    I need help!!!!
    26 Posts 4 Posters 18.6k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @danwitz65
      @danwitz65
      All I can do is suggest you go through the entire process again. Create the script. Make sure it’s not inside your MagicMirror folder, etc . . and follow the instructions precisely. If there is something else going on there then perhaps a fresh install is in order, but that is completely up to you
        danwitz65
        Well thanks a ton for the help im not gonna reinstall the whole thing that would be crazy ill just have to deal with it i guess…
          austin
          Did you run this command?
          pm2 startup
          This will give you a command to run to setup pm2 to start at boot.
            Mykle1 Project Sponsor Module Developer @austin
            @austin
            @danwitz65 stated
            Yeah idk i follow it step by step
              austin
              @Mykle
              The first time I ran this command I thought it was done. I did not realize that it returns a command to run.
              So since I made this mistake I figured I would ask if the command was run and to check for it to return a different command to run.
                @austin
                “pm2 startup”
                “PM2 will now show you a command you need to execute.”
