    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 122.5k Views 27 Watching
    • K Offline
      kapsolas Module Developer
      Check out my module to pull images from a users Instagram Feed. An API_KEY is required to set this up.
      The images will be pulled will animate and rotate on the mirror.
      The link for it is http://bit.ly/MMM-Instagram
      Thanks!
      N 1 Reply Last reply Reply Quote 3
      • Z Offline
        zombi27
        Wow, thanks for that great module :)
        I had problems getting a api key, but then i found this helpful link, maybe it helps others: http://jelled.com/instagram/access-token
        But i have a little problem with my pictures: on not-square pics i get ugly white bars :/ do you know a way to turn those of / make them black?
          bokifide
          Is there a way to just pull the followers on my instagram profile??
          • P Offline
            potentialpotato
            This is awesome and Instagram has solid steps on how to get the access token. You can only view the feed of an account you have credentials to, unless you register an app and have it approved.
            Another note, does it have to be restarted anytime you want to pull the most recent images? I uploaded new pictures to my IG feed, and let it sit for 12 hours but it didn’t update.
            • K Offline
              kapsolas Module Developer @zombi27
              @zombi27 No idea. I haven’t looked into that. Maybe the code could be updated to check the width and height and dynamically set those when showing the image.
              I won’t have time to work on it for a month so maybe when I return I can try to.
              • K Offline
                kapsolas Module Developer @bokifide
                @bokifide Probably! The API is pretty feature rich. I just wanted to pull my feed images. To pull from your followers, it would need to be coded in.
                I’ll consider it for a future enhancement.
                • K Offline
                  kapsolas Module Developer @potentialpotato
                  @potentialpotato The update to the feed should occur right away. The code is set up to refresh the feed based on the updateInterval value.
                    dr0pb0x
                    anyway to make the images smaller/larger?
                    • K Offline
                      I have not looked into autoresizing an image. It is on my list to get to when I have some time.
                      The image at this point is not being resized, I just take it and display it as it comes from instagram.
                      Videos will auto play when I get to them as well.
                      Thanks!
                      • Y Offline
                        yo-less Module Developer
                        @dr0pb0x , @kapsolas I had a quick look at your code (Not a fan of the bit.ly link) and if you go about displaying the Instagram image this way:
                        	var imageWrapper = document.createElement("img");
                        	imageWrapper.src = tempimpage.photolink;
                        	imageWrapper.style.maxWidth = this.config.instaMaxWidth;
                        	imageWrapper.style.maxHeight = this.config.instaMaxHeight;
                        	imageDisplay.appendChild(imageWrapper);
                        you should be able to specify two parameters instaMaxWidth and instaMaxHeight that the user can change in their config.file so the beginning of your MMM-Instagram.js file would look like this:
                            defaults: {
                                format: 'json',
                                lang: 'en-us',
                                animationSpeed: 1000,
                                updateInterval: 60000, // 10 minutes
                                access_token: '',
                                count: 200,
                                min_timestamp: 0,
                                loadingText: 'Loading...',
                                instaMaxWidth: '100%',
                                instaMaxHeight: '100%'
                        Now, any user of your module could define their own maximum image width and height, either by specifying an absolute figure like ‘300px’ or in relative terms using ‘20%’ or the like. I’ve created a pull request, but I suggest you test my code first as I don’t have an Instagram account or Instagram API key to test it.
                        You can use my fork to do so: https://github.com/yo-less/MMM-Instagram
                        D J 2 Replies Last reply Reply Quote 0
                          dr0pb0x @yo-less
                          @yo-less unfortunately this didn’t work :( I even tried setting it to 1px/1% just to make sure but the images didnt change in size
                          • Y Offline
                            yo-less Module Developer @dr0pb0x
                            @dr0pb0x Have you tried using my forked version here:
                            • Y Offline
                              @dr0pb0x I’ve tried it with my forked version after changing the module to simply retrieve any picture from the internet. It’s working fine.
                              The only limitation is that you can’t set the MaxHeight in relative terms (percentages), other than that, it works as intended as far as I can tell without actually using the API.
                                dr0pb0x @yo-less
                                @yo-less I just had a chance to try it out and it still doesn’t work for me. Could it possibly be Instagram’s API?
                                http://stackoverflow.com/questions/21394100/what-are-the-different-image-size-formats-available-via-instagram-api
                                  Diicken
                                  Is there anyway to display images from my home server? And do someone have an idea how I should write the code?
                                  • Y Offline
                                    @dr0pb0x Anything is possible, but I doubt it. Please have @kapsolas help you with this, as I don’t have any direct way of testing it. As far as I’m concerned my code adjustments should work.
                                    • MichMichM Offline
                                      MichMich
                                      Awesome work! My SO is very pleased with this idea. You might want to add a screenshot to the repo.
                                      • ? Offline
                                        A Former User
                                        Just getting “Loading…”
                                        • cowboysdudeC Offline
                                          cowboysdude Module Developer
                                          This post is deleted!
                                          • ? Offline
                                            A Former User @cowboysdude
                                            @cowboysdude said in MMM-Instagram - Pull and animate photos from Instagram feed:
                                            @kapsolas
                                            Some of us are having issues here… little help please.
                                            Installed per instructions with NPM Install and it isn’t working.
                                            That’s all mine says too… “Loading…”
                                            apparently this is an unsupported module… delete.
                                            • 1 / 5
