    Need help with making the rasberry pi start up delayed
    8 Posts 3 Posters 3.5k Views 3 Watching
      danwitz65
      Can some give a step by step with the commands you have to enter in terminal to get to the files to edit and everything. Im not fond of code and am basically asking for a step by step dumby guide. Thank you!!!
        Mykle1 Project Sponsor Module Developer @danwitz65
        @danwitz65
        You can’t get the Pi to start up or you want to delay the start up? This is the guide for setting up your Pi and installing MM
        https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
          danwitz65
          I want to delay start up. Because as it sits right now the tv doesnt turn on as fast so the pi boots before i can turn the tv on and i get no picture so id like to make the pi delay 5-10 seconds. So i have time to turn the tv on
            @danwitz65
            Turn the tv on first?
              danwitz65
              Its all plugged in to an fancy three way extension cord so when i plug in the “mirrors” cord it powers the tv and pi.
              But the pi starts to run right away while the tv i have to push the button ive seen people that delay them and ive seen the code but i dont know how to get to where to put it or what commands to run.
                danwitz65
                https://www.raspberrypi.org/documentation/configuration/config-txt/boot.md
                Here the link where ive seen it
                If you scroll down you see the codes but i have nonidea how to command them in terminal. Can you walk me through that
                • dorfman2D Offline
                  dorfman2
                  Did you utilize pm2 as part of your setup? Possibly you could use;
                  pm2 start mm --start-delay {time in milliseconds}
                  *disclaimer, I haven’t tested this.
                    danwitz65
                    I did use pm2 but even with pm2 it dont work right itll start up show magic mirrors loading screen then go to raspbian desktop where i have to enter pmstart mm.sh or whatever and then itll load just fine thats also been a struggle that was never resolved that i have coped with tho however
