    MMM-3Day-Forecast
    31 Posts 9 Posters 23.9k Views 9 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @nigel-daniels
      @nigel-daniels said in MMM-3Day-Forecast:
      @cowboysdude enjoy… you won’t have missed the ‘chance of rain’ icon there :)
      Why Thank you sir :)
      • N Offline
        nigel-daniels
        FYI there is a minor fix to the chance of storm icons, there was a typo in the gif files name which prevented it from displaying. This also impacted MMM-Weather-Now.
          MattSharp
          Don’t suppose there’s any support on this module these days?
          I just get stuck on Loading… after I’ve installed this, my API key is correct and tested in browser, the only error I can see that I think relates to it is "[TypeError: Cannot read property ‘simpleforecast’ of undefined] :/
          Any help would be appreciated but after 2 years I’m not expecting anything! :p
          N Mykle1M 2 Replies Last reply Reply Quote 0
          • N Offline
            nigel-daniels @MattSharp
            @MattSharp Hi, from what you describe the error is happening because the node_helper is not getting a response to the call to get the weather status in the first place. That’s where it expect the simpleforcast to be a part of the response. Can you post a version of your config to verify the call is happening ok?
              Mykle1 Project Sponsor Module Developer @MattSharp
              @MattSharp
              @nigel-daniels
              I had nothing to do tonight so I took a look at this for you. I’m certain your problem lies with your config entry. Why? Because I tried a few things in the config and received the “[TypeError: Cannot read property ‘simpleforecast’ of undefined]”. This occurs when the state and/or city value is incorrect. I tried 3 cities in 2 different states and the module works fine. If you have further trouble I will try to help you. Here is my WORKING config entry.
                          disabled: false,
                          module: 'MMM-3Day-Forecast',
                          position: 'top_right',
                          config:	{
                              api_key: '123456789abcde', // Wunderground api key
                              state: 'NY',               // US states or other country codes
                              city: 'Elmira'            // City, eg. New_York (with underscore - no spaces)
              • N Offline
                nigel-daniels
                I have just migrated this to the WeatherBit API as Wunderground are cancelling the free service :( This forces an update of the module and a new config! I’ve updated the read me in GitHub, so please take a look.
                  dxfan227 @nigel-daniels
                  @nigel-daniels hello! Not sure if you are still around but I was wondering if you could help.
                  I have installed the module correctly, and using imperial, but would like to remove the metric notation that is listed in () . What do I need to edit to accomplish this?
                  Thank you
                  • N Offline
                    nigel-daniels
                    Hi, I have not been able to work on these modules as a full time role has limited my time considerably. To make tweaks I recommend forking the repo in git hub.
                      skaireks
                      (image url = “https://github.com/nigel-daniels/MMM-3Day-Forecast/blob/master/3-day2.png”!)
                      I am sorry , how to turn the weather on the second option???
                      • T Offline
                        thiske
                        Hey newbie here,
                        I have changed the language to dutch in the config file, but some of the translations are wrong, where does the translate come from? so that I can change some text.
                        greets Thijs
                        • 3 / 4
