    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 122.6k Views 27 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @Guest
      @wjdw87
      cd ~/MagicMirror/modules/MMM-Instagram
      npm install
      • cowboysdudeC Offline
        cowboysdude Module Developer @Guest
        @wjdw87 said in MMM-Instagram - Pull and animate photos from Instagram feed:
        Hmm… from here : https://github.com/kapsolas/MMM-Instagram
        Do you have to install : https://www.npmjs.com/package/request - How?
        To confirm:
        You cloned the module from github - YES
        You generated a token for instragram - YES
        Configured the config.js file, configuration for the module appropriately - YES
        reply
        OH that’s the easy part ;)
        In the terminal window [the one you type in ‘npm start’ to start the mirror]… go to the modules dir then the MMM-Instagram dir
        type in without quotes “npm install”
        Once that’s finished go back to the MagicMirror and start your mirror :)
        • ? Offline
          A Former User
          Many Thanks @cowboysdude , @strawberry-3-141
          I just did a fresh install oof the module, then the dependency.
          Still no luck :( 0_1477600708301_Screenshot 2016-10-28 03.37.16.png
            @wjdw87
            Ok hang in there kid… just about there…
            • ? Offline
              A Former User
              This post is deleted!
              • ? Offline
                A Former User
                I guess for security can change the API key once i’m all up and running :) - many thanks @cowboysdude !
                • K Offline
                  kapsolas Module Developer
                  Just an FYI - You do not want to just post your config to the world.
                  That access token can allow someone to impersonate you now! The config.js contains confidential information for accessing the services our mirrors are using. Refrain from publishing it to the world with out redacting the app ids.
                  ? 1 Reply Last reply Reply Quote 2
                  • ? Offline
                    A Former User @kapsolas
                    @kapsolas said in MMM-Instagram - Pull and animate photos from Instagram feed:
                    Thanks, understood, i intend to replace API keys imemdiately on getting it up and running (at the moment just testing as building), hpe not to offend.
                      That’s ok, that’s not a valid API key… That’s the problem.
                      Let me explain… you do have an API key but what you need is an Access Token… that’s where the problem is.
                      In the config it is asking for the Access token… that’s where we both made a mistake!!! :) It’s all good.
                      We got it! :)
                      Thanks @kapsolas
                      • ? Offline
                        A Former User
                        • ? Offline
                          A Former User
                          @cowboysdude thanks a lot at 4am almost i can sleep ha ha for 2 hours :/
                          Its working, note for others Access Token key is granted here… http://instagram.pixelunion.net/ (when you get to that stage and have created the developer account)0_1477601791572_Screenshot 2016-10-28 03.53.07.png . :
                          layout needs tidying up mind but im sure there are some posts on that :)
                            JUST to clearify for anyone… the module works GREAT!!
                            Create the right thing and it’ll work~
                            ACCESS TOKEN is NOT your API KEY LOL
                            • P Offline
                              Paninpyos
                              Oh, Instagram. How to get all these followers? Sure, I can use services of zen-promo com to find people who are interested in my arts. But may be you can suggest anything?
                              • ? Offline
                                A Former User
                                Just go with the flow, you pick them up, some have their accounts private (i did to stop prying eyes at my life) but since just opened, and tbf its mainly likes and comments, etc, it wastes time that’s all… don’t take seriously (father does with his sunset photos ha ha)…
                                • ? Offline
                                  A Former User
                                  More importantly * at all
                                  Has anyone played with the css ? how advanced is this module? What’ts it coded in ? Function and Design ?
                                  CSS for sure but the rest not looked under the hood, but if anyone can answer i’ll have my in-house dev team do the following for me and share here the source
                                  Generic feed (swipe left / right) through feed (20)
                                  and popup-view of chosen image.
                                  (/uploads/files/1477676198837-instagram-feed-general-resized.jpg)0_1477676379169_Instagram Popup.jpg
                                  Simple enough to get done quickly, once i know what it’s made off, and without having to battle the module code or Magic Mirror core code.
                                  Many thanks and look forward to some answers.
                                  • K Offline
                                    The module is coded in javascript. I started to use some CSS, but did not spend much time on it.
                                    I focused on just pulling the image and flipping them them on a timer .This was the goal of my project and I met it.
                                    If you want to enhance it, then I am sure you can. I would start by looking at the method that displays the image. This is all done using DOM.
                                    • ? Offline
                                      Hi there @kapsolas (not faulting the module at all in the slightest, just trying to get bearing’s (love the module btw), thank’s on the head’s up, Q any particular files that should pay attention too?
                                      Once again thanks.
                                      • K Offline
                                        The file you will want to start to modify is:MMM-Instagram.js
                                        This is where the magic happens. The other file node_helper.js is used to handle the “packaging” of the information that the module uses to render the images. It is that file that reaches out to instagram and retrieves the images.
                                        In MMM-Instagram.js, you will find a method getDOM. This is where the module is rendering the image by modifying the DOM of the page. It is creating a new DIV and setting up an tag.
                                        I believe, you can start from here.
                                        Thanks!
                                          Jeff @yo-less
                                          @yo-less
                                          Thanks for your work, but you had a spelling and ; mistakes on the github upload.
                                          e.g.: imageWrapper.src = tempimpage.photolink;
                                          I got rid of them.
                                          https://github.com/jeffjoe/MMM-Instagram
                                          • L Offline
                                            lucallmon
                                            • 3 / 5
