    MMM-Todoist - Your todoist tasks on your mirror
    76 Posts 37 Posters 117.6k Views 39 Watching
    • C Offline
      Chiumanfu
      Do those two entries have due dates associated? Mine did some weird things until I assigned due dates to each entry… and subsequently added tkotz8105’s fetcher fix.
      • T Offline
        tkotz8621
        @Sunburned I find that sometimes happens as well… some changes I make (deletions, additions, mods) don’t make it to the mirror. I do not know why that is happening and have not looked in any detail on it. When you say that you restart the Mirror at 2 am… is it a system reboot? I do the same and when it all starts back up… the tasks are there and properly sorted.
          Sunburned
          Thanks for the responses everyone.
          Chiumanfu
          Yep the entries all had due dates, and I also did the fetcher fix.
          tkotz8621
          2am is a full system reboot of the raspberry pie that then restarts the mirror.
          • joela85J Offline
            joela85 @Sunburned
            This post is deleted!
              Sunburned
              So finally progress. I noticed that when the mirror was starting i was getting that EADRINUSE :::8080 error. I dug around a bit and removed some old modules that I either didn’t want anymore or decided not to use and flushed the PM2 logs, no more error on loading and todoist is working.
              The only issue now is the same thing that used to happen with wunderlist. If i add items to the list, they get added fine. If i remove them they do not come off. But if I remove something and add something else the removed item will be removed when the new item appears.
                ROMSY
                hey guys,
                just a short question is it possible to just show up the Tasks of Today or the next seven days or does only “One” list in the Module work right now?
                  djsunrise19 @tidus5
                  @tidus5 Looks nice! Could you please share your code? :)
                    Blackmirror
                    Hello,
                    I can’t see my entrys, but for two weeks as was functional.
                    My list is now only empty
                    • T Offline
                      tkotz8621
                      Mine too. I wonder if Todoist API was changed. I was planning to look at it but unfortunately it won’t be until the weekend.
                        Blackmirror
                        I have my make a new api , but it is not working too.
                        • kruemelK Offline
                          kruemel
                            jsp196
                            Has anyone solved this yet? I was unable to get Wunderlist to work (installed both regular and enhanced - would never show more than the heading title) and now I can’t get Todoist to work. All settings are correct - I’ve updated the List ID in the MMM-todoist.js file in addition to the config.js file. I also assigned deadlines to everything just to make sure that wasn’t an issue. Here’s my section of config file:
                            			module: "MMM-Todoist",
                            		position: "top_center",	// This can be any of the regions. Best results in left or right regions.
                            		header: "ToDo List", // This is optional
                            		config: { // See 'Configuration options' for more information.
                                      	accessToken: "XXXXXXXXXX",
                            			maximumEntries: 60,
                            			interval: 60,
                            //			lists: ["XXXXXXXXX"],
                            			fade: false,
                            I’d really like ANY todo list to work on the mirror. I appreciate any help or suggestions. Thanks!
                              jsp196
                              Follow-up question - I’ve been trying to put all the config options in both the MMM-Todoist file and the config.js file (commenting them on and off as needed) but it’s not working. Is there a way for me to find a LOG of what Todoist is responding with so I know if it’s working? I’m a relative beginner but am hoping there’s a place for me to look and diagnose what’s not working.
                              • T Offline
                                tkotz8621 @jsp196
                                @jsp196 A possible reason for your tasks not displaying is if you have any tasks with no due dates, there is a known bug in MMM-Todoist that will not display any of the tasks. I have a fork at https://github.com/tkotz8105/MMM-Todoist that corrects the bug. I hope it solves your issue.
                                  jsp196 @tkotz8621
                                  @tkotz8621 Thanks. I had tried that but I just went through and deleted all the MMM-Todoist files, started over with your fork and now it works.
                                  One other question - if I want to change the color of this module, is the CSS entry .module.MMM-Todoist? And has anyone had any luck with it working in custom.css or does it need to go into main.css?
                                  Thanks!
                                  • L Offline
                                    Lange
                                    Have anyone added a feature where it shows duedate?
                                    • T Offline
                                      tkotz8621 @Lange
                                      @Lange Good idea… I thought about looking to adding it as an option set in config file. It may be a few weeks before I can maybe start to take a look at it.
                                        djsunrise19
                                        I want to extend the module a little bit:
                                        • Project Name as header
                                        • Project color in front of the name / the todos
                                        • reminder icon behind the todo (due date like the discussion above)
                                        I tried a few things (from @tidus5 within the fetcher). But I can’t get it to work. Any hints / ideas?
                                        • T Offline
                                          tidus5 @djsunrise19
                                          @djsunrise19 Hello
                                          i’m on holiday. Can send you the files when i’m back. you need to change the fetcher indeed.
                                          Have a nice day
                                          • T Offline
                                            tidus5
                                            This is my code
                                            it’s based on 2 users (i badly commented the code)
                                            /* Magic Mirror
                                             * Fetcher
                                             * By Michael Teeuw http://michaelteeuw.nl edited for Wunderlist by Paul-Vincent Roll
                                             * Edited again for Todoist by Chris Brooker
                                             * MIT Licensed.
                                            var request = require("request");
                                            /* Fetcher
                                             * Responsible for requesting an update on the set interval and broadcasting the data.
                                             * attribute listID string - ID of the Wunderlist list.
                                             * attribute reloadInterval number - Reload interval in milliseconds.
