    Modifying Compliments module
    9 Posts 3 Posters 4.6k Views 2 Watching
      acbc18
      So i’ve been working on this for a few weeks now and i’m completely stuck. I tried to change the compliments module in config.js and get an error at the three lines after position. Can anyone figure out what I’m doing wrong? here is my config.js
      /* Magic Mirror Config Sample
      • By Michael Teeuw http://michaelteeuw.nl
      • MIT Licensed.
      • For more information how you can configurate this file
      • See https://github.com/MichMich/MagicMirror#configuration
      var config = {
      address: “localhost”, // Address to listen on, can be:
      // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
      // - “”, “0.0.0.0”, “::” to listen on any interface
      // Default, when address config is left out, is “localhost”
      port: 8080,
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
      language: "en",
      timeFormat: 12,
      units: "imperial",
      		module: "alert",
      		module: "updatenotification",
      		position: "top_bar"
      		module: "clock",
      		position: "top_left"
      		module: "compliments",
      		position: "lower_third",
                          Config: {
                              updateInterval: 30000,
                              compliments: {
      	                       morning:  [
                                         “Good morning love!”,
      	                           “Have a great day!”,
                                         “Hey Sexy!”
                                         afternoon:  [
                                         “Still looking great!”,
                                         “The cats are being bastards again”,
      	                       evening:  [
                                         “How was your day?”,
                                         “You can do anything!”
      		module: "currentweather",
      			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
      			appid: "YOUR_OPENWEATHER_API_KEY"
      		module: "weatherforecast",
      		header: "Weather Forecast",
      			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
      • cowboysdudeC Offline
        cowboysdude Module Developer
        Use a different module for compliments…
        https://github.com/cowboysdude/MMM-NiceThings
        A lot easier to use…
          acbc18 @cowboysdude
          @cowboysdude I’ll give it a shot, thanks!
            This is the config…VERY simple!
            module: ‘MMM-NiceThings’,
            position: ‘lower_third’
            @Mykle1 will show you the errors so if you want you can also fix your config :) He’s good like that!
              Mykle1 Project Sponsor Module Developer @acbc18
              @acbc18 said in Modifying Compliments module:
              Your use of curly quotes
              Should be
              "Good morning love!",
              No more curly quotes, EVER! :^)
              Just so we’re clear, you can’t use them at all so you’ll have to check your entire config for them.
              Find ” and “ Replace with "
              cowboysdudeC A 3 Replies Last reply Reply Quote 1
                cowboysdude Module Developer @Mykle1
                @Mykle1 EVERRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR LOL
                  acbc18 @Mykle1
                  @Mykle1 Thank you. I’m new at this and didn’t notice it but will do from now on.
                    acbc18 @Mykle1
                    @Mykle1 Outside of that though is there any syntax issue with the lines starting with config: { down to compliments: {?
                    Edit: thanks guys turns out I had left out a comma and putting that in fixed it (after changing the quotes).
                      No worries friend. We’ve all been there.
                      Excellent! Those are two things you won’t forget.
                      Enjoy your mirror! :^)
