    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 216.9k Views 28 Watching
    • FallandeGubbeF Offline
      FallandeGubbe @Alvinger
      @Alvinger aahh… I think you might be right! I will do some investigation on this!
      Thanks! :thumbsup:
        albertc
        @Alvinger
        Is it possible to make the departure times show up as relative instead of absolute? As in: bus leaving in 5 mins, instead of at 09:44 (just as it looks at the bus stop).
        A 1 Reply Last reply Reply Quote -1
          Alvinger @albertc
          @albertc
          Not right now. This was a conscious decision on my part as the mirror updates fairly seldom. relative departure times would be showing the wrong info after one minute.
            MobbareKurtZ
            Module doesn’t show anything except the header for me, found this in the logs:
            node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: [object Object]
            What to do?
              MobbareKurtZ @MobbareKurtZ
              @MobbareKurtZ said in MMM-ResRobot - Public transport information for Sweden:
              What to do?
              Oh I think I got it. You can’t have a route that isn’t a direct run?
                albertc @Alvinger
                @Alvinger
                Thanks for the response! But wouldn’t it be possible to use the (seldomly updated) time and subtract real time and still have an accurate “time left to departure”? I guess the table on screen would need to be updated more often than data is loaded.
                  Alvinger @MobbareKurtZ
                  @MobbareKurtZ
                  It all depends on the underlying ResRobot API but it sounds reasonable that ResRobot needs to know in what direction you are travelling.
                  As the module only shows departures there is no need to specify a destination unless you want to limit the displayed departures to the ones going in that specific direction. In that case I would suggest to enter not the ultimate destination but rather the next “logical” stop such as point of transit between modes of transport.
                    MobbareKurtZ @Alvinger
                    @Alvinger How can you add multiple departure locations though?
                      @MobbareKurtZ
                      By adding them as a comma-separated list, e.g.
                      to: "54321,64321,74321"
                      where each from and to pair specify an id for the departure and destination stops. If destination is not needed for a departure station, simply leave it empty like this:
                      to: "54321,,74321"
                        @Alvinger Alright thanks!
                          Advokaten
                          Is this still working? I’m getting “Fetching departures…” message forever :(
                          		module: "MMM-ResRobot",
                          		position: "bottom_left",
                          			from: "740064518",		// ResRobot Station ID (or a comma-separated string of IDs)
                          			to: "740012366",			// ResRobot Station ID of destination (or a comma-separated string of IDs)
                          			skipMinutes: 0,		// Skip departures that happens within the next  minutes.
                          			maximumEntries: 6,	// Number of departures to show on screen
                          			truncateAfter: 5,	// A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
                          			apiKey: "my api key"		// Your ResRobot apiKey
                            Alvinger @Advokaten
                            @Advokaten
                            Strange, my mirror is running flawlessly. I’ll put in your config and see what happens.
                            A 2 Replies Last reply Reply Quote 0
                              Advokaten @Alvinger
                              @Alvinger I reinstalled it, rebooted and stuff and it magically appeared! Thank you for this wonderful module! :D (I have no idea what was wrong lol)
                                Advokaten @Alvinger
                                @Alvinger I saw that the bus line I pull data from is misnamed. Is there a way to fix this? Thanks.
                                  Alvinger @Advokaten
                                  @Advokaten
                                  Do you mean that the name of the bus stop is misnamed on screen? Then you have to contact ResRobot to change it.
                                  • W Offline
                                    wizz
                                    @Alvinger If i add 2 departure one for my bus and one for the train in the module i also want it to display 2 different mode of transportation icons,
                                    How do i do that?
                                    Or is it not possible?
                                    Wold be nice if it was an solution for this.
                                      Alvinger @wizz
                                      @wizz
                                      It’s automatic and already there! Try it and you’ll see.
                                      Icons are selected based on mode of transport, it’s going to be one of bus, metro, rail or ferry.
                                      • W Offline
                                        wizz
                                        @Alvinger ok thats nice will try tonight and see how it works :)
                                        • N Offline
                                          norden1978
                                          I am having the same trouble with “Fetching departures…”
                                          Tried to redo it some times but cannot get it to work.
                                          This is the config i use:
        module: "weatherforecast",
        header: "Weather Forecast",
        locationID: "2677025",  //ID from http://www.openweathermap.org/help/city_list.txt
        appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
        position: "right",
        header: "Tidtabell",
        to: "740001587",
        maximumEntries: 6,
        truncateAfter: 0,
        apiKey: "d0b6457c-a18e-42cc-9aa4-xxxxxxxxx"
                                          • E Offline
                                            Eburkis
                                            I have the same problem as norden1978 ^^above me and its stuck on “fetching departures”
                                            i dont know whats wrong
                                            here is my code
                                            		position: "left",
                                            		header: "Avgångar",
                                            			to: "1138",
                                            			skipMinutes: 0,
                                            			maximumEntries: 6,
                                            			truncateAfter: 2,
                                            			apikey: "MY APIKEY"		// Your ResRobot apiKey
                                            • 6
                                            • 7
                                            • 3 / 7
