    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 158.5k Views 20 Watching
    • MichMichM Offline
      MichMich
      An other small suggestion: delay all show effects with the a delay equal to the animation time. This way all Modules that will need to hide will nicely hide before any new modules fade in.
      • I Offline
        ianperrin
        @MichMich - some great ideas, keep them coming.
        I’ve created issues (or rather enhancements) for these on GitHub - https://github.com/ianperrin/MMM-ModuleScheduler/issues. Feel free to review, comment etc.
        "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
        • Mr.MeeseeksM Offline
          Mr.Meeseeks
          Is it required to restart mm/server if a scheduler configuration is changed, add, removed?
          CAAAAN DOO!👍
          • I Offline
            ianperrin @Mr.Meeseeks
            @Mr.Meeseeks Apologies for missing this one.
            The schedules are set up after the ALL_MODULES_STARTED or DOM_OBJECTS_CREATED notifications have been received from the core. So a restart should not be required and a refresh of the browser should be sufficient to pick up config changes.
            • cowboysdudeC Offline
              cowboysdude Module Developer
              In retrospect I only wanted to be able to hide a module now and then LOL
              NEVER thought it would turn into such an awesome module!!!
              Thanks @ianperrin !!!
              • MitchfarinoM Offline
                Mitchfarino Module Developer
                @cowboysdude @ianperrin how would would I implement a schedule so that a module appeared for 5 minutes, then disappear and reappear in 5 minutes time?
                I’ve tried this
                module_schedule: { */5 * * * * },
                2nd edit- I thought I’d got it with this…
                module_schedule: { from: '*/2 * * * *', to: '*/3 * * * *'},
                cowboysdudeC I 2 Replies Last reply Reply Quote 0
                  cowboysdude Module Developer @Mitchfarino
                  @Mitchfarino said in MMM-ModuleScheduler:
                  I’ve tried this
                  Yes that should make it run every five minutes…
                  Copy and try this without brackets…
                  '*/5 * * * *'
                  example - schedule: ‘30 9 * * *’,
                  • I Offline
                    ianperrin @Mitchfarino
                    Try this
                    module_schedule: {from: '0/10 * * * *',  to: '5/10 * * * *'},
                    Which should equate to the module being
                    • shown every 10 minutes starting from 0 minutes past the hour, i.e. 0, 10, 20 etc
                    • hidden every 10 minutes starting from 5 minutes past the hour, i.e. 5, 15, 25 etc
                    MitchfarinoM 1 Reply Last reply Reply Quote 1
                      Mitchfarino Module Developer @ianperrin
                      @ianperrin cheers mate!
                      I’ll have a look tonight!
                      Fantastic module by the way
                      • I Offline
                        Thank you and no worries.
                        Unfortunately, I’ve just done a quick test with the expressions I posted above and they didn’t work. :(
                        If you check the cron expressions i suggested using crontab.guru, it would appear they are non-standard. Therefore, I suspect they are not supported by the node cron module.
                        Not to worry, there’s always a solution! crontab.org states that step values can be used in conjunction with ranges. So the expressions I believe you require are as follows:
                        module_schedule: {from: '0-59/10 * * * *',  to: '5-59/10 * * * *'},
                        • MichMichM Offline
                          MichMich
                          Any ETA for https://github.com/ianperrin/MMM-ModuleScheduler/issues/4 and https://github.com/ianperrin/MMM-ModuleScheduler/issues/6?
                          • I Offline
                            ianperrin @MichMich
                            @MichMich said in MMM-ModuleScheduler:
                            Wow - someone is keen ;)
                            The first iteration of #4 has been committed. Global schedules can now be added to show/hide/dim all modules - see the updated documentation for more info.
                            On the to list is to
                            • add support for showing/hiding/dimming modules in groups
                            • add the ability to exclude specific modules from the global schedules
                            #6 comes afterwards when I can switch my dev environment to the develop branch
                            • I Offline
                              ianperrin @MichMich
                              @MichMich
                              • one schedule can now be used to hide/show/dim all modules - see global scheduling
                              • one schedule can now be create to hide/show/dim a group of modules - see group schedules
                              To do:
                              • add the ability to exclude specific modules from the global/group schedules
                              • unit and regression tests ;)
                              • MichMichM Offline
                                MichMich
                                Nice work! LockStrings are not yet implemented, right? Until then I can’t use the module.
