    Motion Detector
    213 Posts 38 Posters 569.3k Views 39 Watching
    • T Offline
      trividar
      Hi guys,
      I have a problem. My MM do not turn on the display in the morning. I is possible that my pi camera is in a kind of sleepmode or standby? I have to restart with pm2 stop mm and start again an than it works fine.
      • cowboysdudeC Offline
        cowboysdude Module Developer @trividar
        @trividar said in Motion Detector:
        Hi guys,
        I have encountered that MANY times… don’t exactly know why myself… It’s not just this module it happens with most of them… I believe once it sleeps long enough the PI doesn’t want to wake up LOL
        • C Offline
          cpramhofer
          Hi Guys,
          had exactly the same problem with mit Raspi NOIR Cam V2.1.
          the sudo modprobe bcm2835-v4l2 command solved my problem.
          maybe you should add this Tipp in your Readme as many people out there have the same problem.
          greets
          Christoph
          • T Offline
            trividar
            Hi Christoph
            Unfortunately it didn’t work for me;o( Today my screen did not turn on. My Pi works and I can connect over ssh but I have to stop and start my MM and thank works again fine. I just think that my camera stop working if there is no motion a long time (during night).
            I got some errors during the night:
              alihallo
              First of all, I also had the problem which could be solved by adding
              @reboot sudo modprobe bcm2835-v4l2
              at the last line of the crontab. Thank you very much!
              It works fine for some hours, but suddenly the monitor does not show up again.
              I cannot see error messages, but the following commands does not get an answer anymore…
              /opt/vc/bin/tvservice -s
              There is no return value anymore, it is just loading forever.
              In the log it looks like this:
              mm-0 monitor :state 0x12000a [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
              mm-0 monitor has been activated
              mm-0 monitor :state 0x120002 [TV is off]
              mm-0 monitor has been deactivated
              mm-0 monitor :
              mm-0 monitor :
              mm-0 monitor :
              As soon as the problem occures, the command
              /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7
              also does not switch the monitor on again.
              It seems that the tvservice command just got a problem after some hours… Any idea how to solve this?
              I need to restart the pi to get the monitor on again, after that everything works fine for some hours…
              Best regards,
              alihallo
              • C Offline
                cpramhofer
                Hi alihallo,
                i have exact the same problem. i also added the @reboot sudo modprobe bcm2835-v4l2 command into my cronetab.
                but once the screen is off for some hours it will not switch on again.
                for me it seems that the RPi 3 is going into some kind of sleepmode if the monitor is switched off for too long.
                kind regards
                Christoph
                cowboysdudeC 1 Reply Last reply Reply Quote 1
                  cowboysdude Module Developer @cpramhofer
                  This post is deleted!
                  • P Offline
                    paphko
                    Just as a side note, I have the same issue that my RasPi screen does not switch on again after a random time. But I am running v1 of the mirror (so not this motion detector module) and I use motion for motion detection. My guess is that this is an issue with the RasPi firmware because it was working fine several months ago (and I was frequently updating RasPi firmware)…
                      I just run a straight cron job with a file called pir.py that runs two other files…
                      monitor_on.sh
                      monitor_off.sh
                      It’s not incorporated into the mirror it runs the entire pi and I’ve had great luck with it! :)
                      • C Offline
                        cpramhofer @cowboysdude
                        hi @cowboysdude ,
                        could you please give me (and maybe others) the detailed instruction how these files look in detail and where those are located?
                        thanks a lot in advance,
                        Christoph
                        • C Offline
                          cpramhofer
                          here is what i have done, actually it works - i will watch it a few days.
                          switch to /bin/
                          cd /
                          cd bin
                          open nano and create a shell script
                          sudo nano monitor_on.sh
                          write the “On” Command in it and save with Ctrl+x
                          /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chat 7
                          open nano and create another shell script
                          sudo nano monitor_off.sh
                          write the “Off” Command in it and save with Ctrl+x
                          /opt/vc/bin/tvservice -o
                          make both shell scripts executable
                          sudo chmod +x monitor_off.sh
                          sudo chmod +x monitor_on.sh
                          open the crontab and add the following at the end
                          switches the monitor off and on every 15 minutes. this is for experimenting, i will look how it works and will set the
                          time up as.
                          15 * * * * sudo /bin/monitor_off.sh
                          15 * * * * sudo /bin/monitor_on.sh
                          @reboot sudo modprobe bcm2835-vl2
                            Well hey Thanks for making that easy… was JUST working on that LOL I’m putting it on github with instructions and the files…
                              https://github.com/cowboysdude/Pir-Sensor
                                Update:
                                Monitor was only partially coming back on this should fix that.
                                • C Offline
                                  chengstark
                                  my monitor won’t turn back on
                                  when I run “npm start dev”, it shows “compare result=Infinity,Infinity;0,0” , seems like it can’t capture any movement
                                  the camera module works outside MagicMirror
                                  when I tried “sudo modprobe bcm2835-v4l2”, it says “modprobe: invalid option – ‘4’”
                                  how can I fix this
                                  • C Offline
                                    cpramhofer
                                    Hi @cowboysdude
                                    thank you for your files and the explanation. what i don´t understand is how this all works together with the “Motion Detector” - i would prefere to use a camera instead of a PIR Sensor but as far as i see i have to install the pir.py file which is calling the on&off files and referring to the PIN with the connected PIR sensor.
                                    is there a way to use the on&off files with the “Motion Detector” Module?
                                    greets
                                    Christoph
                                    • C Offline
                                      cpramhofer
                                      Hi guys
                                      as it looks that it isn´t an MM problem but an Pi Problem…another try:
                                      sudo nano /etc/kbd/config
                                      change the values to zero
                                      BLANK_TIME=0
                                      POWERDOWN_TIME=0
                                      good luck
                                        @cpramhofer There is a module for camera control… cannot remember the name of it but look around here I KNOW there’s one here.
                                        • C Offline
                                          cpramhofer
                                          hi @cowboysdude,
                                          i´m sorry - i thought we are all speaking about the camera based motion detection by @alexyak
                                          https://github.com/alexyak/motiondetector
                                          have a nice sunday!
                                            @cpramhofer No that’s ok… I think this thread is getting mixed between PIR sensor and camera… opps
                                            • 6
                                            • 10
                                            • 11
                                            • 4 / 11
