    MMM-NOAA
    noaa
    10 Posts 5 Posters 8.6k Views 3 Watching
      MagicStarthilfe
      Hi, I have a problem with the MMM-NOAA module. The following error is reported:
      TypeError: Cannot read property ‘observation_location’ of undefined
      at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:26:49)
      at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:186:22)
      at emitTwo (events.js:106:13)
      at Request.emit (events.js:194:7)
      at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1163:10)
      at emitOne (events.js:96:13)
      at Request.emit (events.js:191:7)
      at IncomingMessage. (/home/pi/MagicMirror/node_modules/request/request.js:1085:12)
      at Object.onceWrapper (events.js:293:19)
      at emitNone (events.js:91:20)
      Can someone help me?
      Thank you very much
        barnosch
        did you make a
        “npm install”
        within the MMM-NOAA folder to install all the dependencies?
        API key doublechecked?
        M 3 Replies Last reply Reply Quote 2
          MagicStarthilfe @barnosch
          Had the whole system rebuilt. Maybe I forgot this. I’ll test it this afternoon. I checked API Key several times, everything is OK
            @barnosch Thanks for your tip
              @barnosch
              That was the solution. I had forgotten “npm install” during the new installation. Thank you for your help.
                barnosch
                nice. that was easy ;)
                your welcome.
                • P Offline
                  Peter
                  NOAA suddenly stopped working today.
                  I have 2 RPI’s, on one of them I did the update I saw today.
                  The other one is not updated.
                  Both stopped working.
                  Anyone else with the same problem?
                  Or even better: a sollution?
                  Peter
                    Mykle1 Project Sponsor Module Developer @Peter
                    @Peter
                    It’s working, unless you’re receiving error messages in the terminal or console. In that case, you should post the error messages.
                    You could also try quitting MM and relaunching. Sometimes data can be delayed causing a module to hang.
                    • P Offline
                      Peter @Mykle1
                      @Mykle1 , I restarted MM and even the RPI several times.
                      Suddenly (after dinner) it started working again.
                      Thanks for your help!
                      I am happy again.
                      Peter
                      • cowboysdudeC Offline
                        cowboysdude Module Developer @Peter
                        @Peter Glad you got it working !
