    Updating MM on a PC?
    14 Posts 3 Posters 6.9k Views 2 Watching
    • D
      Damian
      Hello, yeah I may be sounding thick, but how does one update all on MM running on a PC? The MM itself, and all modules?
      I tried the usual Pi commands, but they are surely different?
      cd MagicMirror -then git pull -then npm install
      sudo apt-get updateor even tried
      cd MagicMirror > cd modules > cd MMM-WuderGround then type in git pull or
      In terminal, ~/MagicMirror/modules/MMM-WunderGround $
      and type git pull
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Damian
        @Damian said in Updating MM on a PC?:
        That should work. git commands and npm commands should work.
        sudo will not.
        • D
          Damian @Mykle1
          @Mykle1
          Damian@KitchenComputer ~/MagicMirror
          $ git pull
          Fatal: not a git repository (or any of the parent firectories): .git
          • cowboysdudeC
            cowboysdude Module Developer
            try:
            git pull origin master
            If you’re still having problems do this:
            sudo apt-get install git-all
            Then retry ‘git pull’…
            • D
              Damian @cowboysdude
              @cowboysdude said in Updating MM on a PC?:
              try:
              From ~MagicMirror
              $ git pull origin master
              fatal: Not a git repository (or any of the parent directories): .git
              $ sudo apt-get install git-all
              bash: sudo: command not found
              • cowboysdudeC
                Type ‘git init’ then retry ‘git pull’
                • D
                  Damian @cowboysdude
                  @cowboysdude
                  $ git init
                  Initialized empty git repository in C:/users/Damian/MagicMirror/.git/
                  $ git pull
                  fatal: no remote repository specified. Please, specify either a url or a remote name from which new revisions should be fetched.
                  • cowboysdudeC
                    cowboysdude Module Developer @Damian
                    git remote add origin https://github.com/MichMich/MagicMirror.git
                    • D
                      Damian @cowboysdude
                      @cowboysdude
                      Thanks will try that out when keyboard recharges, I have run battery flat with all the things I have tried 😮
                      • cowboysdudeC
                        @cowboysdude
                        Nice Job LOL I have to go to work :) Good luck!
                        • D
                          Damian @cowboysdude
                          @cowboysdude
                          Think I may just delete MM, and start afresh with virgin modules, then try and update again, and start adding my changes… see if it’s maybe me messing around has done something eh?
                          • cowboysdudeC
                            @Damian very possible you could have broke something. If the suggestions I gave you didn’t work… good idea, start over :) This time make backups of the files you are changing before you change them :)
                            • D
                              Damian @cowboysdude
                              @cowboysdude
                              Thanks, yeah for sure I will keep a “Master Files Folder” for all originals should something go weird?
                              As an aside, the updated compliments… on my Pi I noticed that they did not color since updating today, had a quick look and on comparing old file with updated file, there was a part missing … racking my brains to think the exact name, but it made reference to the CSS… so when I C&P that section from old file into new file, the compliments colored again!.. was this intentional to omit this or just an oversight from the dev?
                              • cowboysdudeC
                                @cowboysdude
                                I’m not really sure in all honesty. I have written most of my own modules and use none of the default ones.
