    MMM-voice setup but MagicMirror wont display
    31 Posts 4 Posters 18.3k Views 4 Watching
      shazglass
      Hi everyone. am so new at this its scary - but that said, I have manged to build my own MM with a few added 3rd party modules, and I managed to change the notifications to be more personalized. I have managed to install MMM-voice, and written in the MagicMirror config/config.js file as directed, but I can’t get the MM to display any more. please can someone help me?
      I really would appreciate your time … many many thnx!
      			module: "MMM-voice",
      			position: "bottom_bar",
      				microphone: 1,
      • C Offline
        cyberphox
        Remove the …
          shazglass @cyberphox
          @cyberphox wow that was a fast response! thank you
          ok, removed the … MM now works but shows a microphone and says error.
          What have I done wrong?
            shazglass @shazglass
            I have my mic plugged into a USB sound card on my pi. Is that ok, or should I plug it directly into the audio of the pi? My mic is not a USB connection.
            • C Offline
              cyberphox
              Run this from terminal
              cat /proc/asound/cards
              and see if your microphone is listed as : 1
                @cyberphox said in MMM-voice setup but MagicMirror wont display:
                this is the response:
                pi@raspberrypi:~ $ cat /proc/asound/cards
                0 [ALSA ]: bcm2835_alsa - bcm2835 ALSA
                bcm2835 ALSA
                pi@raspberrypi:~ $
                  shazglass
                  the one above I took the USB sound card out and plugged the mic directly to the pi.
                  this one I did your command again with the sound card in the USB slot and mic connected to USB sound card:
                  bcm2835 ALSA
                  1 [Device ]: USB-Audio - USB Audio Device
                  GeneralPlus USB Audio Device at usb-3f980000.usb-1.3, full speed
                    I have gone onto the pi itself and chossen the usb as an audio device with clicking microphone and microphone capture… but still shows the “error” in MM display.
                    • C Offline
                      cyberphox
                      and you ran the dependencies script from the installers folder?
                      • C Offline
                        cyberphox
                        mine was error cause i accidentally cloned into MMM-Voice…capital V and it didnt create the dic file…
                        maybe try running npm start dev and see what errors you have in the console
                          @cyberphox yes, that I def did -was super careful with that.
                            @cyberphox heres what I get with the npm start dev…not sure I am doing this in the right dir. I checked the Capital V or v, and mine is def lowercase v
                            pi@raspberrypi:~/MagicMirror/modules/MMM-voice $ npm start dev
                            npm ERR! missing script: start
                            npm ERR! /home/pi/.npm/_logs/2018-04-07T15_24_32_070Z-debug.log
                              pi@raspberrypi:~/MagicMirror $ npm start dev
                              magicmirror@2.3.1 start /home/pi/MagicMirror
                              sh run-start.sh “dev”
                              Starting MagicMirror: v2.3.1
                              Loading config …
                              Loading module helpers …
                              Initializing new module helper …
                              Module helper loaded: MMM-EARTH
                              No helper found for module: MMM-CountDown.
                              Module helper loaded: MMM-voice
                              No helper found for module: MMM-QRCode.
                              All module helpers loaded.
                              Starting server on port 8080 …
                              Server started …
                              Connecting socket for: MMM-EARTH
                              Starting module: MMM-EARTH
                              Connecting socket for: MMM-voice
                              Starting module helper: MMM-voice
                              Starting module: newsfeed
                              Sockets connected & modules started …
                              Launching application.
                              https://epic.gsfc.nasa.gov/api/natural
                              Create new news fetcher for url: http://ewn.co.za/RSS Feeds/Latest News - Interval: 300000
                              MMM-voice: Checking files.
                              MMM-voice: Starting pocketsphinx.
                              Shutting down server…
                              Stopping module helper: updatenotification
                              Stopping module helper: MMM-EARTH
                              Stopping module helper: MMM-voice
                              Stopping module helper: newsfeed
                              • C Offline
                                cyberphox
                                is the dev window…check the console tab…look for errors
                                  @cyberphox hi… I am so hard trying not to be an ass… but I dont know what you mean? Sorry…I am serously a 5 day taught myself to help my son with his project.
                                    Mykle1 Project Sponsor Module Developer @shazglass
                                    @shazglass said in MMM-voice setup but MagicMirror wont display:
                                    No worries dude. Personally, I’m glad to see you involved with your son. That’s how this started for me. I wanted to have something in common with my 21 year old son so I could stay “cool” in his eyes. Now . . .
                                    I don’t use voice on my Pi mirror anymore but I do use it extensively on other boards. This is what I remember.
                                    • I didn’t use a 3rd party sound card
                                    • USB microphone plugged directly into USB port of the Pi
                                    • Needing to run alsamixer in a terminal window to set mic/capture device.
                                    • Testing mic by recording your voice (forgot command - google it)
                                    After that, installing MMM-voice, paying careful attention to the directions on how to install the dependencies. If at this point the module runs but displays a microphone and the word “ERROR” then I can help you. If, on the other hand, the module does not run and errors in the terminal or the dev console then something in your beginning steps is amiss
                                    S 1 Reply Last reply Reply Quote 2
                                      shazglass @Mykle1
                                      @Mykle1 Good morning.
                                      thank you for the reply, makes a lot of sense. I don’t know how to run alsamixer? which directory would I do that in. I have tested the mic and it def works. I am at the point where it displays a microphone with ERROR showing. Sometimes it says , INITIALISING, CHOOSE MODE, then straight away shows ERROR again. Is there something on the pi I need to configure? thnx again Mykle, and I am a mom to a 15 year old :)
                                      strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 0
                                      • strawberry 3.141S Offline
                                        strawberry 3.141 Project Sponsor Module Developer @shazglass
                                        @shazglass There is a error log in the module. Also there is a hidden debug option for for informations debug: true
                                          shazglass @strawberry 3.141
                                          @strawberry-3.141 Hi - thank you for your reply. Ok, so how do I fix the error log in the module? and where must i type debug: true? Sorry for being a pain - like I said, I have no idea, I am seriously just helping my son, who also just taught himself by reading all of this information.
                                            @shazglass
                                              module: 'MMM-voice',
                                              position: 'bottom_bar',
                                                microphone: 1,
                                                debug: true
                                            post your error and debug log, it’s huge so maybe on pastebin
