    run Linux command from a mm2 module
    20 Posts 5 Posters 6.6k Views 5 Watching
      Mykle1 Project Sponsor Module Developer @Guest
      @sean
      First, thank you for your input. I do appreciate it.
      1. Adding your suggestion results in an uncaught exception. . . TypeError: Cannot read property ‘1’ of null
      2. Using your suggestion and taking out the “[1]” results in an array with a single object
      • ? Offline
        A Former User @Mykle1
        @mykle1
        null means not found. Maybe my regular espression pattern was wrong. As I wrote, it was not tested.
        However if you find proper expression pattern, it will return matched string. Google it about regular expression. That is a standard way to search or replace text by pattern in most of program languages.
          @sean
          ok thank you. This seems like a good place to start.
          https://www.regular-expressions.info/
          • ? Offline
            @mykle1
            • https://www.w3schools.com/jsref/jsref_obj_regexp.asp
            • https://www.w3schools.com/jsref/jsref_match.asp
              See these also.
              @sean
              See these also.
              Thanks!
                @sdetweil said in run Linux command from a mm2 module:
                let me see what I can do.
                Will be tomorrow.
                Thanks! Anything you can offer will be much appreciated.
                This what I have, and sent to the module.js
                • ? Offline
                  @mykle1
                  test.js
                  var str = `nouveau-pci-0100↵Adapter: PCI adapter↵fan1:        1170 RPM↵temp1:        +43.0°C  (high = +95.0°C, hyst =  +3.0°C)↵                       (crit = +105.0°C, hyst =  +5.0°C)↵                       (emerg = +135.0°C, hyst =  +5.0°C)↵↵coretemp-isa-0000↵Adapter: ISA adapter↵Core 0:       +46.0°C  (high = +83.0°C, crit = +99.0°C)↵Core 1:       +41.0°C  (high = +83.0°C, crit = +99.0°C)↵Core 2:       +46.0°C  (high = +83.0°C, crit = +99.0°C)↵Core 3:       +38.0°C  (high = +83.0°C, crit = +99.0°C)↵↵f71858fg-isa-0a00↵Adapter: ISA adapter↵+3.3V:        +3.31 V  ↵3VSB:         +3.30 V  ↵Vbat:         +3.20 V  ↵fan1:        1910 RPM↵fan2:        1069 RPM↵fan3:           0 RPM  ALARM↵temp1:        +34.5°C  (high = +70.0°C, hyst = +60.0°C)↵temp2:        +29.5°C  (high = +100.0°C, hyst = +85.0°C)↵temp3:        +36.4°C  (high = +100.0°C, hyst = +85.0°C)↵↵`
                  var pattern = [
                    "(fan[0-9]):[\\s]+([0-9]+ RPM)",
                    "(temp[0-9]):[\\s]+(\\+[0-9\\.]+°C)",
                  for (i = 0; i < pattern.length; i++) {
                    var rx = new RegExp(pattern[i], "g")
                    var found
                    do {
                      found = rx.exec(str)
                      if (found) console.log(found[1], found[2])
                    } while(found)
                  RESULT
                    @sean said in run Linux command from a mm2 module:
                    RESULT
                    Excellent sean! Working here as well. You have my eternal gratitude. :thumbsup:
                    EDIT
                    Using your example above as a guide I was able to add to the pattern array successfully.
                    My addition
                    "(Core [0-9]):[\\s]+(\\+[0-9\\.]+°C)"
                    Result
                    Now I’ll do the ones I want. Thank you again, sean. This is awesome!
                      sdetweil @Mykle1
                      @mykle1 @sean nice work. Sorry I ran out of time.
                        No worries, bro. I appreciate your interest and concern. I’m sure I’ll need help in the future. You can get in on that. :-)
