    MMM-SunRiseSet
    Scheduled Pinned Locked Moved Education
    51 Posts 10 Posters 34.8k Views 10 Watching
      Description:
      • More information than you ever wanted to know about the rising and setting of the sun.
      • Animated world map showing day and night for the entire planet
      • Data and image or just the image. (config option)
      Examples:
      MMM-Lunartic - Top
      MMM-SunRiseSet - Bottom
      Download:
      [card:mykle1/MMM-SunRiseSet]
      Version 1.0.1
        Download:
        Version 1.0.2
        Update
        A new config option for an animated earth image that updates to show the approach of day or night.
        git pull for update or install as usual
        Images of new option:
          Due to a number of issues filed on the Github repo for this module I would like to assure those people that this module does, in fact, work as expected. The issue being that the Day/Night animated map was not loading. So, I re-installed the module. It loads without a problem and displays the image as expected. I can only suggest that you delete your current installation of the module and re-install it. Here is a screenshot of the module from just moments ago. The image may take a few seconds to load, so please be patient. :-)
            At my request, our friend on the forum, @cruunnerr, installed MMM-SunRiseSet on his mirror, running Raspbian Stretch Lite and MM 2.2.2. He reports “works like a charm. tried all options. world, map, static…”
            Many thanks to @cruunnerr for testing and confirming his results.
            • V Offline
              Vauxdvihl
              Hi Mykle1,
              thanks a lot for this great module.
              May be you can add some pinhead showing lat / lng.
              And maybe there could be some possibilit of zooming.
              Thanks a lot
              Cheers
                Mykle1 Project Sponsor Module Developer @Vauxdvihl
                @Vauxdvihl said in MMM-SunRiseSet:
                I really don’t have any plans to do anything more with MMM-SunRiseSet. Please feel free to try anything you like with it. I’ll honor any PR’s that you send to the repo. :-)
                You can make the image larger or smaller via config and css. Zooming is quite another matter. Be aware that the images are renderings, not actual satellite imagery.
                Peace
                  Update
                  I am happy to report that the certificate issue with the US Naval Observatory API has been corrected. I don’t know if I had anything to do with the fix but I did keep emailing them and the electron team about updating the certificate stores.
                  MMM-SunRiseSet is now working as intended.
                  I’m very happy now.
                  justjim1220J 1 Reply Last reply Reply Quote 0
                  • justjim1220J Offline
                    justjim1220 Module Developer @Mykle1
                    @mykle1
                    when you asked for others to email them, I did about 5 or 6 times. :winking_face:
                    Jim Hallock - 1995
                      Mykle1 Project Sponsor Module Developer @justjim1220
                      @justjim1220 said in MMM-SunRiseSet:
                      I thank you very much for that. :thumbsup:
                        @mykle1 yep!
                        Jim Hallock - 1995
                          0_1549154963174_Screenshot from 2019-02-02 18-34-15.png -
                          • cowboysdudeC Offline
                            cowboysdude Module Developer
                            Looks really good and I really like it! So I can use either if I’d like? I like the earth as it’s on a black background and it would look cool sitting on my 32" Mirror ;)
                              Mykle1 Project Sponsor Module Developer @cowboysdude
                              @cowboysdude
                              Yes, you can use either image. They both update to show the movement of the sun on the earth.
                                @mykle1 have you ever tried setting the movement to 500ms?
                                its kinda cool, if your device can handle it!
                                I actually tried it with the Earth module…
                                Jim Hallock - 1995
                                  @justjim1220
                                  Yes, I have. I used to run it at 1000ms. It’s pretty bad ass if your graphics can handle it
                                  justjim1220J 1 Reply Last reply Reply Quote 1
                                    @mykle1 when I did it, it was a mistake! But the outcome was cool!
                                    It actually froze my dev machine after about 45 minutes!
                                    Jim Hallock - 1995
                                      @justjim1220
                                      Jimbo is back! :-)
                                        mrdenmark
                                        i can’t to seem to get some images to show, i just get surise/sunset and time of day,if i select static i get the diagram but nothing with world or map
                                        	disabled: false,
                                        	module: "MMM-SunRiseSet",
                                        		lat: "-44.57",      // Your latitude (for the data)
                                        		lng: "168.50",     // Your longitude (for the data)
                                        		image: "world",          // "world" (animation), "map" (animation), "static" (graph)
                                        		imageOnly: "no",       // no = all data, yes = only animated world or map
                                        		dayOrNight: "day",   // "night" approaching, "day" approaching (imageOnly: must be "yes", image: must be "world")
                                        		useHeader: false,      // true if you want a header
                                        		header: "Header",      // useHeader must be true
                                        		maxWidth: "515px",
                                        • V Offline
                                          Vauxdvihl
                                          @Mykle1
                                          Me too
                                          I have the same issue
                                          No images are shown
                                          Can you please help
                                          Thanks a lot
                                            Mykle1 Project Sponsor Module Developer @mrdenmark
                                            @Vauxdvihl
                                            @mrdenmark said in MMM-SunRiseSet:
                                            My apologies.
                                            The API in use for this module, http://api.usno.navy.mil, is down for maintenance. They have set a date of April, 2020 for completion. This also affects MMM-Lunartic but at least I was able to fashion a fix for that one. Not so in this case.
                                            F V 2 Replies Last reply Reply Quote 0
                                            • 1 / 3
