    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 723.8k Views 27 Watching
      maxbachmann
      @Mykle1 without cooler I am at stable 77-78 degree I would say that sucks lol
      @justjim1220 Lol just use windows for the stuff it"s made for (I guess like the name already implies it"s for throwing it out of the window) :smiling_face_with_horns:
        Mykle1 Project Sponsor Module Developer @justjim1220
        @justjim1220
        Well, I wish you luck. I tried (half-heartedly) to get MM-voice and Hello Lucy to run under Windows. Once I got comfortable with ubuntu I realized the benefits where MM is concerned
          Mykle1 Project Sponsor Module Developer @maxbachmann
          @maxbachmann said in Hello-Lucy:
          With a simple fan my Pi mirror runs at a constant 43C
            maxbachmann
            @Mykle1 In general the only reason I still use Windows is because Autodesk still does not have linux versions for the CAD software lol
              maxbachmann
              @Mykle1 just took a cooler from a old PCB I had laying around and some thermal compound. saved me 25 degree
                maxbachmann
                Lucy.mp4 auf dem Raspberry Pi
                  @maxbachmann
                  I’m not suggesting that you abandon Windows. I still have my Windows machine, too. I mean where MM is concerned. Do you need to have Autodesk and the CAD software running with MM?
                    Excellent!
                      maxbachmann @Mykle1
                      @mykle1 ah no I mean in general. I wanted to drop windows already for months ;) But since I need the CAD software I can’t lol maybe I will go over to linux and put windows into a VM just for CAD Software
                        maxbachmann
                        Well today I got a pi b+ into my hands and tested it right away. Well sadly there is no improvement at all. The video still runs smooth which I expected, however there is still 83% cpu load while playing it. Will give it a cooler and do not show it a lot of the time anyways so I guess I should be fine anyways
                          @maxbachmann
                          Were you expecting the Pi to perform like a desktop or laptop board? That’s just crazy. ;-)
                            maxbachmann
                            @Mykle1 well your desktop has a gpu but a not a better cpu and ram is not used ;)
                            And yes expected a slightly better performance given the 17% more cpu speed. However I will just stop playing video files in electron which kills my cpu (83%).
                            So I tried I different way to show the video. I used magic mirror like I would normalways but the video I did not show in electron, but opened omxplayer to blend the video in.
                            I tested using top. It shows cpu usage for all cores so don’t wonder about numbers over 100%
                            With the video on electron using a magic mirror module my cpu usage was at stable 250-260%. Using the omxplayer to show the video and showing the rest like I did the first time the CPU usage was different each time. It was always either in the 20% area or in the 150%. So it is a enormous improvement to the first option and makes it definetly possible to play it on a raspberry pi 3b ;)
                              Uhh, you lost me.
                              That is excellent news for those employing Hello-Lucy without the animated gif. Well done!
                                maxbachmann
                                @Mykle1 Yes will create a omxplayer module for my mirror (although I am not sure wether I have the time this month)
                                  Just making sure that Lucy works with MM v2.5.0. Also, tried using a screen capture app instead of my iphone. The screen capture app is not able to share the microphone with Lucy so this video is silent. However, the video seems nicer than a handheld iphone video.
                                  https://youtu.be/h7P_hexqe2g
                                  Or, an older iphone video with audio of voice commands when Lucy was in development months ago.
                                  https://www.youtube.com/watch?v=bKHEXPzVb2A
                                    dazza120 @Mykle1
                                    @mykle1 can you tell me where to makeup the Lucy voice clip, i just want to use a generic greeting for Lucy like your me2.mp3 without the name though lol, if you could help that would be appreciated. Great work on this, love it!
                                      Mykle1 Project Sponsor Module Developer @dazza120
                                      @dazza120
                                      Wow, umm, I don’t recall the exact site I used to make the sound files. There are several online. Try googling “text to mp3”. I used Audacity to add the robotic type sound effect. I made a bunch and, through the help of a friend, randomized them so Lucy doesn’t always say the same thing. Good fun.
                                        Mykle1 Project Sponsor Module Developer @cowboysdude
                                        @cowboysdude said in Hello-Lucy:
                                        https://www.youtube.com/watch?v=1n0pM-7v0pc&feature=youtu.be
                                        Ha. I just watched this again. 11 months ago! Crazy!
                                        • X Offline
                                          Xclasher 0
                                          Hi all. Is there a way to integrate both MMM-pages & MMM-voice (with lucy modification)? I would like to have the MMM-voice to be available at a specific page and trigger the MMM-voice (pages) via commands
                                            Mykle1 Project Sponsor Module Developer @Xclasher 0
                                            @xclasher-0
                                            If you want to use MMM-Pages and MMM-voice then there doesn’t seem to be a need for the Hello-Lucy enhancement. I don’t think using MMM-Pages and MMM-voice will allow you to do individual modules. I think you can only go back a page or forward a page rather than from any page to any other page.
                                            Note: You will have to use @cowboysdude’s fork of MMM-voice with MMM-Pages
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 14
                                            • 15
                                            • 7 / 15
