How do I exit full screen after boot up?
5 Posts 4 Posters 19.5k Views 4 Watching
  • 1 Offline
    1uke_
    Hello Forum,
    Background info
    I have search Google for the answer but everything I try isn’t working.
    I have magic mirror boot up to full screen.
    I have only just installed the software and it boots up to a full size blank screen. (I’m not sure if that is what is meant to happen?)
    My Question
    How do I exit out of full screen mode and get back to my Raspbian desktop?
    M 1 Reply Last reply Oct 27, 2017, 9:39 PM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @1uke_
      @1uke_ said in How do I exit full screen after boot up?:
      That is not suppose to happen. It should boot with 4 default modules displaying. Calendar, Clock, Compliments and Newsfeed.
      My Question
      Press your Alt key. This drops down a menu at the top where you can Exit MM, among other things. When you do get to your desktop, copy and paste any errors from your terminal here and we’ll try to get your sorted.
      • V Offline
        vermaravi
        You can try this:
        • after your magic mirror has loaded, press: Ctrl + q. This should kill Magic Mirror app
        • If you are using pm2 to start the app, it will restart after a few seconds
        • when the app has been killed, you can bring up a terminal window and type: pm2 stop MagicMirror
        Hope it helps.
          brandonbrown
          This is on an old thread, but thank you @Mykle1 .
          I used ‘F11’ all of the time to immediately go to a smaller window.
          M 1 Reply Last reply Jun 18, 2019, 12:15 AM Reply Quote 1
            Mykle1 Project Sponsor Module Developer @brandonbrown
            @brandonbrown said in How do I exit full screen after boot up?:
            Hey Brandon, you are very welcome. Also, have a look at this page (it’s short but informative) about the key commands you can use while your mirror is running. Have fun!
            https://forum.magicmirror.builders/topic/5619/how-to-find-and-use-key-commands-in-mm-for-absolute-beginners
