    MMM-3Day-Forecast
    31 Posts 9 Posters 28.8k Views 9 Watching
    • N Offline
      nigel-daniels
      This module is another weather module and is a port of a home-brew mirror project I’d done prior to switching to MM2. I got used to the three day forecast and the details it provided so figured I’d port it across. I hope you like it.
      You can get it here
      cowboysdudeC M 2 Replies Last reply Reply Quote 3
      • cowboysdudeC Offline
        cowboysdude Module Developer @nigel-daniels
        @nigel-daniels very nice… nice enough to make me want to switch mine out!!
        Have you thought about adding humidity next to the chance of rain perhaps?
        • N Offline
          nigel-daniels
          Nice idea! I’m tied up for a few days but I’ll do my best to grab some time and look into getting humidity posted too.
            Love this and the weather now but…
            I have my config setup correctly it just says…
            “Loading Weather Data…”
            “Loading Forecast Data”
            That’s as far as it ever goes…
            • N Offline
              nigel-daniels @cowboysdude
              @cowboysdude hi, sorry to here that:( I have a couple of questions to check out what may be going on:
              1. Did the request dependancy install ok?
              2. Can you post or pm me the config you are using?
              I’ll try and recreate the issue and figure out what is going on… It may be best to do this as an issue on the github site.
              N cowboysdudeC 2 Replies Last reply Reply Quote 0
              • N Offline
                nigel-daniels @nigel-daniels
                @nigel-daniels another thing to try out as well is to test your API key is ok. Just put:
                http://api.wunderground.com/api/[YOUR_API_KEY_HERE]/conditions/q/CA/San_Francisco.json
                Into a browser replacing the [] and their content with your own api key. It should return a bunch of text with the data on the current weather in San Francisco.
                  @nigel-daniels Yes I ran the npm install inside the directories and it went without issue.
                  Yes I’ll PM you my config
                  Thanks!
                    Well did find out was using the wrong ‘key’… fixed that and entered the url in the web browser and it gives me the results but won’t load on the mirror. Running in DEV mode shows no errors either…
                    Thank you!
                      Even just running nothing but the MMM-Weather-Now and MMM-3Day-Forecast all I get is
                      Loading… on both…
                      git cloned it
                      switched to that dir and ran ‘npm install’
                      put the proper config in the mirror
                      ran it in DEV mode getting no errors and it’s loading
                      Nothing.
                      • N Offline
                        @cowboysdude thanks for all of the info, it points to a need for to set up the same environment you have and to recreate the issue you have. I have a spare Pi so I’ll set up the full environment on it. When I’ve got there (probably Wed) I’ll see if I can debug the set up.
                        The system I’m running is on a Pi Zero running as node serveronly so I suspect there could be an issue with these modules firing up under electron. I’ll check this out and let you know what I find out.
                          Ahhhhhhhhhh yes that could do it… at first I thought perhaps the ‘classes’ where my issue but I think you’re correct! Thanks a bunch!
                          • N Offline
                            @cowboysdude I’ve spotted an error in my ReadMe that I think has caused the problem here. In my example config I only put key where I entered the API key instead of api_key. Try changing the name of that config variable and things should sort themselves out, I hope that works. Let me know if there are any other problems and I’ll update the Read Me files.
                              @nigel-daniels said in MMM-3Day-Forecast:
                              api_key
                              That sir solved the issue!! Many Thanks… it’s running great now! :)
                              • N Offline
                                nigel-daniels
                                This module has been updated to include humidity. More details on the module read me page here.
                                • MichMichM Offline
                                  MichMich
                                  It might be a good idea to make use of the available translations. The words “Today”, “Tomorrow” and “Day After” are all part of the system translations. Check the documentation on how to use it. :)
                                  • N Offline
                                    nigel-daniels @MichMich
                                    @MichMich great idea… done! If anyone can translate the text I have? I’d appreciate and will add the appropriate files.
                                    BTW. I assume this does not work in the node helper?
                                    • MichMichM Offline
                                      MichMich
                                      No, the translations are frontend only.
                                      About the translations: just make a modular specific english translations file. When that is done, others can send you a pull request with other languages.
                                      • N Offline
                                        nigel-daniels
                                        I recommend re-cloning to anyone using the module, there were a couple of missing icons. They are now in place.
                                          @nigel-daniels as soon as I get back home… am on vacation [holiday] in Galveston, Texas :) Nice and sunny and very warm here! …
                                          • N Offline
                                            @cowboysdude enjoy… you won’t have missed the ‘chance of rain’ icon there :)
