    I need help!!!!
    26 Posts 4 Posters 18.3k Views 4 Watching
      danwitz65
      Every time i go to rotate the screen and reboot itll show magi mirror loading then stop and go to the raspbian desktop and i cant get back into magic mirror with out deleting and reinstalling i enter the comand
      Rotate display vertically
      display_rotate=1
      In the config.txt file
      Reboot
      And then does as said above can someone help me
      • tbbearT Offline
        tbbear Module Developer
        hi, so first of all does the screen rotate as u said? And than how did u made MM to start automaticly? Do u use pm or any other stuff? If u dont change your rotation does ur MM work ok?
        Robert the Bear
          danwitz65 @tbbear
          @tbbear said in I need help!!!!:
          No i never even got the screen to rotate at all. Im not sure to be honest i followed a pretty well made tutorial online. Ibtryed using pm2 or whatever bit i couldnt make the mm.sh a file it could execute i guess ehat im wondering is how to get rolling on this.
          What i have so far:
          The pi assembled
          Rasbian desktop installed and functiong
          Downloaded magic mirror a few times and deleted the others and so on
          It comes on in landscape mode i can see the basic set up with the time greeting and news.
          What i wouldnlike to have is:
          The pi boot diectly to MM
          MM to be in portait mode
          And although i know its in tutorials and walkthroughs id like to:
          Change the time to 12 hr
          Add a weather app
          Maybe some custom greeting?
          Make sure i can set the pi to not turn off wifi
          Make sure theres no screen savers or whatever
          All the good stuff to have it function as it should you know.
          If you could help me as to where things go whether it be in terminal, a folder, a file. Anything such as that.
          I just built a retro pi.
          I overclocked it
          Transfered all the roms over network
          Installed kodi
          Put the add ons in kodi
          And customized the displays in roms to run them all real smooth so im no newby to this stuff, also no expert either tho ill admit. Just need a different approach or point me in the right direction.
          Thank you!
          tbbearT 1 Reply Last reply Reply Quote 0
          • tbbearT Offline
            tbbear Module Developer @danwitz65
            @danwitz65 ok, lets fix it step by step:
            1. Rotate the screen (works for all normal displays, not for pi special and touchscreens)
            Open a terminal and login to your pi
            sudo nano /boot/config.txt
            move all the way down to the end of the file
            add the line: display_rotate=3
            Press ctrl + o to save and ctrl + x to exit the file
            Now do a reboot and you should have a screen tilted by the number of your desire:
            0 = 0 degrees (the default value)
            1 = 90 degrees
            2 = 180 degrees
            3 = 270 degrees
            That’s it! Quick and easy.
            Robert the Bear
            D 1 Reply Last reply Reply Quote 3
              danwitz65 @tbbear
              1 = 90 degrees
              2 = 180 degrees
              3 = 270 degrees
              Oh hell thats gotta be my problem there i didnt realize save was ctrl+o i was kust doing x i think. Ill report back once i try it thanks a ton!
              1 Reply Last reply Reply Quote -1
                danwitz65
                Ok sweet got it! Thank you!!
                  danwitz65
                  Oh my god worse problems now…
                  Id tryed editing my wifi auto turn off thing and followed a thing on line that said to delete the contents and type in what they had and now i dont have any internet at all and dont have my original file… do you have the original networks interfaces file…
                    danwitz65
                    Never mind fixed it.
                    Anyways where im at now is trying to get it to auto start when the the powers on ive got pm2 ive tryed making the mm.sh file but that isnt working can i get a hand from the beginning of that process getting it to auto start.
                      Mykle1 Project Sponsor Module Developer @danwitz65
                      @danwitz65
                      https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                        danwitz65
                        I dont understand this command and section
                        Whats a shell script
                        cd ~
                        nano mm.sh
                        Where do you put it how do you get it to work
                        And then id like to set my weather in adams wisconsin how do i do that i got my key or whatever and put it in so it shows up on the mirror but it says new york and i tryed just typing in adams and madison wi and it wouldnt switch over
                        Again thank you for all your help
                          @danwitz65 said in I need help!!!!:
                          I think the default locationID: "5128581", is for New York. You would have to change that to locationID: "5243553", in your config entry. The readMe file for weather tells you to get it at http://openweathermap.org/help/city_list.txt. I looked it up for you, based on Adams, WI.
                          Otherwise, you could put Adams,WI in location (no space) and locationID: "5243553",
                            danwitz65
                            Oh my god thank you so much!
                            Whil i got you hear can you help me through getting magic mirror to boot up automatically. Ive tryed and made the shell script i can run all the commands to get it to run then i try pm2 save and the sudo reboot.
                            The mirror loading screen shows up then goes blank and boots back up to raspbian desktop… its driving me nuts
                              @danwitz65
                              Perhaps you’re not saving the PM2 state correctly. I would only tell you exactly what is written here.
                                danwitz65
                                Yeah idk i follow it step by step but when it loads up it just shows four raspberrys then magic mirror2 “booting up” then the raspbian home highway picture desktop… idk what im doing wrong
                                  @danwitz65
                                  Are you waiting when that happens? There is a delay between the time you see the desktop and when PM2 launches the mirror. How long are you waiting?
                                    danwitz65
                                    Idk it never has launched after a reboot ive had to do it manually in terminal everything’s me so far
                                    Also when you type
                                    chmod +x mm.sh
                                    From that guide is terminal supposed to do something?
                                      @danwitz65
                                      It will make the shell script is executable. I don’t recall if there is any output to confirm. It may simply go back to your directory
                                        danwitz65
                                        Yeah it doesnt confirm back with anything just opens a line for another command.
                                        Also just tryed rebooting and waiting its been 7 mins now and magic mirror hasnt popped up
                                          @danwitz65
                                          Well, it shouldn’t take THAT long. If you run pm2 start mm in the terminal, does it launch the mirror?
                                            danwitz65
                                            Yes it does
                                            Just did it as well to be sure
