    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 874.7k Views 59 Watching
    • M
      mounir @mounir
        sdetweil @mounir
        @mounir is this windows 10, or 11?
        never seen this. installed on windows 11 last week to test
        are u running any other web server apps?
        M 1 Reply Last reply
        • M
          mounir @sdetweil
          @sdetweil i’m in windows 11 but there is no webserver running
            sdetweil @mounir
            @mounir read this
            https://superuser.com/questions/1437780/how-to-fix-listen-eacces-permission-denied-on-any-port/1568476
            u can change the port in MagicMirror\config\config.js
            • M
              mounir @sdetweil
              @sdetweil thank you it works when i’m changing the port in the config.js
                sdetweil
                Note for v ersion 2.18 a little twist
                do
                 npm install --only=prod
                otherwise the developer dependencies will be installed too, and fail, causing electron not to be installed.
                then
                the additional steps are the same
                cd fonts
                npm install
                cd ..\vendor
                npm install
                cd ..
                and edit package.json to change the start line as shown in prior posts
                new info for change of start line in package.json, with node 16
                should be like this (earlier worked with node 14,)
                "start": "node_modules\\.bin\\electron js\\electron.js",
                • P
                  Pearce
                  I went through the installation guide and got this error:
                  $ npm start
                  magicmirror@2.18.0 start
                  DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                  ‘DISPLAY’ is not recognized as an internal or external command,
                  operable program or batch file.
                    sdetweil @Pearce
                    @pearce further up
                    https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
                    • N6NGN
                      N6NG
                      Hi all… Looks like a lot of people are trying this… I’m going for it myself but ran into this problem…
                      When I try to do the
                      git clone https://github.com/MichMich/MagicMirror.git
                      I get the following error.
                      N6NG@Main-Computer-in-Ham-Shack MINGW64 /
                      $ git clone https://github.com/MichMich/MagicMirror.git
                      fatal: could not create work tree dir ‘MagicMirror’: Permission denied
                      Anyone figured out how to change permissions… sudo isn’t recognized yet.
                      Dennis
                        sdetweil @N6NG
                        @n6ng no mingw,
                        just normal windows prompt
                        • swvalentiS
                          swvalenti Project Sponsor
                          @sdetweil I installed MagicMirror no issues on Windows 11 but get undefined on several modules. Here is npm start dev
                          Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'self'". Either the 'unsafe-inline' keyword, a hash ('sha256-+VvWeRXLFRBjsYaMznmUQGiO1Vl3+a2jdYPOrV4EIp8='), or a nonce ('nonce-...') is required to enable inline execution.
                          main.js:481 Initializing MagicMirror.
                          translator.js:128 Loading core translation file: translations/en.json
                          translator.js:146 Loading core translation fallback file: translations/en.json
                          loader.js:184 Load script: modules/default/alert/alert.js
                          module.js:509 Module registered: alert
                          loader.js:155 Bootstrapping module: alert
                          loader.js:184 Load script: modules/default/alert/notificationFx.js
                          loader.js:160 Scripts loaded for: alert
                          loader.js:203 Load stylesheet: vendor/css/font-awesome.css
                          loader.js:203 Load stylesheet: modules/default/alert/./styles/notificationFx.css
                          loader.js:203 Load stylesheet: modules/default/alert/./styles/center.css
                          loader.js:162 Styles loaded for: alert
                          translator.js:107 alert - Load translationfalse: translations/en.json
                          translator.js:107 alert - Load translation fallback: translations/bg.json
                          loader.js:164 Translations loaded for: alert
                          loader.js:184 Load script: modules/default/updatenotification/updatenotification.js
                          module.js:509 Module registered: updatenotification
                          loader.js:155 Bootstrapping module: updatenotification
                          loader.js:160 Scripts loaded for: updatenotification
                          loader.js:203 Load stylesheet: modules/default/updatenotification/updatenotification.css
                          loader.js:162 Styles loaded for: updatenotification
                          loader.js:164 Translations loaded for: updatenotification
                          loader.js:184 Load script: modules/default/clock/clock.js
                          module.js:509 Module registered: clock
                          loader.js:155 Bootstrapping module: clock
                          loader.js:184 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                          loader.js:184 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                          loader.js:184 Load script: vendor/node_modules/suncalc/suncalc.js
                          loader.js:160 Scripts loaded for: clock
                          loader.js:203 Load stylesheet: modules/default/clock/clock_styles.css
                          loader.js:162 Styles loaded for: clock
                          loader.js:164 Translations loaded for: clock
                          loader.js:184 Load script: modules/default/calendar/calendar.js
                          module.js:501 Check MagicMirror version for module 'calendar' - Minimum version:  2.1.0 - Current version: undefined
                          module.js:525 Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                              at cmpVersions (module.js:525)
                              at Function.Module.register (module.js:502)
