    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 122.6k Views 27 Watching
    • K Offline
      kapsolas Module Developer
      I just started up my mirror again and the instagram module loaded up correctly.
      Are you use that you have configured the token correctly?
      Additionally, install a tool like firebug on your browser and try to access the mirror using the browser. Then enable firebug. It will have error messages or plugin messages written to the console.
      If the plugin gets images and starts to display them, you will get console entries such as: incrementing the activeItem and refreshing
      • cowboysdudeC Offline
        cowboysdude Module Developer
        Well we’re certainly glad it worked for you…however…
        module: ‘MMM-Instagram’,
        position: ‘top_right’,
        access_token: ‘API_KEY from instagram’,
        count: 200,
        min_timestamp: 0,
        animationSpeed: 2500,
        updateInterval: 12500
        Replaced ‘API_KEY …’
        and followed all directions and it still sits there and says “Loading…”…
        • ? Offline
          A Former User @cowboysdude
          @cowboysdude said in MMM-Instagram - Pull and animate photos from Instagram feed:
          count: 200,
          min_timestamp: 0,
          Same
          • K Offline
            What are you guys seeing in the console log? If you are not anything… then I will have to send you a version of the module with debug comments in it to see where the issue is.
            FYI - I had a similar issue with the Module for Traffic and never solved it. It just sat on Loading…
            cowboysdudeC 1 Reply Last reply Reply Quote 1
              cowboysdude Module Developer @kapsolas
              @kapsolas Well gosh darn it LOL SOLVE IT MAN! Lives are hangin in the balance…
              No I have run it in dev mode and I see or get no errors… so perhaps using a version with debug would be best :)
                OH I stand corrected… here’s an error:
                • ? Offline
                  A Former User
                  How do you get it to show in a browser??
                    cowboysdude Module Developer @Guest
                    @wjdw87 said in MMM-Instagram - Pull and animate photos from Instagram feed:
                    restart your mirror like this:
                    npm start dev
                    • ? Offline
                      A Former User
                      cool thanks
                        @wjdw87 You’re welcome :) NOW if he can solve the problem it’ll work! :)
                        • K Offline
                          Hmm. that tempimpage variable is not found in my code.
                          Did you modify the code at all? The code should look as below. In the error message it shows tempimpage which is not a valid variable. This would cause the script to not work.
                             var tempimage = this.images.photo[this.activeItem];
                              // image
                              var imageLink = document.createElement('div');
                              imageLink.id = "MMM-Instagram-image";
                              imageLink.innerHTML = "<img src='" + tempimage.photolink + "'>";
                              imageDisplay.appendChild(imageLink);
                              wrapper.appendChild(imageDisplay);
                          cowboysdudeC ? 2 Replies Last reply Reply Quote 0
                            @kapsolas no didn’t modify. So what I’ll do is delete what’s there and recopy it since I already did the npm install.
                            Thank you!! 😊
                            • ? Offline
                              A Former User @kapsolas
                              @kapsolas Where is this “added code” that needs to be removed, sorry missed that.
                              • ? Offline
                                A Former User
                                Remove " + tempimage.photolink + “'>”" ?
                                /* global Module */
                                /* Magic Mirror
                                • Module: MMM-Instagram
                                • By Jim Kapsalis https://github.com/kapsolas
                                • MIT Licensed.
                                Module.register(‘MMM-Instagram’, {
                                defaults: {
                                    format: 'json',
                                    lang: 'en-us',
                                    animationSpeed: 1000,
                                    updateInterval: 60000, // 10 minutes
                                    access_token: '',
                                    count: 200,
                                    min_timestamp: 0,
                                    loadingText: 'Loading...'
