    After Update to 2.1.3 nothing works anymore
    9 Posts 3 Posters 3.6k Views 3 Watching
    • F Offline
      fischi87
      Hello guys, like i wrote, after update with
      git pull && npm install
      nothing works anymore. i will send you my log:
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@3.10.10
      3 info using node@v6.11.4
      5 info lifecycle magicmirror@2.1.3~prestart: magicmirror@2.1.3
      6 silly lifecycle magicmirror@2.1.3~prestart: no script for prestart, continuing
      7 info lifecycle magicmirror@2.1.3~start: magicmirror@2.1.3
      8 verbose lifecycle magicmirror@2.1.3~start: unsafe-perm in lifecycle true
      9 verbose lifecycle magicmirror@2.1.3~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      10 verbose lifecycle magicmirror@2.1.3~start: CWD: /home/pi/MagicMirror
      11 silly lifecycle magicmirror@2.1.3~start: Args: [ '-c', 'sh run-start.sh' ]
      12 silly lifecycle magicmirror@2.1.3~start: Returned: code: 1  signal: null
      13 info lifecycle magicmirror@2.1.3~start: Failed to exec start script
      14 verbose stack Error: magicmirror@2.1.3 start: `sh run-start.sh`
      14 verbose stack Exit status 1
      14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
      14 verbose stack     at emitTwo (events.js:106:13)
      14 verbose stack     at EventEmitter.emit (events.js:191:7)
      14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
      14 verbose stack     at ChildProcess.emit (events.js:191:7)
      14 verbose stack     at maybeClose (internal/child_process.js:920:16)
      14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
      15 verbose pkgid magicmirror@2.1.3
      16 verbose cwd /home/pi/MagicMirror
      17 error Linux 4.9.35-v7+
      18 error argv "/usr/bin/node" "/usr/bin/npm" "start"
      19 error node v6.11.4
      20 error npm  v3.10.10
      21 error code ELIFECYCLE
      22 error magicmirror@2.1.3 start: `sh run-start.sh`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'.
      23 error Make sure you have the latest version of node.js and npm installed.
      23 error If you do, this is most likely a problem with the magicmirror package,
      23 error not with npm itself.
      23 error Tell the author that this fails on your system:
      23 error     sh run-start.sh
      23 error You can get information on how to open an issue for this project with:
      23 error     npm bugs magicmirror
      23 error Or if that isn't available, you can get their info via:
      23 error     npm owner ls magicmirror
      23 error There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      can anybody help me please?
      greedings
        Mykle1 Project Sponsor Module Developer @fischi87
        @fischi87 said in After Update to 2.1.3 nothing works anymore:
        You could try npm install in the MagicMirror directory. The upgrade may require some new dependencies.
        • F Offline
          fischi87
          sorry i wroted it wrong i meaned
          npm install
          i tried it again but nothing still works.
          when i stop pm2 and start with
          DISPLAY=:0 npm start
          i get no error but i can not load the page on the port.
          what happened after the update of 2.1.3?
          Mykle1M 2 Replies Last reply Reply Quote 0
            Wait, are you running node server only? You didn’t mention that.
            I don’t know. I just work here. :^)
            • F Offline
              fischi87
              What do u mean?
              I Start my mirror with pm2 automatic.
              Befor Update everything works will. I just did
                I’m not sure what you’re asking. Are you trying to view/administer the mirror remotely and you are being refused access?
                Or are you connected directly to the Pi and nothing is loading?
                • F Offline
                  fischi87
                  Good Morning,
                  I Start my pi and normaly i can Go to the local page with ip:8090 but this page dosend work. When i do
                  pm stop all
                  And Start the mirror with
                  DISPLAY:=0 npm start
                  Then it Starts the run Script and load every modules i have but it dosent load the page at ip:8090, i get no awnser.
                  • lavolp3L Offline
                    lavolp3 Module Developer
                    Have you added the following line to your config?
                    var config = {
                            port: 8080,
                            address: "0.0.0.0",
                    (the last one)
                    With newer versions, you apparently need this line for being able to connect to the server side of the mirror.
                    Has been discussed here in some thread.
                    This solved the same problem for me.
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    • F Offline
                      fischi87
                      Yes this is the Solution, thanks a lot. I read it also in a other topic.