                                  I’m using it like this… but it’s not working for some reason:
                                  module: ‘MMM-ModuleScheduler’,
                                  global_schedule: [
                                  // SHOW MODULES WITH THE CLASS ‘daytime_scheduler’ AT 06:00 AND HIDE AT 22:00 EVERY DAY
                                  {from: ‘50 6 * * *’, to: ‘0 9 * * *’, groupClass: ‘scheduler_mfm’},
                                  {from: ‘50 6 * * *’, to: ‘0 23 * * *’, groupClass: ‘scheduler_mfd’},
                                  {from: ‘0 6 * * *’, to: ‘0 23 * * *’, groupClass: ‘scheduler_sat’},
                                  {from: ‘0 6 * * *’, to: ‘0 23 * * *’, groupClass: ‘scheduler_sun’},
                                  {from: ‘0 6 * * *’, to: ‘0 23 * * *’, groupClass: ‘scheduler_nflg’},
                                  {from: ‘0 6 * * *’, to: ‘0 23 * * *’, groupClass: ‘scheduler_nflng’}
                                  Then for example a module:
                                  		module: 'compliments',
                                  		position: 'lower_third',
                                                      classes: 'scheduler_mfm'
                                  I did update the module with ‘git pull’ so that’s okay but it’s not rendering correctly and shutting the module ‘off’
                                  Did I miss something simple again? :)
                                  • I Offline
                                    ianperrin @cowboysdude
                                    @cowboysdude - During my testing of the global scheduling feature, I identified an issue which meant the initial state of the modules may not have been correct. I’ve committed a potential fix for this which may fix your issue too so please feel free to git pull again and test.
                                    If it doesn’t work, can you let me know what is output in the logs pm2 logs mm - you should see something like the following for each of your global schedules
                                    MMM-ModuleScheduler is creating a global schedule for scheduler_mfm modules using '50 6 * * *' and '0 9 * * *' with dim level undefined
                                    MMM-ModuleScheduler is hiding scheduler_mfm modules
                                    MMM-ModuleScheduler has created the global schedule for scheduler_mfm modules
                                    MMM-ModuleScheduler will next show scheduler_mfm modules at Tue Nov 01 2016 06:50:00 GMT+0000 (UTC)
                                    MMM-ModuleScheduler will next hide scheduler_mfm modules at Tue Nov 01 2016 09:00:00 GMT+0000 (UTC)
                                    The second line in the above log example will only appear if the schedule means that the modules affected it should be initially hidden
                                    • I Offline
                                      ianperrin @MichMich
                                      LockStrings should now be supported - feel free to test and let me know if it works as expected!
                                        Will give it a try! Thanks @ianperrin !
                                          anatius
                                          I am trying to dim my mirror at nighttime - on weekdays between 10PM and 7AM, on weekends between 10Pm and 8AM. However, the below code does not do the trick - where is my mistake?
                                          			module: 'MMM-ModuleScheduler',
                                          				global_schedule: [
                                          					{from: '0 7 * * 1-5', to: '0 20 * * 1-5', dimLevel: '30'},
                                          					{from: '0 8 * * 0,6', to: '0 20 * * 0,6', dimLevel: '30'},
                                          • I Offline
                                            ianperrin @anatius
                                            @anatius The config looks okay, can you check the output of the log pm2 logs mm once you have started MM2 and viewed it in a browser then post the results here?
                                            It should look something like:
                                            MMM-ModuleScheduler received INITIALISE_SCHEDULER
                                            MMM-ModuleScheduler is setting the config
                                            MMM-ModuleScheduler is removing all scheduled jobs
                                            MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
                                            MMM-ModuleScheduler received CREATE_GLOBAL_SCHEDULE
                                            MMM-ModuleScheduler is creating a global schedule for all modules using "0 7 * * 1-5" and "0 20 * * 1-5" with dim level 30
                                            MMM-ModuleScheduler is dimming all modules
                                            MMM-ModuleScheduler has created the global schedule for all modules
                                            MMM-ModuleScheduler will next show all modules at Mon Dec 19 2016 07:00:00 GMT+0000 (UTC)
                                            MMM-ModuleScheduler will next dim all modules at Mon Dec 19 2016 20:00:00 GMT+0000 (UTC)
                                            MMM-ModuleScheduler is creating a global schedule for all modules using "0 8 * * 0,6" and "0 20 * * 0,6" with dim level 30
                                            MMM-ModuleScheduler will next show all modules at Sat Dec 24 2016 08:00:00 GMT+0000 (UTC)
                                            MMM-ModuleScheduler will next dim all modules at Sat Dec 24 2016 20:00:00 GMT+0000 (UTC)
                                            • 3 / 5
