroP 1 Reply Last reply Reply Quote 0
          • RedNaxR Offline
            Should be fixed now… Just git pull to update the module
              RB14060 @RedNax
              @RedNax Confirmed working! Thanks for the quick fix.
              • paviroP Offline
                paviro @RedNax
                @RedNax shouldn’t we update the vendor ones then? @MichMich?
                We're all stories in the end. Just make it a good one, eh?
                – The Doctor
                • MichMichM Offline
                  MichMich
                  Yeah! Please send me a pull request (including an updated changeling).
                  Thanks in advance!
                    Bu52 @RB14060
                    @RB14060 This is too cool. Good Job.
                      shgmongohh
                      Thanks for charing the config.js. It helps to understand how things works.
                      Sebastian
                        DazDavid
                        Where can i find the Module you are using for your time to arrive somwhere (“MMM-Traffic”)? That is quite cool.
                        • 1 / 3
