    Black Screen after Booting Up
    26 Posts 4 Posters 17.2k Views 4 Watching
    • N Offline
      nickymac12
      how would I restore my config file? Sorry I am new to using terminal and don’t really know all the commands.
        j.e.f.f Project Sponsor Module Developer @nickymac12
        @nickymac12 type:
        cd ~/MagicMirror/config (Takes you to the MM config directory)
        mv config.js.bak config.js (Restores your config file)
        pm2 restart mm (restarts MagicMirror)
        • F Offline
          fox @j.e.f.f
          @j.e.f.f said in Black Screen after Booting Up:
          @nickymac12 ok. Try installing the sample config file.
          Type:
          mv config.js config.js.bak (this will back up your existing config)
          cp config.js.sample config.js
          pm2 restart mm
          If magic mirror starts, then you either have a problem with your config or with a module.
          I checked the sample config. No other modules installed only the original. But i still have a blank screen…
          What would you propose?
            j.e.f.f Project Sponsor Module Developer @fox
            @fox I’d suggest backing up your MagicMirror folder (i.e. rename it) and try a fresh install. By renaming it you won’t lose anything.
            • F Offline
              fox @j.e.f.f
              I Think so
              I just punched the
              bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
              in the terminal…
              @j.e.f.f do you know how i can solve the two pm2 sessions after a fresh install?
              With pm2 status i get always two MagicMirror/mm instances.
              If i kill one, it comes back after a few seconds
                Mykle1 Project Sponsor Module Developer @fox
                @fox said in Black Screen after Booting Up:
                type pm2 stop mm or pm2 stop mm.sh in a terminal
