    MMM-Jnews
    Scheduled Pinned Locked Moved Education
    33 Posts 10 Posters 20.0k Views 8 Watching
      barnosch
      Do you plan to add more sources manually?
      Currently there are only the top-headlines implemented. Which is good enough.
      But, i would like to add some more (from the newsapi page) like wired or TechCrunch.
      edit:
      ok after testing i really would like to add the sources in an array maually if possible, since there are the very unuseful BILD news in the top-headlines.
      And some cosmetics stuff: the date stuff “1hour ago” and so on i static and not translated.
      No problem for me, just for the notes ;)
      Thanks for the module.
      cowboysdudeC 1 Reply Last reply Reply Quote 2
      • cowboysdudeC Offline
        cowboysdude Module Developer @barnosch
        @barnosch Feel free then do a pull request :) That would be pretty awesome!!
          cowboysdude Module Developer @justjim1220
          @justjim1220 Well because the wunderground key isn’t good for anything else so may as well try it here LOL
          justjim1220J 1 Reply Last reply Reply Quote 2
            jeffreyking
            Hi I am new to this and I did so I think all that is to be done and it still do not work tell me to config.js file
                                     module: 'MMM-Jnews'
            	                             apiKey: "my api",
                                                 image : true, [default is false, Raspberry Pi's don't like the images]
                                                 rotateInterval: 25 * 1000 [This is default set to 25 seconds, you can change this if you'd like]
                                     module: 'MMM-MovieListings',
                                            position: 'top_center',   // This can be any of the regions. Best results in left or$
            					apiKey: 'de1d0b92bb87bncbbbbbbbbbbbbbbbbbbbbbb9f7a57b',
            					region: 'US',
            					language: 'EN',
            					interface: 'poster', //'list', 'poster', 'detailed'
            					includeMoviePlot: false,
            					maxPlotLength: 198,
            					header: 'Movie Listings',
            					moviesPerPage: 0,
            					refreshInterval: 1000 * 60 * 60 * 24, //Once a day
            					baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
            					animationSpeed: 2.5 * 1000,
            					pageChangeInterval: 35 * 1000
            cowboysdudeC bheplerB 2 Replies Last reply Reply Quote 0
              bjoern
              This post is deleted!
                cowboysdude Module Developer @jeffreyking
                @jeffreyking said in MMM-Jnews:
                module: ‘MMM-Jnews’
                apiKey: “my api”,
                image : true
                OK first off you have to go to https://newsapi.org/ and get your api key…the key they give you has to go in between the quotes like this [for example]
                apiKey : “aabjadjfadfas9adfajsdlfja”
                The rest of the config should work for you as I’ve rewritten it… use the above example only go get the api and replace “my apikey” with “YOUR KEY” put in quotes that you get from the newsapi.org link :)
                • justjim1220J Offline
                  justjim1220 Module Developer @cowboysdude
                  @cowboysdude
                  You know I just had to give you some sh** a little bit.
                  It is a nice module, as I suspected, no way to get local news without making some changes to your code.
                  I really like the set up though.
                  Great job! (as usual!) :grinning_face: :grinning_face: :grinning_face:
                  Jim Hallock - 1995
                  cowboysdudeC 1 Reply Last reply Reply Quote 1
                    @justjim1220 said in MMM-Jnews:
                    @cowboysdude
                    Yes it’s news from a bunch of different sources all brought together…
                      Mykle1 Project Sponsor Module Developer @cowboysdude
                      @cowboysdude said in MMM-Jnews:
                      I’m getting just a little bit tired of all your success. ;-)
                        bjoern
                        Great module. I like it. Question: Some lines of text consist of 3 lines and the next message is 4. As a result, the modules above will always jump “up and down”. Can you set the module to 4 lines and these automatically fill depending on the content? Do you understand what I want to express?
                        • 4 / 4
