Navigation
    • Search
    console.log in getDom
    Troubleshooting
    • K
      kiki99 last edited by
      Hi Forum 😉
      Is it possible, that console.log and log.Info does not work in getDom? I did not get any Output. Is there a way?
      Many Tanks fort each tip 🙂
      Best regards k.
      strawberry 3.141 1 Reply Last reply Reply Quote 0
      • strawberry 3.141
        strawberry 3.141 Project Sponsor Module Developer @kiki99 last edited by
        @kiki99 where did you check for logs? those ones are in the browser/electron window and not in the terminal as the ones in the nodehelper
        • cowboysdude
          cowboysdude Project Sponsor Module Developer last edited by
          When you do a console log in the developer window it shows up there…
          When you do a console.log in node_helper it shows up in the terminal window that you loaded MM by using npm start…
          Hope that helps.
          • Mykle1
            Mykle1 Project Sponsor Module Developer last edited by
            I’m gonna jump right in here, right after the two geniuses. 🙂
            • K
              Okay, many thanks at first for that.
              But is there a way to get the output from the “console of the browser” when i start it via npm start? In the npm log there is nothing.
              It’s a bigger structure so i can’t simple add it to the wrapper, or can i? ;))
              Best Regards.
              Sean 1 Reply Last reply Reply Quote 0
              • Sean
                Sean Module Developer @kiki99 last edited by
                @kiki99
                I think it might be related with electron. You can pipe whole electron console output to file or others. But I didn’t test. Check this.
                https://github.com/dustinblackman/winston-electron/blob/master/README.md
