    MMM-CalendarExt
    198 Posts 45 Posters 246.8k Views 45 Watching
      redink
      I just updated this module, and it stopped working. I even tried resting to the simple config from the readme, and nothing is coming up. Where can I see the logs for it to try and fix this?
      • ? Offline
        A Former User @redink
        @redink
        stop pm2 mm then npm start dev in your MM directory root.
        • V Offline
          Vauxdvihl
          @Sean
          Sorry to ask again
          Is there any possibility to increase a little bit the size of the letters?
          I mean the ones showing in the calendar as a “task”?
          thanks
          • ? Offline
            A Former User @Vauxdvihl
            @vauxdvihl
            You can adjust anything in CSS. (It could not be so easy but really funny)
            Or tell me which letters to be increased.
            • V Offline
              Vauxdvihl
              @Sean
              I want to play around with the following values
              Increase / Decrease “FINAL: SEA7 - OAK 6”
              Increase / Decrease “Time (04:05-07:05)”
              I am not a programmer :-)
              Thanks a lot
              • ? Offline
                @vauxdvihl
                Add this into your MagicMirror/css/custom.css file.
                .CALEXT .eventTime {
                  font-size: 120%;
                  line-height:110%;
                .CALEXT .eventContent {
                  font-size: 140%;
                  line-height:110%;
                You can adjust these values with relative % or absolute px (Or many other various things)
                https://www.w3schools.com/cssref/pr_font_font-size.asp
                • V Offline
                  Vauxdvihl
                  @Sean
                  Thanks a lot
                  In custom css file a have the following:
                  div.CALEXT  .event .symbol {
                      order:1;
                      display:block;
                      flex-basis: 30px; // Modify this
                      text-align:center;
                      min-width: 50px; // Modify this
                      font-size: 150%; // Add this
                  div.CALEXT .events .symbol.emoji {
                      font-size: 150%; //Adjust this as your wish. you can use px or %
                  div.CALEXT .events .symbol.font-awesome {
                      font-size: 250%; //Adjust this as your wish. you can use px or %
                  div.CALEXT .tableStyle .eventTime {
                      display:block;
                    font-size: 80%;
                    line-height:110%;
                    font-size: 250%;
                    line-height:110%;
                  The adjustment of time works fine.
                  But not of the initial content.
                  Sorry
                  But can you please help again
                  Thanks a lot
                  • ? Offline
                    @vauxdvihl
                    Because your other CSS rules might override that rule. (Simpler rule name might have lower priority). See this. https://developer.mozilla.org/en-US/docs/Web/CSS/Specificity
                    Anyway, you can use like this;
                     div.CALEXT div.slot div.eventsBoard div.eventContainer div.eventContent {
                       font-size: 250%;
                       line-height:110%;
                    (For more exact rule specificity, I should know whole CSS of your MM, but I believe above code enough)
                    • Y Offline
                      yoey2112
                      Hello @Sean ,
                      Been playing around with this module for a day now (not very savvy with javascript) and I cannot figure out how to increase the size of my Calendar. I’m using weeks (4 count) and position bottom_bar, but I would like it to take up about a third of the bottom (vertical monitor). I know this must be a change in CSS, but I dont know what to do. Any help would be great!
                      -Yoey
                      • ? Offline
                        A Former User @yoey2112
                        @yoey2112
                        Which parts do you want to grow up? More details I need to help. Image could be a help.
                        • Y Offline
                          yoey2112
                          So 2 things really. I’d like the Calendar to take up the entire bottom 3rd of the screen.
                          Second, any suggestions on making it look a little popping?
                          Thanks!
                          justjim1220J 2 Replies Last reply Reply Quote 0
                          • justjim1220J Offline
                            justjim1220 Module Developer @yoey2112
                            @yoey2112
                            May I ask how you were able to show blank events?
                            mine looks like this, all jumbled up and no blanks…
                            Jim Hallock - 1995
                              @yoey2112
                              add the following to your custum.css file
                               #CALEXT_month.tableStyle {
                                max-width:100%;
                                width:100%;
                                background:none;
                              Jim Hallock - 1995
                                @Sean
                                Do you see the calendar posted above by @yoey2112 ?
                                It has blank events instead of collapsed events, I am wanting mine to look like that!
                                But, I can’t figure out how to get it done!
                                Jim Hallock - 1995
                                • Y Offline
                                  yoey2112
                                  @justjim1220 I added that to my custom CSS but its still fairly small, a little bigger though. Is there any way to adjust the height of that location as well?
                                  justjim1220J 1 Reply Last reply Reply Quote 0
                                    @yoey2112
                                    what did you add? I have been looking to do this!
                                    the height is self-adjusting per the font sizes and line heights for the table cells.
                                    May be able to figure out a better way if I had the code you used to get the empty cells to show like that.
                                    Jim Hallock - 1995
                                    • ? Offline
                                      A Former User @justjim1220
                                      @justjim1220
                                      I’ve already sent email for which was talked between us.
                                      @yoey2112
                                      For the whole module width;
                                      .CALEXT .tableStyle {
                                          margin:auto;
                                          max-width: 90%; /*  change to 100%  and if you want, you can add field `width` */
                                      But it will be affected by your MM body width (By default, it has some margin)
                                      • Y Offline
                                        yoey2112
                                        @Sean Can I also adjust the height of the calendar? Example, if I wanted the Calendar to take up the entire bottom half of a Vertical screen?
                                        • ? Offline
                                          @yoey2112
                                          Not easy, but I think possible.
                                          It looks you are using weeks (4 weeks) view, So you can adjust the height of each day slot inweeks or months view with this;
                                          .CALEXT .tableStyle td.slot {
                                            max-height:150px;
                                            height:150px;
                                          Add above codes in your css/custom.css. Adjust the value for your purpose.
                                          Then, in your config,
                                            views: {
                                              weeks: {
                                                overflowHeight:150,
                                          For further details; https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
                                          But there could be performance issue in RPI; https://github.com/eouia/MMM-CalendarExt/wiki/Performance-Issues
                                          • bokifideB Offline
                                            bokifide
                                            Hi! Love this module :) thank you.
                                            Just wondering if there’s a way to omit Saturday and Sunday?
                                            Been poking around and I haven’t been able to figure it out =/
                                            Thanks ahead <3 :)
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 6 / 10
