    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 308.6k Views 54 Watching
    • cruunnerrC Offline
      cruunnerr
      Hey dude,
      sorry for not answering, but i am only rarely here :(
      First i would try to edit the config file:
      sudo nano /boot/config.txt
      try to uncomment “hdmi_force_hotplug=1” and try to uncomment “config_hdmi_boost=4”
      maybe play around with some other settings.
      https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
      Rebooting the pi once a day is not the best solution :/
      But however, if necessary:
      http://www.simsalabim-solutions.net/vademecum/raspberry_pi/setting_up_reboot_cron_job_on_pi
        Rec3ptor @cruunnerr
        @cruunnerr Thanks for the reply, apreciate it. I now have a 5050 LED strip wired up with the mosfets.
        working with the pir script (removed the module as you advised others)
        what method did you use to run pigpiod deamon on startup. i added this in my crontab, guess that will do unless theres a better way.
        @reboot /usr/local/bin/pigpiod
          cruunnerr
          @Rec3ptor
          If u followed the guide i posted, your PIGPIOD installation path should be “/usr/local/bin/pigpiod”
          For autostart when booting u must edit the rc.local. Mine is like this:
          pi@MagicMirror:~ $ cat /etc/rc.local
          #!/bin/sh -e
          # rc.local
          # This script is executed at the end of each multiuser runlevel.
          # Make sure that the script will "exit 0" on success or any other
          # value on error.
          # In order to enable or disable this script just change the execution
          # bits.
          # By default this script does nothing.
          # Print the IP address
          _IP=$(hostname -I) || true
          if [ "$_IP" ]; then
            printf "My IP address is %s\n" "$_IP"
          fi
          iwconfig wlan0 power off &
          sleep 5 &
          sleep 10 &
          /usr/bin/python /home/pi/pir.py &
          exit 0
          So enter this via ssh:
          sudo nano /etc/rc.local
          and just put this into the file:
            Mykle1 Project Sponsor Module Developer @cruunnerr
            @cruunnerr
            My nickname for you:
            King Cron
            :thumbsup:
            • T Offline
              teitlebot @richland007
              @richland007 This wont be helpful but I will say I had a similar problem a few months back but now it works. Must be some configuration that changed in the mean time on my pi but I dont know what.
                bolish
                Hello there,
                I’m currently planning my project and will integrate PIR sensor + related 2.1 method through HDMI.There is one thing confusing me :
                • we talk about HDMI CEC in method 2.1
                • nevertheless, it seems the PIR Sensor module is “only” turning HDMI output off and that is triggering "issues such as “powersaving / no input”.
                But is HDMI CEC not allowing us to send a “turn screen off” command to the monitor instead of disabling the rasp. HDMIoutput and relying / hoping on the monitor’s behaviour?
                Sorry once more if I mssed the point, but would like to understand before moving forward.
                Regards
                  sdetweil @bolish
                  @bolish said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
                  as I understand it, not many monitors/tv’s provide support for external power off/on commands…
                  none of my TV’s used for MM support this…
                    bolish @sdetweil
                    @sdetweil Maybe you’re right! I didn’t considered that.
                    But seems possible, correct? By changing the actual commands to the ones defined by the libcec librairy?
                      sdetweil @bolish
                      @bolish I do not know… as I said, none of my TVs support ANY commands to turn off/on…
                      in my MMM-SleepWake module, I use module.hide() to hide everything, leaving a blank screen… for those devices that do not provide external control…
                        bolish
                        OK, I will then try myself when I will receive my stuff and let forums knows if working or not.
                        • 10
                        • 11
                        • 12
                        • 13
                        • 14
                        • 17
                        • 18
                        • 12 / 18
