    MMM-3Day-Forecast
    31 Posts 9 Posters 29.2k Views 9 Watching
    • MichMichM
      MichMich
      No, the translations are frontend only.
      About the translations: just make a modular specific english translations file. When that is done, others can send you a pull request with other languages.
      • N
        nigel-daniels
        I recommend re-cloning to anyone using the module, there were a couple of missing icons. They are now in place.
        • cowboysdudeC
          cowboysdude Module Developer @nigel-daniels
          @nigel-daniels as soon as I get back home… am on vacation [holiday] in Galveston, Texas :) Nice and sunny and very warm here! …
          • N
            nigel-daniels @cowboysdude
            @cowboysdude enjoy… you won’t have missed the ‘chance of rain’ icon there :)
            • cowboysdudeC
              @nigel-daniels said in MMM-3Day-Forecast:
              Why Thank you sir :)
              • N
                nigel-daniels
                FYI there is a minor fix to the chance of storm icons, there was a typo in the gif files name which prevented it from displaying. This also impacted MMM-Weather-Now.
                  MattSharp
                  Don’t suppose there’s any support on this module these days?
                  I just get stuck on Loading… after I’ve installed this, my API key is correct and tested in browser, the only error I can see that I think relates to it is "[TypeError: Cannot read property ‘simpleforecast’ of undefined] :/
                  Any help would be appreciated but after 2 years I’m not expecting anything! :p
                  N Mykle1M 2 Replies Last reply Reply Quote 0
                  • N
                    nigel-daniels @MattSharp
                    @MattSharp Hi, from what you describe the error is happening because the node_helper is not getting a response to the call to get the weather status in the first place. That’s where it expect the simpleforcast to be a part of the response. Can you post a version of your config to verify the call is happening ok?
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @MattSharp
                      @MattSharp
                      @nigel-daniels
                      I had nothing to do tonight so I took a look at this for you. I’m certain your problem lies with your config entry. Why? Because I tried a few things in the config and received the “[TypeError: Cannot read property ‘simpleforecast’ of undefined]”. This occurs when the state and/or city value is incorrect. I tried 3 cities in 2 different states and the module works fine. If you have further trouble I will try to help you. Here is my WORKING config entry.
                                  disabled: false,
                                  module: 'MMM-3Day-Forecast',
                                  position: 'top_right',
                                  config:	{
                                      api_key: '123456789abcde', // Wunderground api key
                                      state: 'NY',               // US states or other country codes
                                      city: 'Elmira'            // City, eg. New_York (with underscore - no spaces)
                      • N
                        nigel-daniels
                        I have just migrated this to the WeatherBit API as Wunderground are cancelling the free service :( This forces an update of the module and a new config! I’ve updated the read me in GitHub, so please take a look.
                          dxfan227 @nigel-daniels
                          @nigel-daniels hello! Not sure if you are still around but I was wondering if you could help.
                          I have installed the module correctly, and using imperial, but would like to remove the metric notation that is listed in () . What do I need to edit to accomplish this?
                          Thank you
                          • N
                            nigel-daniels
                            Hi, I have not been able to work on these modules as a full time role has limited my time considerably. To make tweaks I recommend forking the repo in git hub.
                              skaireks
                              (image url = “https://github.com/nigel-daniels/MMM-3Day-Forecast/blob/master/3-day2.png”!)
                              I am sorry , how to turn the weather on the second option???
                              • T
                                thiske
                                Hey newbie here,
                                I have changed the language to dutch in the config file, but some of the translations are wrong, where does the translate come from? so that I can change some text.
                                greets Thijs
                                  MajorC Project Sponsor @nigel-daniels
                                  @nigel-daniels is there a way to have the weather icons with transparent background?
