    Module Position
    34 Posts 5 Posters 21.1k Views 4 Watching
      maxbachmann
      can I change the position of a module while MM2 is running?
        dherl0623 @maxbachmann
        @maxbachmann As far as I know, no. You can however update your position in the configuration file, then press CTRL+R to hard refresh the MM browser.
          maxbachmann
          @dherl0623 ty Ik I can change it in there, but would have been cool to change during runtime so I can blend the module in at whatever place I currently need it ;) Well can’t change when it’s not possible
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @maxbachmann
            @maxbachmann there is now magicmirror api for it, but you could manipulate the dom and set the module in a different region manually.
              maxbachmann
              @strawberry-3-141
              How can I do that in there (sorry I am a absolute noob with the dom)
                maxbachmann
                I just asked my friend google:
                 var d = document.getElementById(wrapper);
                 d.style.left = newx_pos;
                 d.style.top = newy_pos;
                is that how to do it?
                  @maxbachmann no, you would get the module itself, the wrapper has an id with the identifier of the module, then you would get the wrapper of the position and would call appendChild with your module
                    maxbachmann
                    @strawberry-3-141 Can you help me with how that would look like in software? I am sorry this project is the first time I use javascript at all and absolutely clueless when it’s about the dom
                      @maxbachmann
                      // get the module to move with it's identifier
                      var clock = document.getElementById('module_0_clock');
                      // append it to the region you like
                      document.querySelector('div.region.top.left div.container').appendChild(clock);
                      it will work only if you already have a module in that position, otherwise you need to ovverride the style to display block
                      document.querySelector('div.region.top.left div.container').style.display = 'block';
                      that’s it
                        maxbachmann
                        @strawberry-3-141 So I always have to know wether there is already a element in that region? Is there a way to check all modules and return the ID’s of the elements that are in this position?
                        justjim1220J 1 Reply Last reply Reply Quote 0
                          maxbachmann
                          @strawberry-3-141 and where to add that? is that already the “end code”? I tried in the domupdate function and it did not work, so I guess that was wrong
                            it is safe to always run the code so you don’t need to check if there is a module necessarily.
                            it is not related to the get dom function, you can put it where ever you want except node_helper (because its not executed in the browser)
                            can you post the code of your module or upload it to github, then i can have a look
                              maxbachmann
                              In general I want to add it to all kind of modules so I can change the position when sending them a socketmessage to do so
                                @maxbachmann i wouldn’t place that code in other modules, you can perform that from your module for every module, this isn’t magicmirror related. its pure dom manipulation.
                                  maxbachmann
                                  Ah did not know that ;) well yes then it’s definetly in my program. All my program does so far is subscribe to a mqtt broker, load some data and according to this show/hide modules. Now I want to add the possibility to move modules to different positions.
                                  Can send the current code later
                                    maxbachmann @maxbachmann
                                    @strawberry-3-141 so in general use all 3 commands and then it works in both senarios? where can I find the right ID for each module?
                                      @maxbachmann you can get all modules https://github.com/MichMich/MagicMirror/tree/master/modules#module-selection then iterate over them and when you find the module execute the cmds
                                      const moduleToMove = 'clock';
                                      const targetRegion = 'top.left';
                                      MM.getModules().enumerate((module) => {
                                          if (module.name === moduleToMove) {
                                              const instance = document.getElementById(module.identifier);
                                              const region = document.querySelector(`div.region.${targetRegion} div.container`);
                                              region.appendChild(instance);
                                              region.style.display = 'block';
                                      something similar to this
                                        maxbachmann
                                        @strawberry-3-141 ty that works.
                                        Added the possibility
                                        region.insertBefore(instance, region.childNodes[0])
                                        so I can prepend and append the module
                                        • justjim1220J Offline
                                          justjim1220 Module Developer @maxbachmann
                                          @maxbachmann
                                          If you look in your css folder you will find the main.css file. Open it and you will find all the regions. Compare them to where you have you modules set and it should help you figure it out.
                                          “Life’s Too Short To Dance With Ugly People”
                                          Jim Hallock - 1995
                                            maxbachmann @justjim1220
                                            @justjim1220 it already works the way @strawberry-3-141 proposed :)
                                            Only thing I am not quite sure about yet is when can I use const?
                                            I have the code in socketmessagereceived. Can I use const in there when I do only give the variable one value each time it runs the function? Because for me it seems like the variables still exist when the function gets called again which would mean const does not work