                              at calendar.js:9
                          loader.js:184 Load script: modules/default/compliments/compliments.js
                          module.js:509 Module registered: compliments
                          loader.js:155 Bootstrapping module: compliments
                          loader.js:244 File already loaded: moment.js
                          loader.js:160 Scripts loaded for: compliments
                          loader.js:162 Styles loaded for: compliments
                          loader.js:164 Translations loaded for: compliments
                          loader.js:184 Load script: modules/default/weather/weather.js
                          module.js:509 Module registered: weather
                          loader.js:155 Bootstrapping module: weather
                          loader.js:184 Load script: modules/default/weather/weatherprovider.js
                          loader.js:184 Load script: modules/default/weather/weatherobject.js
                          loader.js:244 File already loaded: suncalc.js
                          loader.js:184 Load script: modules/default/weather/providers/openweathermap.js
                          loader.js:160 Scripts loaded for: weather
                          loader.js:244 File already loaded: font-awesome.css
                          loader.js:203 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                          loader.js:203 Load stylesheet: modules/default/weather/weather.css
                          loader.js:162 Styles loaded for: weather
                          loader.js:164 Translations loaded for: weather
                          loader.js:184 Load script: modules/MMM-News/MMM-News.js
                          module.js:509 Module registered: MMM-News
                          loader.js:155 Bootstrapping module: MMM-News
                          loader.js:160 Scripts loaded for: MMM-News
                          loader.js:203 Load stylesheet: modules/MMM-News/MMM-News.css
                          loader.js:162 Styles loaded for: MMM-News
                          loader.js:164 Translations loaded for: MMM-News
                          loader.js:203 Load stylesheet: css/custom.css
                          alert.js:47 Starting module: alert
                          updatenotification.js:18 Starting module: updatenotification
                          clock.js:48 Starting module: clock
                          compliments.js:38 Starting module: compliments
                          weatherprovider.js:35 Weather provider: OpenWeatherMap initialized.
                          weatherprovider.js:46 Weather provider: OpenWeatherMap started.
                          main.js:499 All modules started!
                          module.js:94 Template render error: (updatenotification.njk)
                            EvalError: Refused to evaluate a string as JavaScript because 'unsafe-eval' is not an allowed source of script in the following Content Security Policy directive: "script-src 'self'".
                              at Object.n.t (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:2630)
                              at n.i.render (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:37638)
                              at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35783
                              at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35581
                              at o (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35306)
                              at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:64086
                              at XMLHttpRequest.i.onreadystatechange (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:64326)
                          (anonymous) @ module.js:94
                          module.js:94 Template render error: (current.njk)
                          weather.js:149 New weather information available.
                          swvalentiS S 2 Replies Last reply
                          • swvalentiS
                            swvalenti Project Sponsor @swvalenti
                            Lastly, all the modules I have working on another MM are not showing at all just blank. Is this a windows issue?
                            • swvalentiS
                              I scoured the forum and internet but can’t find anything on nunchucks I am guessing that is the issue.
                                sdetweil @swvalenti
                                @swvalenti did u run the extra steps?? (because the postinstall linux syntax fails on windows)
                                cd vendor
                                npm install
                                cd ..
                                cd fonts
                                npm install
                                cd ..
                                now u can start
                                  sdetweil @swvalenti
                                  @swvalenti black screen
                                  see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                                  swvalentiS 1 Reply Last reply
                                  • swvalentiS
                                    swvalenti Project Sponsor @sdetweil
                                    @sdetweil Hey Sam it’s not a black screen just modules show as undefined…like weather, news and components all other modules show
                                      sdetweil @swvalenti
                                      @swvalenti where did u install the extra modules?
                                      same place as on linux
                                      MagicMirror/modules
                                      right??
                                      • swvalentiS
                                        @sdetweil also how do you not install under mingw could that be the issue
                                        S swvalentiS 3 Replies Last reply
                                          sdetweil @swvalenti
                                          @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                          open a Windows cmd.exe session and do all the commands there…
                                          • swvalentiS
                                            there just the default modules in MagicMirror but others don’t show at all like MMM-PGA but fine on a pi
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
