    Electron CPU usage
    247 Posts 46 Posters 641.2k Views 42 Watching
    • W Offline
      wtidwell @Snille
      @Snille
      I’m running a full version. I intend on reinstalling Raspian lite when I have some free time if I can’t troubleshoot it until then.
      When I was installing electron, I tried to install it globally with the -g command like it suggested in the electron readme. However it said I didn’t have permission and I tried to repeat it with sudo and it still said the same thing. Not sure if that means anything significant. I did get it to install non globally with no errors but I dunno if that may be my problem.
      • SnilleS Offline
        Snille Module Developer
        @wtidwell Nah, I’m running the “lite” version of Jessie… So it’s not that… I did not do a separate install of electron actually. I used the “install-script” from MM at the beginning… It’s goning to be interesting to see if you get any better results with another SD card…
        If you cant find it, make it and share it
        MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
        • W Offline
          wtidwell @Snille
          @Snille
          Speaking of hardware, and this may be a dumb question, but any chance the mouse and keyboard are causing this performance hitch? I just plugged in the ones on my desk which are the corsair strafe and logitech g600, both more intricate than normal pnp mouse and keyboard…
          • SnilleS Offline
            @wtidwell Nope, I don’t think so. I have not had any keyboard nor mouse connected since I installed it. :)
              Mykle1 Project Sponsor Module Developer @Snille
              @Snille said in Electron CPU usage:
              You can actually get all three on the same “screen”.
              I followed your directions but only one appeared at a time. I’ll try again later if you want me to. Getting ready for work at the moment.
              • SnilleS Offline
                @Mykle1 Don’t worry about it. You provided the information. :) But if you want to do it anyway, do it via SSH instead, you need to have more “screen-space” to fit all the information at the same time. Check my screenshot. The number of columns and rows are much higher. :)
                  A quick google search reveals that the Pi is mainly manufactured in Wales, UK. However, they are also being made in China, and now Japan. I can’t help but wonder if there is some small difference that would affect performance on those made in the UK and those made elsewhere
                  • SnilleS Offline
                    @Mykle1 Lets see…
                    Do (in SSH): cat /proc/cpuinfo
                    Paste the result from hardware and revision… :)
                    Hardware        : BCM2835
                    Revision        : a02082
                    I think it’s the “last” revision that is important.
                    Pi 3 Model B	1GB	a02082 (Sony, UK)
                    Pi 3 Model B	1GB	a22082 (Embest, China)
                    More info about revisions…
                    Mine is from UK it seams. :)
                    Mykle1M 2 Replies Last reply Reply Quote 0
                      Here it is. It appears that mine is also from the UK. How about the other info? Does it match up to yours?
                      processor	: 3
                      model name	: ARMv7 Processor rev 4 (v7l)
                      BogoMIPS	: 76.80
                      Features	: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
                      CPU implementer	: 0x41
                      CPU architecture: 7
                      CPU variant	: 0x0
                      CPU part	: 0xd03
                      CPU revision	: 4
                      Hardware	: BCM2709
                      Revision	: a02082
                      Serial		: 0000000028d2c528
                      pi@Pi3:~ $
                      • SnilleS Offline
                        @Mykle1 Here is my full “list”. :)
                        processor       : 0
                        BogoMIPS        : 76.80
                        CPU architecture: 7
                        CPU variant     : 0x0
                        CPU part        : 0xd03
                        CPU revision    : 4
                        processor       : 1
                        BogoMIPS        : 76.80
                        CPU architecture: 7
                        CPU variant     : 0x0
                        CPU part        : 0xd03
                        CPU revision    : 4
                        processor       : 2
                        BogoMIPS        : 76.80
                        CPU architecture: 7
                        CPU variant     : 0x0
                        CPU part        : 0xd03
                        CPU revision    : 4
                        processor       : 3
                        BogoMIPS        : 76.80
                        CPU architecture: 7
                        CPU variant     : 0x0
                        CPU part        : 0xd03
                        CPU revision    : 4
                        Hardware        : BCM2835
                        Revision        : a02082
                        Serial          : x
                          @Snille
                          The only difference I see:
                          My hardware = BCM2709
                          Your hardware = BCM2835
                          I’m curious to see @wtidwell results
                          W 2 Replies Last reply Reply Quote 0
                          • W Offline
                            wtidwell @Mykle1
                            @Mykle1
                            @Snille
                            I’ll do this as soon as I can, I’m still not home from the day yet but I’ll get to it later this evening.
                            Thank you everyone for your help!
                            • W Offline
                              wtidwell @Mykle1
                              @Mykle1
                              @Snille
                              My hardware is also BCM2835 revision a02082 , just like Snille. I have another micro SD I think floating around somewhere in my house, I’ll try and do a clean install of rapsian stretch lite on it tomorrow and use the auto install script on that and see how that goes. Fingers crossed I just got a crappy SD card or something.
                                Mykle1 Project Sponsor Module Developer @wtidwell
                                @wtidwell said in Electron CPU usage:
                                How did you make out? I’ve been thinking about this issue since you started the topic. I did quite a bit of googling and there are a number of instances where people had trouble (not with MM) with performance, and heat. In many cases, those people determined that their Pi’s were faulty, after much time, frustration and troubleshooting. In those cases, they had their Pi’s replaced and the problem was solved.
                                I hope the new SD solves your problem but I have my doubts about that. Please keep me informed and good luck.
                                • W Offline
                                  wtidwell @Mykle1
                                  @Mykle1
                                  Well I ordered a new pi 3 on Amazon and did a fresh install it’s the same thing all over again. Every time the text changes on magic mirror it maxes out my cpu. And it’s starting to overheat as well and I didn’t even change any overclock settings.
                                  Quite infuriating honestly. I don’t know what I’ll try next.
                                    Oh man, that sucks. I’m sorry to hear that. I’m at a lost here. Really, there is no logical reason for that to happen
                                    • W Offline
                                      wtidwell @Mykle1
                                      @Mykle1
                                      My last ditch effort is to try a new SD card. The card it came with is a SanDisk 32gb card and it’s just a plain black card and I have this otherone which is a SanDisk ultra 32gb card so maybe that does something.
                                      Mykle1M cowboysdudeC 3 Replies Last reply Reply Quote 0
                                        @wtidwell
                                        I am certainly rooting for you! I think there was/is a walk-through on preparing the SD card, formatting and such, although I don’t remember where. It’s been a long time.
                                        The best of luck to you. Please keep me posted
                                        • W Offline
                                          wtidwell @Mykle1
                                          @Mykle1
                                          Just to rule out one more variable: the pi 3 should be fine running at 1080p yes?
                                            Here is my res on an old HP monitor. That’s using the DVI interface. It does not have HDMI.
                                            • 12
                                            • 13
                                            • 2 / 13
