    MMM-3Day-Forecast
    31 Posts 9 Posters 29.4k Views 9 Watching
    • N
      nigel-daniels
      Nice idea! I’m tied up for a few days but I’ll do my best to grab some time and look into getting humidity posted too.
      • cowboysdudeC
        Love this and the weather now but…
        I have my config setup correctly it just says…
        “Loading Weather Data…”
        “Loading Forecast Data”
        That’s as far as it ever goes…
        N 1 Reply Last reply
        • N
          nigel-daniels @cowboysdude
          @cowboysdude hi, sorry to here that:( I have a couple of questions to check out what may be going on:
          1. Did the request dependancy install ok?
          2. Can you post or pm me the config you are using?
          I’ll try and recreate the issue and figure out what is going on… It may be best to do this as an issue on the github site.
          N cowboysdudeC 2 Replies Last reply
          • N
            nigel-daniels @nigel-daniels
            @nigel-daniels another thing to try out as well is to test your API key is ok. Just put:
            http://api.wunderground.com/api/[YOUR_API_KEY_HERE]/conditions/q/CA/San_Francisco.json
            Into a browser replacing the [] and their content with your own api key. It should return a bunch of text with the data on the current weather in San Francisco.
            • cowboysdudeC
              cowboysdude Module Developer @nigel-daniels
              @nigel-daniels Yes I ran the npm install inside the directories and it went without issue.
              Yes I’ll PM you my config
              Thanks!
              • cowboysdudeC
                Well did find out was using the wrong ‘key’… fixed that and entered the url in the web browser and it gives me the results but won’t load on the mirror. Running in DEV mode shows no errors either…
                Thank you!
                • cowboysdudeC
                  Even just running nothing but the MMM-Weather-Now and MMM-3Day-Forecast all I get is
                  Loading… on both…
                  git cloned it
                  switched to that dir and ran ‘npm install’
                  put the proper config in the mirror
                  ran it in DEV mode getting no errors and it’s loading
                  Nothing.
                  • N
                    @cowboysdude thanks for all of the info, it points to a need for to set up the same environment you have and to recreate the issue you have. I have a spare Pi so I’ll set up the full environment on it. When I’ve got there (probably Wed) I’ll see if I can debug the set up.
                    The system I’m running is on a Pi Zero running as node serveronly so I suspect there could be an issue with these modules firing up under electron. I’ll check this out and let you know what I find out.
                    • cowboysdudeC
                      Ahhhhhhhhhh yes that could do it… at first I thought perhaps the ‘classes’ where my issue but I think you’re correct! Thanks a bunch!
                      • N
                        @cowboysdude I’ve spotted an error in my ReadMe that I think has caused the problem here. In my example config I only put key where I entered the API key instead of api_key. Try changing the name of that config variable and things should sort themselves out, I hope that works. Let me know if there are any other problems and I’ll update the Read Me files.
                        • cowboysdudeC
                          @nigel-daniels said in MMM-3Day-Forecast:
                          api_key
                          That sir solved the issue!! Many Thanks… it’s running great now! :)
                          • N
                            nigel-daniels
                            This module has been updated to include humidity. More details on the module read me page here.
                            • MichMichM
                              MichMich
                              It might be a good idea to make use of the available translations. The words “Today”, “Tomorrow” and “Day After” are all part of the system translations. Check the documentation on how to use it. :)
                              • N
                                nigel-daniels @MichMich
                                @MichMich great idea… done! If anyone can translate the text I have? I’d appreciate and will add the appropriate files.
                                BTW. I assume this does not work in the node helper?
                                • MichMichM
                                  MichMich
                                  No, the translations are frontend only.
                                  About the translations: just make a modular specific english translations file. When that is done, others can send you a pull request with other languages.
                                  • N
                                    nigel-daniels
                                    I recommend re-cloning to anyone using the module, there were a couple of missing icons. They are now in place.
                                    • cowboysdudeC
                                      @nigel-daniels as soon as I get back home… am on vacation [holiday] in Galveston, Texas :) Nice and sunny and very warm here! …
                                      • N
                                        @cowboysdude enjoy… you won’t have missed the ‘chance of rain’ icon there :)
                                        • cowboysdudeC
                                          Why Thank you sir :)
                                          • N
                                            nigel-daniels
                                            FYI there is a minor fix to the chance of storm icons, there was a typo in the gif files name which prevented it from displaying. This also impacted MMM-Weather-Now.
