    Error installing
    8 Posts 3 Posters 3.5k Views 3 Watching
    • T Offline
      tunamelt
      I have installed this software on my rpi many times, but after an error I had to reinstall but ran into errors. I tried multiple times to reinstall even after a full format,not quick. I have also followed a tutorial here, even though I haven’t needed to follow any tutorial in the past.
      The following information is from a full format on my sd, using an image from https://www.raspberrypi.org/downloads/raspbian/ full install with pixel.
      I did everything listed in the tutorial, including raspi-config setup, sudo apt-get update and sudo apt-get upgrade as well as sudo rpi-update.
      I’ve made sure nodejs is installed and updated and still I get errors with both the automatic and manual install. I’ve got the screenshots and logs I believe you’ll need, please let me know if you need any more information and thank you, in advance, for your help.
      Files
        Mykle1 Project Sponsor Module Developer @tunamelt
        @tunamelt
        Assuming you’re installing on a Pi 3
        I can tell you that your node and your npm versions need to be updated based on the pictures you provided. It may even be the root of your problem. Personally, I would update those first, then try a manual installation of MM again. There have been some reports of the automatic installer failing without cause. Good luck.
        Yours:
        Mine:
        • T Offline
          tunamelt
          That was it. Thank you so much. I’m new to this and I ran apt-get update and upgrade. I figured I’d be on the latest version but now I know I need to update the repos.
          Thanks a ton
            @tunamelt said in Error installing:
            Fantastic. You’re welcome. Enjoy your mirror. :-)
            • T Offline
              tunamelt @Mykle1
              @Mykle1
              Any idea how I can update my repo list so when I do apt-get update I actually get the latest apps?
              • cowboysdudeC Offline
                cowboysdude Module Developer
                There is a notification module in MM so when an app gets updated it will notify you…
                T 1 Reply Last reply Reply Quote 1
                • T Offline
                  tunamelt @cowboysdude
                  @cowboysdude
                  Sorry, I meant is there any way to update my rpi3 apt repo so when I do apt-get install on, for instance, nodejs and nom, it actually updates to the latest version
                    cowboysdude Module Developer @tunamelt
                    @tunamelt that one I’m not too sure about…perhaps someone else can shed some light on this one :)
