    MMM-3Day-Forecast
    31 Posts 9 Posters 28.7k Views 9 Watching
    • N Offline
      nigel-daniels
      I recommend re-cloning to anyone using the module, there were a couple of missing icons. They are now in place.
      • cowboysdudeC Offline
        cowboysdude Module Developer @nigel-daniels
        @nigel-daniels as soon as I get back home… am on vacation [holiday] in Galveston, Texas :) Nice and sunny and very warm here! …
        • N Offline
          nigel-daniels @cowboysdude
          @cowboysdude enjoy… you won’t have missed the ‘chance of rain’ icon there :)
            @nigel-daniels said in MMM-3Day-Forecast:
            Why Thank you sir :)
            • N Offline
              nigel-daniels
              FYI there is a minor fix to the chance of storm icons, there was a typo in the gif files name which prevented it from displaying. This also impacted MMM-Weather-Now.
                MattSharp
                Don’t suppose there’s any support on this module these days?
                I just get stuck on Loading… after I’ve installed this, my API key is correct and tested in browser, the only error I can see that I think relates to it is "[TypeError: Cannot read property ‘simpleforecast’ of undefined] :/
                Any help would be appreciated but after 2 years I’m not expecting anything! :p
                N Mykle1M 2 Replies Last reply Reply Quote 0
                • N Offline
                  nigel-daniels @MattSharp
                  @MattSharp Hi, from what you describe the error is happening because the node_helper is not getting a response to the call to get the weather status in the first place. That’s where it expect the simpleforcast to be a part of the response. Can you post a version of your config to verify the call is happening ok?
                    Mykle1 Project Sponsor Module Developer @MattSharp
                    @MattSharp
                    @nigel-daniels
                    I had nothing to do tonight so I took a look at this for you. I’m certain your problem lies with your config entry. Why? Because I tried a few things in the config and received the “[TypeError: Cannot read property ‘simpleforecast’ of undefined]”. This occurs when the state and/or city value is incorrect. I tried 3 cities in 2 different states and the module works fine. If you have further trouble I will try to help you. Here is my WORKING config entry.
                                disabled: false,
                                module: 'MMM-3Day-Forecast',
                                position: 'top_right',
                                config:	{
                                    api_key: '123456789abcde', // Wunderground api key
                                    state: 'NY',               // US states or other country codes
                                    city: 'Elmira'            // City, eg. New_York (with underscore - no spaces)
                    • N Offline
                      nigel-daniels
                      I have just migrated this to the WeatherBit API as Wunderground are cancelling the free service :( This forces an update of the module and a new config! I’ve updated the read me in GitHub, so please take a look.
                        dxfan227 @nigel-daniels
                        @nigel-daniels hello! Not sure if you are still around but I was wondering if you could help.
                        I have installed the module correctly, and using imperial, but would like to remove the metric notation that is listed in () . What do I need to edit to accomplish this?
                        Thank you
                        • N Offline
                          nigel-daniels
                          Hi, I have not been able to work on these modules as a full time role has limited my time considerably. To make tweaks I recommend forking the repo in git hub.
                            skaireks
                            (image url = “https://github.com/nigel-daniels/MMM-3Day-Forecast/blob/master/3-day2.png”!)
                            I am sorry , how to turn the weather on the second option???
                            • T Offline
                              thiske
                              Hey newbie here,
                              I have changed the language to dutch in the config file, but some of the translations are wrong, where does the translate come from? so that I can change some text.
                              greets Thijs
                                MajorC Project Sponsor @nigel-daniels
                                @nigel-daniels is there a way to have the weather icons with transparent background?