                                             	function dateDiff(date1, date2){
                                                var diff = {}                           // Initialisation du retour
                                                var tmp = date2 - date1;
                                                tmp = Math.floor(tmp/1000);             // Nombre de secondes entre les 2 dates
                                                diff.sec = tmp % 60;                    // Extraction du nombre de secondes
                                                tmp = Math.floor((tmp-diff.sec)/60);    // Nombre de minutes (partie entière)
                                                diff.min = tmp % 60;                    // Extraction du nombre de minutes
                                                tmp = Math.floor((tmp-diff.min)/60);    // Nombre d'heures (entières)
                                                diff.hour = tmp % 24;                   // Extraction du nombre d'heures
                                                tmp = Math.floor((tmp-diff.hour)/24);   // Nombre de jours restants
                                                diff.day = tmp;
                                                return diff;
                                            var Fetcher = function(listID, reloadInterval, accessToken, clientID) {
                                             var self = this;
                                             if (reloadInterval < 1000) {
                                            	reloadInterval = 1000;
                                             var reloadTimer = null;
                                             var items = [];
                                             var fetchFailedCallback = function() {};
                                             var itemsReceivedCallback = function() {};
                                             /* private methods */
                                             /* fetchTodos()
                                            	* Request the new items.
                                             var fetchTodos = function() {
                                            	clearTimeout(reloadTimer);
                                            	reloadTimer = null;
                                            	request({
                                            		url: "https://todoist.com/API/v7/sync/",
                                            		method: "POST",
                                            		headers: {
                                            			'content-type': 'application/x-www-form-urlencoded',
                                            			'cache-control': 'no-cache'
                                            		form: {
                                            				token: accessToken,
                                            				sync_token: '*',
                                            				resource_types: '["items"]'
                                            	 function(error, response, body) {
                                            		if (!error && response.statusCode == 200) {
                                                     items = [];
                                            		 for (var i = 0; i < JSON.parse(body).items.length; i++) {
                                            			 if (JSON.parse(body).items[i].project_id == listID) {
                                            		donneetableau = JSON.parse(body).items[i];
                                            		onbalance = [];
                                            		icontodo = [];
                                            		assignedname = [];
                                            		datedueretour = [];
                                            		contentretour = [];
                                            		assignedtodoname = [];
                                            		checkedretour = [];
                                            		if (donneetableau.priority == '1') {icontodo ='<i></i> '}
                                            		else if (donneetableau.priority == '2') {icontodo ='<i></i> '}
                                            		else if (donneetableau.priority == '3') {icontodo ='<i></i> '}
                                            		else {icontodo ='<i></i> '}
                                            		if (donneetableau.assigned_by_uid == 'XXXXXXXX') {assignedname ='(XXXXX)'}//TEST  first XXX UID second XXXX yourname
                                            		else if (donneetableau.assigned_by_uid == 'XXXXXXX') {assignedname ='(XXXXXX)'}//TEST  first XXX UID second XXXX yourname
                                            		else {assignedname ='Inconnu'};
                                            		if (donneetableau.due_date_utc)
                                            				date1 = new Date();
                                            				date2 = new Date(donneetableau.due_date_utc);
                                            				diff = dateDiff(date1, date2);
                                            				if (diff.day = '1') {datedueretour += diff.day + 'd <i></i> ';}
                                            				else if (diff.hour >= '1') {datedueretour += diff.hour + 'h <i></i> ';}
                                            				else {datedueretour += diff.min + 'min <i></i> ';};
                                            		else {datedueretour =''};
                                            		contentretour = donneetableau.content;
                                            		if (donneetableau.responsible_uid ) {
                                            		if (donneetableau.responsible_uid == 'XXXXXXX') {
                                            		assignedtodoname ='<i></i> '
                                            		} ////YOUR UID USER
                                            		else if (donneetableau.responsible_uid == 'XXXXXXX') {assignedtodoname ='<i></i> '}
                                            		else {assignedtodoname ='Inconnu'};  // YOUR UID USER
                                            		} else { assignedtodoname ='' };
                                            		checkedretour = donneetableau.checked;
                                            		onbalance +=assignedtodoname + icontodo + datedueretour + contentretour;
                                            		items.push(onbalance);
                                            				//items.split('\n');
                                            				 //priority.push(JSON.parse(body).priority[i].priority);
                                            				 //datedue.push(JSON.parse(body).datedue[i].due_date_utc);
                                            		 self.broadcastItems();
                                            		 scheduleTimer();
                                             /* scheduleTimer()
                                            	* Schedule the timer for the next update.
                                             var scheduleTimer = function() {
                                            	//console.log('Schedule update timer.');
                                            	reloadTimer = setTimeout(function() {
                                            	 fetchTodos();
                                            	}, reloadInterval);
                                             /* public methods */
                                             /* setReloadInterval()
                                            	* Update the reload interval, but only if we need to increase the speed.
                                            	* attribute interval number - Interval for the update in milliseconds.
                                             this.setReloadInterval = function(interval) {
                                            	if (interval > 1000 && interval < reloadInterval) {
                                            	 reloadInterval = interval;
                                             /* startFetch()
                                            	* Initiate fetchTodos();
                                             this.startFetch = function() {
                                            	fetchTodos();
                                             /* broadcastItems()
                                            	* Broadcast the exsisting items.
                                             this.broadcastItems = function() {
                                            	if (items.length
                                            • 3 / 4
