    MMM-3Day-Forecast
    31 Posts 9 Posters 29.2k Views 9 Watching
    • cowboysdudeC
      Well did find out was using the wrong ‘key’… fixed that and entered the url in the web browser and it gives me the results but won’t load on the mirror. Running in DEV mode shows no errors either…
      Thank you!
      • cowboysdudeC
        Even just running nothing but the MMM-Weather-Now and MMM-3Day-Forecast all I get is
        Loading… on both…
        git cloned it
        switched to that dir and ran ‘npm install’
        put the proper config in the mirror
        ran it in DEV mode getting no errors and it’s loading
        Nothing.
        • N
          nigel-daniels @cowboysdude
          @cowboysdude thanks for all of the info, it points to a need for to set up the same environment you have and to recreate the issue you have. I have a spare Pi so I’ll set up the full environment on it. When I’ve got there (probably Wed) I’ll see if I can debug the set up.
          The system I’m running is on a Pi Zero running as node serveronly so I suspect there could be an issue with these modules firing up under electron. I’ll check this out and let you know what I find out.
          • cowboysdudeC
            Ahhhhhhhhhh yes that could do it… at first I thought perhaps the ‘classes’ where my issue but I think you’re correct! Thanks a bunch!
            • N
              @cowboysdude I’ve spotted an error in my ReadMe that I think has caused the problem here. In my example config I only put key where I entered the API key instead of api_key. Try changing the name of that config variable and things should sort themselves out, I hope that works. Let me know if there are any other problems and I’ll update the Read Me files.
              • cowboysdudeC
                cowboysdude Module Developer @nigel-daniels
                @nigel-daniels said in MMM-3Day-Forecast:
                api_key
                That sir solved the issue!! Many Thanks… it’s running great now! :)
                • N
                  nigel-daniels
                  This module has been updated to include humidity. More details on the module read me page here.
                  • MichMichM
                    MichMich
                    It might be a good idea to make use of the available translations. The words “Today”, “Tomorrow” and “Day After” are all part of the system translations. Check the documentation on how to use it. :)
                    • N
                      nigel-daniels @MichMich
                      @MichMich great idea… done! If anyone can translate the text I have? I’d appreciate and will add the appropriate files.
                      BTW. I assume this does not work in the node helper?
                      • MichMichM
                        MichMich
                        No, the translations are frontend only.
                        About the translations: just make a modular specific english translations file. When that is done, others can send you a pull request with other languages.
                        • N
                          nigel-daniels
                          I recommend re-cloning to anyone using the module, there were a couple of missing icons. They are now in place.
                          • cowboysdudeC
                            @nigel-daniels as soon as I get back home… am on vacation [holiday] in Galveston, Texas :) Nice and sunny and very warm here! …
                            • N
                              @cowboysdude enjoy… you won’t have missed the ‘chance of rain’ icon there :)
                              • cowboysdudeC
                                Why Thank you sir :)
                                • N
                                  nigel-daniels
                                  FYI there is a minor fix to the chance of storm icons, there was a typo in the gif files name which prevented it from displaying. This also impacted MMM-Weather-Now.
                                    MattSharp
                                    Don’t suppose there’s any support on this module these days?
                                    I just get stuck on Loading… after I’ve installed this, my API key is correct and tested in browser, the only error I can see that I think relates to it is "[TypeError: Cannot read property ‘simpleforecast’ of undefined] :/
                                    Any help would be appreciated but after 2 years I’m not expecting anything! :p
                                    N Mykle1M 2 Replies Last reply Reply Quote 0
                                    • N
                                      nigel-daniels @MattSharp
                                      @MattSharp Hi, from what you describe the error is happening because the node_helper is not getting a response to the call to get the weather status in the first place. That’s where it expect the simpleforcast to be a part of the response. Can you post a version of your config to verify the call is happening ok?
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @MattSharp
                                        @MattSharp
                                        @nigel-daniels
                                        I had nothing to do tonight so I took a look at this for you. I’m certain your problem lies with your config entry. Why? Because I tried a few things in the config and received the “[TypeError: Cannot read property ‘simpleforecast’ of undefined]”. This occurs when the state and/or city value is incorrect. I tried 3 cities in 2 different states and the module works fine. If you have further trouble I will try to help you. Here is my WORKING config entry.
                                                    disabled: false,
                                                    module: 'MMM-3Day-Forecast',
                                                    position: 'top_right',
                                                    config:	{
                                                        api_key: '123456789abcde', // Wunderground api key
                                                        state: 'NY',               // US states or other country codes
                                                        city: 'Elmira'            // City, eg. New_York (with underscore - no spaces)
                                        • N
                                          nigel-daniels
                                          I have just migrated this to the WeatherBit API as Wunderground are cancelling the free service :( This forces an update of the module and a new config! I’ve updated the read me in GitHub, so please take a look.
                                            dxfan227 @nigel-daniels
                                            @nigel-daniels hello! Not sure if you are still around but I was wondering if you could help.
                                            I have installed the module correctly, and using imperial, but would like to remove the metric notation that is listed in () . What do I need to edit to accomplish this?
                                            Thank you