                                // Define required scripts
                                getScripts: function() {
                                    return ["moment.js"];
                                // Define required translations
                                getTranslations: function() {
                                    return false;
                                // Define start sequence
                                start: function() {
                                    Log.info('Starting module: ' + this.name);
                                    this.data.classes = 'bright medium';
                                    this.loaded = false;
                                    this.images = {};
                                    this.activeItem = 0;
                                    this.url = 'https://api.instagram.com/v1/users/self/media/recent' + this.getParams();
                                    this.grabPhotos();
                                grabPhotos: function() {
                                    // the notifications are not working for some reason... so we won't do anything asynchronously
                                    // we will just make the call to the method to get the object with photo links....
                                    //Log.info('sending socket notification: INSTAGRAM_GET and URL: ' + this.url);
                                    this.sendSocketNotification("INSTAGRAM_GET", this.url);
                                    // this may not be needed... need to think about it.
                                    //setTimeout(this.grabPhotos, this.config.interval, this);
                                getStyles: function() {
                                    return ['instagram.css', 'font-awesome.css'];
                                // Override the dom generator
                                getDom: function() {
                                    var imageDisplay = document.createElement('div'); //support for config.changeColor
                                    if (!this.loaded) {
                                        wrapper.innerHTML = this.config.loadingText;
                                        return wrapper;
                                    // set the first item in the list...
                                    if (this.activeItem >= this.images.photo.length) {
                                    // image
                                    return wrapper;
                                /* scheduleUpdateInterval()
                                 * Schedule visual update.
                                scheduleUpdateInterval: function() {
                                    var self = this;
                                    Log.info("Scheduled update interval set up...");
                                    self.updateDom(self.config.animationSpeed);
                                    setInterval(function() {
                                        Log.info("incrementing the activeItem and refreshing");
                                        self.activeItem++;
                                    }, this.config.updateInterval);
                                 * getParams()
                                 * returns the query string required for the request to flickr to get the
                                 * photo stream of the user requested
                                getParams: function() {
                                    var params = '?';
                                    params += 'count=' + this.config.count;
                                    params += '&min_timestamp=' + this.config.min_timestamp;
                                    params += '&access_token=' + this.config.access_token;
                                    return params;
                                // override socketNotificationReceived
                                    //Log.info('socketNotificationReceived: ' + notification);
                                    if (notification === 'INSTAGRAM_IMAGE_LIST')
                                        //Log.info('received INSTAGRAM_IMAGE_LIST');
                                        this.images = payload;
                                        //Log.info("count: " +  this.images.photo.length);
                                        // we want to update the dom the first time and then schedule next updates
                                        if (!this.loaded) {
                                        this.updateDom(1000);
                                            this.scheduleUpdateInterval();
                                        this.loaded = true;
                                • ? Offline
                                  A Former User
                                  • K Offline
                                    kapsolas Module Developer @Guest
                                    @wjdw87 Based on the code you have provided above, it looks correct. It does not have the tempimpage anywhere.
                                    I did not ask you to delete any code, but somehow the code you were running had tempimage misspelled to tempimpage.
                                    The messages you are showing in the screenshot, are from the core system, but does show that the instagram feed module is running. So there is something else.
                                    To confirm:
                                    1. You cloned the module from github
                                    2. You generated a token for instragram
                                    3. Configured the config.js file, configuration for the module appropriately
                                      I’m all good… I have NO idea where I got that version from but I copied over your original and it fired up…
                                      Thank you!
                                      I believe that version is yoless fork… someone wanted the ability to adjust width and height… which is not a bad idea … ;)
                                      • K Offline
                                        Awesome! Glad to hear we got it all set up! Enjoy the module!
                                          @kapsolas said in MMM-Instagram - Pull and animate photos from Instagram feed:
                                          I really do! Thanks for all your hard work!
                                          • ? Offline
                                            A Former User
                                            Hmm… from here : https://github.com/kapsolas/MMM-Instagram
                                            Do you have to install : https://www.npmjs.com/package/request - How?
                                            To confirm:
                                            You cloned the module from github - YES
                                            You generated a token for instragram - YES
                                            Configured the config.js file, configuration for the module appropriately - YES
                                            reply
                                            strawberry 3.141S cowboysdudeC 2 Replies Last reply Reply Quote 0
                                            • 2 / 5
