    MMM-GooglePhotos
    294 Posts 56 Posters 391.8k Views 59 Watching
      sdetweil @celliott
      @celliott I don’t know for sure but there is debugging info available
      edit the node_helper.js
      and add
             debug:true,
      between these two lines
        start: function()
      then stop mm, pm2 stop all if using pm2
      then
      cd ~/MagicMirror
      npm start >somefile.txt
      wait til u see the error
      then ctrl-c on the mm terminal window
      (alt-spacebar, n to.minimize mm screen if you didn’t use ssh)
      • O Offline
        orayoflighto Project Sponsor
        For those just joining, I was able to get this to work using the Google OAuth desktop option and the V2 token generator that hermanho made at the link below
        https://github.com/aneaville/MMM-GooglePhotos/issues/145
        M 2 Replies Last reply Reply Quote 1
          megagprime @orayoflighto
          @orayoflighto awesome thanks guys but some of us are really dumb and I can’t figure this out. No new get token no matter how hard I try and I don’t know how to do it on my local pc… If I copy the file over I get the following ![alt text](image url)
            @orayoflighto i tried to do this but i am too dumb, how do i clone on local pc ? and when i do put v2 in folder and node i get this error 9fdb2fe4-798b-4de7-90fd-ea673cdfbd7f-image.png
              sdetweil @megagprime
              @megagprime to get a pull request
              in the existing module folder do
              git fetch origin pull/#/head:local_branch_name
              replace # w 146
              and pick a name for branch name
              the when that completes (no message)
              do
              git checkout whatever name u used
              now your photos module is using the pull request version
              then the normal instructions should work
              edit : shows what u get for not checking and trusting some ‘now old’ post on the internet!
                megagprime @sdetweil
                @sdetweil admin@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ pull/<145>/head:< g2 >
                bash: syntax error near unexpected token `145’
                  @megagprime no <>
                  • L Offline
                    Lilleberg
                    I have just installed MagicMirror on my RaspberryPi and are now playing around trying to tweak my screen to my needs. Just now I want to show a slideshow of one of my albums in the top region of the screen. I have my screen vertically.
                    So the photo should show cover the whole top region from edge to edge, and maybe 1/3 down from the top edge. Trying to use the top_bar position, but the photos then are shown with a padding on the left side and in the top, and are not resized to fit inside the region. Anybody that can show how this can be done? Maybe in the css file?
                      bhepler Module Developer @Lilleberg
                      @Lilleberg Try using the upper_third position for your pictures. That may be closer to what you want.
                      • 1 Offline
                        1a2a3a
                        hi, does anyone know how to configure the sizing of the gphoto?
                        im trying to make the photo not full screen, but to perhaps just the top portion of the mirror or to some size of the mirror (havent really decided on the location) but having trouble sizing them.
                        i changed the showWidth and showHeight but while they make the picture smaller, the quality seems to be reduce?
                        i have also added #GPHOTO in CSS with width and height at 50% but it still feel like its showing full screen…
                        • 1 Offline
                          1a2a3a
                          Did something change here? I’m getting an invalid module position found for this configuration. My position is “fullscreen”. It used to be working fine…?
                            sdetweil @1a2a3a
                            @1a2a3a yes we added checking for position names
                            its fullscreen_above and fullscreen_below
                            here is the list of MagicMirror module positions
                            https://docs.magicmirror.builders/modules/configuration.html
                            1 1 Reply Last reply Reply Quote 0
                            • 1 Offline
                              1a2a3a @sdetweil
                              @sdetweil which option is the same as the previous ‘fullscreen’?
                                sdetweil @1a2a3a
                                @1a2a3a fullscreen_below
                                • 11
                                • 12
                                • 13
                                • 14
                                • 15
                                • 15 / 15
