    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 216.8k Views 28 Watching
      sweup @sdetweil
      @sdetweil - I only got this
      pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-ResRobot
      pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ git pull
      Updating 1618fcc..695f70d
      error: Your local changes to the following files would be overwritten by merge:
      	package.json
      Please commit your changes or stash them before you merge.
      Aborting
      pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ npm install
      npm WARN npm npm does not support Node.js v10.21.0
      npm WARN npm You should probably upgrade to a newer version of node as we
      npm WARN npm can't make any promises that npm will work with this version.
      npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
      npm WARN npm You can find the latest version at https://nodejs.org/
      up to date in 1.083s
      @Alvinger - I did a sudo reboot
        Alvinger @sweup
        @sweup it seems you have changed the file package.json
        Stash it away with “git stash” and try the update again.
          sweup @Alvinger
          @Alvinger said in MMM-ResRobot - Public transport information for Sweden:
          git stash
          Like this?
          git stash
          npm install
          Edit:misspell
            Alvinger @sweup
            @sweup
            git stash
            git pull
            npm install
              sweup @Alvinger
              @Alvinger - hmm something email adress. Any advice?
              pi@raspberrypi:~/MagicMirror/modules/MMM-ResRobot $ git stash
              *** Please tell me who you are.
              Run
                git config --global user.email "you@example.com"
                git config --global user.name "Your Name"
              to set your account's default identity.
              Omit --global to set the identity only in this repository.
              fatal: unable to auto-detect email address (got 'pi@raspberrypi.(none)')
              Cannot save the current index state
              	package.json
              Aborting
              up to date in 1.02s
                sdetweil @sweup
                @sweup let’s find out what u changed
                do
                git diff
                  sweup @sdetweil
                  @sdetweil - sry I’m a bit lost, do I do “git diff” after?
                  git stash
                  git pull
                  npm install
                    sdetweil @sweup
                    @sweup git stash fails cause u are not registered to git on your machine
                    git pull fails cause it would overwrite a change u.made to package.json
                    so, I was trying to find out what the change was, and how important it is…
                    the other commands won’t work til we resolve the diff(erence) issue
                      sweup
                      @sdetweil @Alvinger - thx guys, after
                      $ git config --global user.email "you@example.com"
                      $ git config --global user.name "Your Name"
                      I could solve it with git stash
                        sdetweil @sweup
                        @sweup yeh, but we don’t know what change u lost/stashed
                          Alvinger @sdetweil
                          @sdetweil @sweup
                          My guess is that it is an unintended change probably caused by saving rather than exiting when viewing the file.
                          Anyway, package.json only contains information about the module and can without issue be replaced with a “git pull”.
                          @sweup Great that you solved it. A small suggestion for the future: as most modules (and MagicMirror itself) uses Github you should read up on GIT and its basic commands. It will make life easier for you!
                            Alvinger
                            @sweup I just pushed a minor update with some new options. Feel free to try the new version out.
                            • Z Offline
                              Zapman
                              Hello! :D
                              Got some issue with the module. The module loads when starting up MagicMirror, but stays at “Fetching departures …”. I tried my API key here;
                              (https://api.resrobot.se/v2/trip?key=API-KEY-HERE&originId=740047279&destId=740010151&format=xml) and it worked fine. So the key itself seams to work. I’m using the API key from “ResRobot - Reseplanerare”. I set the key in the config.js.
                              My current config.js;
                              			module: "MMM-ResRobot",
                                                      header: "Departures",
                                                              routes: [ // stations from:
        {from: "740015972", to: ""},
                                                              apiKey: "API-KEY-HERE"
                              Terminal message;
                              [2020-09-23 03:21:58.036] [LOG]    node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {
                                "updateInterval": 60000,
                                "animationSpeed": 2000,
                                "fade": true,
                                "fadePoint": 0.25,
                                "apiBase": "https://api.resrobot.se/v2/departureBoard?format=json&passlist=0",
                                "apiKey": "API-KEY-HERE",
                                "routes": [
                                    "from": "740015972",
                                    "to": ""
                                "skipMinutes": 0,
                                "maximumEntries": 6,
                                "truncateAfter": 5,
                                "truncateLineAfter": 5,
                                "showTrack": true,
                                "getRelative": 0,
                                "coloredIcons": false,
                                "iconTable": {
                                  "B": "fa fa-bus",
                                  "S": "fa fa-subway",
                                  "J": "fa fa-train",
                                  "U": "fa fa-subway",
                                  "F": "fa fa-ship"
                                "colorTable": {
                                  "B": "#DA4439",
                                  "S": "#019CD5",
                                  "J": "#FDB813",
                                  "U": "#019CD5",
                                  "F": "#444400"
                              Maybe someone can have an idea what might be wrong here :crazy_face:
                              A 2 Replies Last reply Reply Quote 0
                                Alvinger @Zapman
                                @Zapman I’ll have a look. Your config looks fine at a first look.
                                  sweup @Alvinger
                                  @Alvinger - thx for you work in this module!
                                  Sidenote, after updated my Rpi (3B) my wifi reception is far worst, never had problem with it before but now it’s loosing connection after a couple of minutes - but I was fast and manage to update to latest ResRobot :) working nicely
                                    Alvinger @Zapman
                                    @Zapman said in MMM-ResRobot - Public transport information for Sweden:
                                    @Zapman You can’t have a comment in the middle of the config. Remove the " // stations from: " and it should work.
                                    This is what it looks like for me:
                                      sdetweil @Alvinger
                                      sure you can, they are ignored, there are comments all over the place
                                        Alvinger @sdetweil
                                        @sdetweil Yes, they should be. However, when I pasted @Zapman’s config into my test site, it didn’t work. When I removed the comment it worked. Go figure!
                                        Z S 2 Replies Last reply Reply Quote 0
                                        • Z Offline
                                          Zapman @Alvinger
                                          @Alvinger Everything is working great now! Thank you for the fast response to my issue! I’ll use this module a lot from now on :smiling_face_with_open_mouth:
                                            sdetweil @Alvinger
                                            @Alvinger i added that config to another module with the comment and got what was expected. 1 route structure in an array
                                            • 6
                                            • 7
                                            • 6 / 7
