    MMM-Rest
    resturltemperature
    25 Posts 6 Posters 22.8k Views 7 Watching
    • T Offline
      Tuxdiver
      I just completed my first module: MMM-Rest (https://github.com/Tuxdiver/MMM-Rest)
      It calls a number of URLs and displays the values in a configurable table on the mirror. The URLs must return a single floating point or integer value, which will be formatted to a fixed number of digits and a custom suffix will be appended.
      I use it for displaying temperatures and other environmental values from a running OpenHAB server via its REST API.
      Screenshot
      Please have a look at it and feel free to give me some feedback!
      Best regards,
      Dirk
        balthaz
        Hello,
        In my config it stay in “loading mode” an idea ?
        my config :
        module: ‘MMM-Rest’,
        position: ‘bottom_right’, // This can be any of the regions.
        // Best results in one of the side regions like: top_left
        sections: [
        suffix: ‘°C’,
        digits: 1,
        url: ‘http://www.dirk-melchers.de/echo.php?text=22.54’,
        suffix: ‘%’,
        digits: 1,
        url: ‘http://www.dirk-melchers.de/echo.php?text=59.1’,
        suffix: ‘°C’,
        digits: 1,
        url: ‘http://www.dirk-melchers.de/echo.php?text=23.10’,
        suffix: ‘%’,
        digits: 1,
        url: ‘http://www.dirk-melchers.de/echo.php?text=62.1’,
        suffix: ‘°C’,
        digits: 1,
        url: ‘http://www.dirk-melchers.de/echo.php?text=-19.73’,
        output: [
        [‘Livingroom’,‘@1’,‘@2’],
        [‘Kitchen’,‘@3’,‘@4’],
        [‘Fridge’,‘@5’],
        • T Offline
          Tuxdiver @balthaz
          @balthaz Config looks good. Strange…
          I will add some debugging messages to the code later to make it easier to find the problem.
          • T Offline
            Tuxdiver @Tuxdiver
            @Tuxdiver said in MMM-Rest:
            OK, I added some debugging code. Please pull the current version and set
            debug: true;
            to the modules config section.
            I’m not sure, which is the best way to debug the version on the Raspi, but I think you could simply use a browser and connect to the Raspi. Maybe the console.log messages will be visible somewhere when using the electron app, but I don’t know where…
            strawberry 3.141S B 2 Replies Last reply Reply Quote 0
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @Tuxdiver
              @Tuxdiver you can open the console in electron with cmd+shift+I or start the mirror with npm start dev, then the console will be open from start
                balthaz @Tuxdiver
                @Tuxdiver
                I add debug mode, but where can i find the log ?
                I try a tcpdump, and they arre no connection to the url :
                pi@mirror:~/MagicMirror/modules/MMM-Rest $ sudo tcpdump |grep dirk
                tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
                listening on wlan0, link-type EN10MB (Ethernet), capture size 262144 bytes
                Stay in loading mode
                Thanks in advance
                • T Offline
                  Tuxdiver @balthaz
                  @balthaz Sorry for the delay… The problem is the same-origin-policy of JavaScript: you must not call any other server than the one, where the mirror is running.
                  I will change the module to use a node helper, but that might take some time.
                  T B 2 Replies Last reply Reply Quote 0
                  • T Offline
                    Tuxdiver @Tuxdiver
                    Module is updated on Github. Please try again. Now it uses a node_helper.js to fetch the remote data. Should solve the security “bug” of AJAX…
                      Jopyth Moderator
                      @Tuxdiver What kind of sensors are you using for this internally (your openHAB)?
                      Helpful sticky: How to troubleshoot
                        balthaz
                        Hello,
                        I am currently on vacation, I will try on my return.
                        • 1 / 3
